Samsung GalaxyBook4 Pro 360 512GB
Quicklinx: HTYTWS00 Mfr#: NP964QGK-KG1UK
Screen Size: 16in
Processor Model: 155H
Operating System: Windows 11 Pro
Hard Drive Capacity: 512GB
Graphics: Intel Arc Graphics
  • IEEE 802.11n
£1,582.50 ex VAT
£1,899.00 inc VAT
The Samsung Galaxy Book4, powered by an Intel Core Ultra 7 processor and boasting 32GB of RAM and a capacious 1TB SSD, delivers exceptional performance for both work and play. Its RTX 4050 graphics card ensures smooth gaming and content creation experiences, while the 16-inch touchscreen display offers immersive visuals and intuitive interaction. Running on Windows 11 Pro, this laptop combines productivity and versatility, making it an ideal choice for professionals seeking a powerful and feature-rich computing solution.
Unbeatable performance. Boosted by AI
Blast through heavy workloads and multitask seamlessly with the supercharged Intel® Core™ Ultra processor, equipped with an advanced NPU for next-level AI performance. Together with the NVIDIA® GeForce RTX™ Laptop Graphics delivering cutting-edge immersive visuals, turning your big ideas into reality has never been easier.
New touchscreen. Creativity at your fingertips
Create and navigate easily on the Galaxy Book4 Ultra with your fingertips. The all-new responsive touch panel on the Dynamic AMOLED 2X display lets you tap your way around with intuitive multi-touch gestures and edit content directly on the screen.
Anti-reflective cover glass. Dazzling views at any angle
Get a clear view of what you love with Corning® Gorilla® Glass with DX. This anti-reflective cover glass on the display reduces distracting reflections and glare, helping onscreen content to be sharp and readable at varying viewing angles and particularly in brightly lit conditions.
Vision Booster. The clear solution to glare
See your screen clearly in sunny weather thanks to Vision Booster. An intelligent outdoor algorithm uses tone mapping to enhance the contrast and colours depending on the light conditions, so you can enjoy the same vibrant picture, even if your workstation is outdoors.
Fast charging. All-day productivity
Go from one creative project to the next with the long-lasting 76Wh (typical) battery for up to 21 hours of video runtime. Then power up your laptop with 55% charge in just 30 minutes — with a light and portable charger that's compatible with your other Samsung Galaxy devices.
Heavy duty design meets lightweight
Weighing just under 1.9kg and with a sleek Moonstone Grey finish, Galaxy Book4 Ultra's refined look is one for the books. Encased in a slim and durable body, it's your portable creative studio on the path to inspiration.
Samsung Knox. Pro security. No worry
Samsung Knox helps provide overall protection to keep your system safe. A dedicated hardware security chip helps safeguard your critical system data in real time. Shielded from the inside out, your device is protected from malicious attacks and breaches for your peace of mind.
Wider-angle cam with AI studio effects
Galaxy Book4 Ultra gets you ready for the spotlight with the FHD wide-angle webcam and studio quality mics with AI noise canceling. Combined with features such as Auto Framing and eye contact correction in Studio effects, it helps you look sharp and sound clear on every video call.
Quad speakers amp up your sound quality
Hear the action in your epic playthroughs with the clarity and depth of the quad-speaker system. The four speakers are tuned with AKG and Dolby Atmos for champion-level surround sound that knocks out the competition.
Earth-friendly innovation. Carbon Trust Certified
With a Carbon Trust Certification for reduced carbon footprint throughout its lifecycle, Galaxy Book4 Ultra is crafted with the planet in mind. Plus, the use of recycled materials and 100% paper packaging mean that with each one you unbox the change you want to see in the world.
Use your phone as a connected camera
Upgrade your video calls from standard laptop webcam to stunning clarity using your Samsung Galaxy smartphone as a connected camera. Connect seamlessly to your Galaxy Book4 Ultra, switch between front and rear cameras to find your angle, and enjoy a high-quality picture with enhanced video effects in video applications.
Stay on task, stay in touch with AI assistant
Manage your tasks via quick chat prompts with Copilot's personalized AI assistance. Plus, get smarter communication tools — access contacts and send messages effortlessly from your PC or Samsung Galaxy mobile device with a simple chat command.
Connect your phone and PC for seamless access
Get direct access to content on your phone right from your laptop with File Explorer. Simply set up the wireless connection between your devices and you're set — search for the files and photos you need, then open them seamlessly from your PC.
Meet your AI photo editing ally: Photo Remaster
The AI-powered Photo Remaster tool lets you breathe new life into old photos and low-quality images. Using a smart algorithm, the feature allows you to clean up blurry photos, as well as remove unwanted light and shade from your snaps with just a tap.
Samsung Studio. Create and edit seamlessly
Create and edit your next masterpiece across devices with Samsung Studio. Shoot a video and start cutting on one of your Samsung Galaxy mobile devices, then export easily via Quick Share to add final touches with precision on the big screen of Galaxy Book4 Ultra.
  • Immersive display
    Experience visual clarity and color accuracy with the 16-inch Full HD AMOLED touchscreen, boasting a 120% DCI-P3 color gamut, 400 cd/m2 brightness, and GorillaGlass with DX for durability. Its Variable refresh rate (VRR) and cinematic experience features ensure smooth, lifelike visuals whether you're gaming or watching movies.
  • Powerful performance
    Powered by the Intel Core Ultra 7 processor with 16 cores, reaching speeds up to 4.8 GHz, and equipped with 16 GB of LPDDR5X SDRAM, the Samsung Galaxy Book4 Pro 360 handles intensive tasks and multitasking with ease. The 512 GB NVMe SSD ensures quick boot times and ample storage.
  • Versatile connectivity
    Featuring Thunderbolt 4, HDMI, and USB 3.2 interfaces, along with Wi-Fi 6E and Bluetooth 5.3 support, this notebook offers versatile connectivity options for all your peripherals and ensures fast Internet speeds.
  • Innovative design
    With its 360° flip design, backlit keyboard, and included S Pen, the Samsung Galaxy Book4 Pro 360 adapts to your workflow, whether you're typing, drawing, or presenting. The notebook's 2-in-1 capability enhances productivity and creativity on-the-go.
  • Enhanced audio experience
    Dolby Atmos compliant AKG quad speakers paired with Smart Amplification technology deliver a rich, immersive audio experience. Dual array microphones with AI noise reduction ensure your voice is crystal-clear during calls, even in noisy environments.
Samsung Galaxy Book4 Pro 360 - AI Ready - 16" - Intel Core Ultra 7 - 155H - Evo - 16 GB RAM - 512 GB SSD
Notebook - AI Ready - 2-in-1 - flip design
Operating System
Win 11 Pro
Platform Technology
Intel Evo
Intel Core Ultra 7 (Series 1) - 155H / 1.4 GHz, up to 4.8 GHz / 24 MB Cache
16 GB LPDDR5X (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
16" touchscreen 2880 x 1800 / WQXGA+ @ 120 Hz - 212 ppi
Graphics
Intel Arc Graphics
Input Device
ClickPad, S Pen
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
Accelerometer, ambient light sensor, gyro sensor
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Moonstone grey
35.54 cm x 25.22 cm x 1.28 cm
1.66 kg
Limited warranty - return to base - 3 years
Notebook - AI Ready - Yes - flip design
Operating System
Windows 11 Pro
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 1) 155H / 1.4 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
16-core
Cache
L3 - 24 MB
Platform Technology
Intel Evo
Intel Smart Cache
RAM
16 GB (provided memory is soldered)
LPDDR5X SDRAM
Storage
Main Storage
512 GB SSD - NVM Express (NVMe)
Display
16" - AMOLED
Touchscreen
Resolution
2880 x 1800 (WQXGA+)
V-Sync Rate at Max Res.
120 Hz
Widescreen
Pixel Density (ppi)
212
Image Aspect Ratio
16:10
Image Brightness
400 cd/m²
Colour Gamut
120% DCI-P3
Anti-glare, blue light reduction, 0.2 ms response rate, Variable refresh rate (VRR), cinematic experience, gaming performance, GorillaGlass with DX
Keyboard Name
Pro keyboard
Audio & Video
Graphics Processor
Intel Arc Graphics
Camera
Yes - 1080p
Resolution
2 Megapixel
Camera Features
Wide angle lens, auto framing, Eye Contact function
Sound
AKG quad speakers, dual array microphone
Dolby Atmos
Audio Features
Output: Smart Amplification technology; Input: AI noise reduction
Input
Keyboard, ClickPad, S Pen
Keyboard Backlight
Numeric Keypad
Backlit
Communications
Wireless
Miracast, dual stream (2x2)
Lithium Ion
76 Wh
Battery Run Time
Video playback: up to 21 hours
AC Adapter
Output
65 Watt
Connections & Expansion
Interfaces Details
HDMI , 2 x Thunderbolt 4 , USB 3.2 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Software
Software Included
Samsung Recovery Solution, Samsung Update, Samsung Settings, Samsung Gallery, Studio Plus, Samsung Flow, Live Wallpaper, Quick Search, Samsung Notes, Screen Recorder, Galaxy Book Smart Switch, Quick Share, Samsung Pass, Second Screen, Private Share, Galaxy Book Experience
Moonstone grey
Integrated Options
Security
65W power adapter
USB-C to USB-C cable
SGS Eye Care Display Certification
1.66 kg
Sustainability Information
TCO Certified
Screen Size: 16in
Brand: Samsung
Price Range Ex VAT: £1500+
