Envelop your Galaxy Z Flip5 with the luxurious Flap Eco-Leather Case. Crafted using eco-conscious materials, this case enhances the sleek look of your phone while helping to protect against bumps and scratches.
Premium design meets practicality
Chic and minimalist, the Flap Eco-Leather Case is both stylish and functional, adding a touch of sophistication to your outfit with its smooth texture. Designed with the planet in mind, it contains material partially derived from plant-based sources such as corn. -
Stylish hinge protection
The case features soft lining on the inside to provide protection without compromising on style. The flap adds an extra layer of security to safeguard the hinge so you can use your device with confidence, knowing that it's well protected.
- Samsung EF-VF731 - protective case - back cover for mobile phone
- Product Type
- Protective case back cover for mobile phone
- 7.63 cm x 1.05 cm x 16.94 cm
- 31 g
- Material
- Eco-leather
- Black
- Designed For
- Galaxy Z Flip5
- 7.63 cm
- 1.05 cm
- 16.94 cm
- 31 g
- Material
- Eco-leather
- Black
Carrying Case
- Protective case
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- UL
- Designed For
- Samsung Galaxy Z Flip5
