Samsung Galaxy Z Flip6 512GB Blue
Quicklinx: HR9JWS00 Mfr#: SM-F741BLBHEUB
  • Android
£1,082.50 ex VAT
£1,299.00 inc VAT
With Galaxy AI your Galaxy Z Flip6 becomes your super-smart helper, saving you time and effort across a ton of day-to-day tasks – before you’ve even unfolded it. Capture shots like never before. Galaxy Z Flip6 comes with the best ever camera on Flip for the eye-popping portrait, pro-level editing and detail-rich video.
  • Even better together with Galaxy AI
    Easily sync multiple Galaxy devices to track your health and wellness on the go.
  • Nighttime portraits are lit
    Capture stunning shots in the daylight, the dark of night and even in dimly lit areas. Use Nightography to ensure every photo shines with detail, thanks to ProVisual Engine.
  • 50MP camera for stunning portraits
    The upgraded 50MP wide rear camera processes your pics through the ProVisual Engine to capture detailed scenes and richer portraits.
  • Automatically zooms for your best shot
    FlexCam uses the power of Galaxy AI to automatically zoom in and out on subjects and provides a preview on FlexWindow for a hands-free selfie experience.
  • FlexCam portraits hit different
    Use FlexWindow to give your subject a 50MP preview. Then, snap a pic to capture bright and detailed portraits even when backlit.
  • Long-lasting battery
    Meet a super-long-lasting battery. Paired with Snapdragon 8 Gen 3 for Galaxy, you can talk, text or game to your heart's content - all day long.
  • Your privacy secured
    Quickly see which apps are accessing your information and customize your settings.
  • Built to withstand
    Built with durable Corning Gorilla Glass Victus 2 exterior and IP48 water-resistance for those unexpected spills.
Samsung Galaxy Z Flip6 - blue - 5G smartphone - 512 GB - GSM
5G smartphone
Manufacturer Model Number
SM-F741B
Display
OLED display - 2640 x 1080 pixels - 6.7" - 425 ppi - (120 Hz) - 22:9 - Dynamic AMOLED 2X - HDR - Corning Gorilla Glass Victus 2 (scratch resistant glass) - inward - foldable
Display (2nd)
OLED display - colour - 3.4"
Qualcomm Snapdragon 8 Gen 3 for Galaxy 3.39 GHz (8-core)
RAM 12 GB / 512 GB
Operating System
Android 14 with One UI 6.1.1
Main Camera
50 Megapixel - wide-angle lens - f/1.8 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
10 Megapixel f/2.2 - focus free
Service Provider
Not specified
Folder (flip) - touch screen, dual screen
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Bluetooth, Wi-Fi 6, Wi-Fi 6E
Security Devices
Face recognition, fingerprint reader (side)
Connectors
USB-C
Wireless Charging Standards
Wireless PowerShare, Fast Wireless Charging 2.0, Qi, WPC
Protection
Water-resistant
Blue
71.9 mm x 6.9 mm x 165.1 mm
187 g
Repairability Index
8 (out of 10)
1.09 W/kg (head) , 1.511 W/kg (body) , 2.59 W/kg (limb)
Smartphone
SM-F741B
Protection
Water-resistant
71.9 mm
6.9 mm
165.1 mm
187 g
Dimensions Details
Unfolded - 71.9 mm x 6.9 mm x 165.1 mm , Folded - 71.9 mm x 14.9 mm x 85.1 mm
Body Colour
Blue
Body Material
Armour Aluminium frame, Corning Gorilla Glass Victus 2
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 14
User Interface
One UI 6.1.1
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n2, n3, n5, n7, n8, n12, n20, n25, n26, n28, n38, n40, n41, n66, n75, n77, n78
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, n12, FDD 800, FDD 1900, FDD 850, FDD 700APT, TDD TD 2600, TDD 2300, TDD TD 2500, FDD AWS-3, SDL DL 1500+, TDD TD 3700, TDD TD 3500
Wireless Interface
NFC, Bluetooth 5.3, IEEE 802.11a/b/g/n/ac/ax, Wi-Fi 6E
Phone Features
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
Security Devices
Additional Features
MIMO technology, Flex Window, Flex mode, Samsung Smart Switch, Samsung KNOX, Samsung Knox Vault, Multi Widget View, Flex Hinge, Interpreter, Galaxy AI, Suggested replies, Photo Ambient, cooling system with vapour chamber, Samsung Care+, Live Translate, Chat Assist, Circle to Search, Google Gemini app, Transcript Assist, Samsung Health, Note Assist, Drawing Assist, Samsung Wallet, 7 years of Security Updates, 7 generations of OS upgrades, SmartThings Support
Media Player
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Atmos sound technology
Clock Speed
3.39 GHz
Processor Core Qty
8-core
RAM
LPDDR5X SDRAM - 12 GB
Internal Memory Capacity
512 GB
User Memory
482.8 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Focus free
Field of View (FoV)
85 degree(s)
Pixel Size
1.22 µm
Main Camera
Sensor Resolution
50 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Field of View (FoV)
85 degree(s)
Pixel Size
1 µm
Focus Adjustment
Automatic
Digital Zoom
10x
Camera Modes
Nightography, HYPERLAPSE, Panorama, Portrait, Portrait video, Pro Video, Slow motion mode
Light Source
LED flash
Video Resolutions
3840 x 2160 (4K) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
FlexCam, Dual Pixel Autofocus technology, ProVisual Engine, 2x Optical Quality Zoom, Photo Assist, Generative Edit, Instant Slow-mo, Auto Zoom, Dual preview, Adaptive Pixel Sensor, Single Take
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Pixel Size
1.12 µm
Display
OLED display
Dynamic AMOLED 2X
Diagonal Size
6.7"
Display Resolution
2640 x 1080 pixels
Display Format
Full HD+
Foldable
Design
Inward folding
Pixel Density
425 ppi
Aspect Ratio
22:9
Max Brightness
2600 cd/m²
Colour Depth
16.7 million colours
HDR
HDR Technology
HDR10+
Refresh Rate
120 Hz
Protection
AOD(Always On Display), 1-120Hz adaptive refresh rate
Display (2nd)
Diagonal Size
3.4"
Display Resolution
720 x 748 pixels
Colour Depth
Connector Type
USB Type-C - 24 pin USB-C
4000 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging
Wireless Charging
Run Time Details
Active online usage (LTE): up to 19 hrs , Active online usage (Wi-Fi): up to 20 hrs , Playback (wireless video): up to 23 hrs , Playback (wireless audio): up to 68 hrs
USB 3.2 Gen 1, Android Audio Streaming for Hearing Aid (ASHA), IP48, IEC 61960
SIM card removal tool, USB-C cable
Regional Warranty Exceptions
Spain - 3 years
Sustainability Information
Repairability Index
8 (out of 10)
Packaging Recycled Content
100 % - recycled paper
Max Depth of Water Resistance
1.5 m
