Samsung Galaxy Z Flip5 512GB Graphite
Quicklinx: HBR6WS00 Mfr#: SM-F731BZAHEUB
Operating system: Android 13
Model: Z Flip5
Mobile Connectivity: 5G
Screen Size: 6.7in
Rear Camera: 12 Megapixel
Hurry, only 1 left in stock!
£999.17 ex VAT
£1,199.00 inc VAT
A perfect fit - both in life and your pocket. A brilliant Flex Window you can customize. A camera that captures selfies from edgy angles. Plus, a battery that keeps up.
  • Flex Window, the large cover screen on a Galaxy Z Flip
    Galaxy Z Flip5 has a 3.4-inch Flex Window built for self expression. Compact and eye-catching from every angle, this foldable is as versatile as it is portable.
  • Camera, good selfie experience on a Galaxy smartphone
    Capture stunning selfies with FlexCam and make any angle your good. No matter which camera you choose, Galaxy Z Flip5 makes it easy. All you have left to do is master the art of the pose.
  • Meet the 3.4" Flex Window
    Reply to messages with a QWERTY keyboard, make calls, check the weather forecast and even pull out your wallet - all from a big, bright Flex Window. Featuring more clock faces and crisscross gestures you know from across the Galaxy ecosystem. And no matter how many widgets you use, you'll never get lost in the shuffle with Multi Widget View.
  • All-day battery life
    Backed up by a powerful processor, this battery is even more efficient, stretching out the charge so you can keep binging movies or gaming late into the night. Need extra juice? Enable low power mode to keep the fun flowing.
  • The powerful processor on Galaxy foldables
    The Snapdragon 8 Gen 2 Mobile Platform for Galaxy takes you to a whole high level of power. Experience smoother graphics, faster AI and improved battery performance.
  • An flex, Flex Mode Panel
    Level up how you use Flex Mode with more controls at your fingertips. Hide or expand the panel with the touch of a button. You can even whip out a touchpad and curser. And an enhanced playback control panel makes navigating through music and media easier and more precise than ever.
  • Durable to keep you flipping
    Galaxy Z Flip5 stays tough. And with the added support of Samsung Care+, take it with you without worrying about whatever slip-ups may happen along the way.
Samsung Galaxy Z Flip5 - graphite - 5G smartphone - 512 GB - GSM
5G smartphone
Manufacturer Model Number
SM-F731B
Display
OLED display - 2640 x 1080 pixels - 6.7" - (120 Hz) - 22:9 - Dynamic AMOLED 2X - inward - foldable
Display (2nd)
OLED display - colour - 3.4"
Qualcomm Snapdragon 8 Gen 2 3.36 GHz (8-core)
RAM 8 GB / 512 GB
Operating System
Android 13 with One UI 5.1.1
Main Camera
12 Megapixel - wide-angle lens - f/1.8 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
10 Megapixel f/2.2 - focus free
Service Provider
Not specified
Folder (flip) - touch screen, dual screen
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Wi-Fi 6, Wi-Fi 6E, Bluetooth
Security Devices
Face recognition, fingerprint reader (side)
Connectors
USB-C
Talk Time
Up to 2100 minutes
Wireless Charging Standards
WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Water-resistant
Graphite
71.9 mm x 6.9 mm x 165.1 mm
187 g
Repairability Index
8 (out of 10)
0.601 W/kg (head) , 1.451 W/kg (body) , 2.34 W/kg (limb)
Smartphone
SM-F731B
Protection
Water-resistant
71.9 mm
6.9 mm
165.1 mm
187 g
Dimensions Details
Unfolded - 71.9 mm x 6.9 mm x 165.1 mm , Folded - 71.9 mm x 15.1 mm x 85.1 mm
Body Colour
Graphite
Body Material
Armor aluminium, Corning Gorilla Glass Victus 2
SAR Value
2.34 W/kg (limb), 1.451 W/kg (body), 0.601 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 13
User Interface
One UI 5.1.1
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Communications
Data Transmission
LTE, FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n75, n77, n78, n40, n25, n12
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac/ax, Wi-Fi 6E, Bluetooth 5.3
Phone Features
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
Security Devices
Additional Features
MIMO technology, Samsung KNOX, Samsung Smart Switch, Flex mode, Flex Window, Multi Widget View, Flex Hinge
Media Player
Supported Digital Audio Standards
WAV, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Clock Speed
3.36 GHz
Processor Core Qty
8-core
RAM
8 GB
Internal Memory Capacity
512 GB
User Memory
453.7 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Focus free
Field of View (FoV)
85 degree(s)
Pixel Size
1.22 µm
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Field of View (FoV)
83 degree(s)
Pixel Size
1.8 µm
Focus Adjustment
Automatic
Digital Zoom
10x
Camera Modes
Nightography
Light Source
LED flash
Video Resolutions
3840 x 2160 (4K) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Slo-mo video 1920 x 1080 (1080p) at 960 fps
Dual Pixel Autofocus technology, FlexCam
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Pixel Size
1.12 µm
Display
OLED display
Dynamic AMOLED 2X
Diagonal Size
6.7"
Display Resolution
2640 x 1080 pixels
Display Format
Full HD+
Foldable
Design
Inward folding
Aspect Ratio
22:9
Max Brightness
1750 cd/m²
Colour Depth
16.7 million colours
Refresh Rate
120 Hz
Video Wallpaper
Display (2nd)
Diagonal Size
3.4"
Display Resolution
720 x 748 pixels
Colour Depth
Connector Type
USB Type-C - 24 pin USB-C
3700 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging
Wireless Charging
Talk Time
2100 minutes
Run Time Details
Talk (4G): up to 2100 min , Active online usage (LTE): up to 17 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (wireless video): up to 20 hrs , Playback (wireless audio): up to 57 hrs
VDE, IPX8, USB 3.2 Gen 1, Android Audio Streaming for Hearing Aid (ASHA)
SIM card removal tool, USB-C cable
Sustainability Information
Repairability Index
8 (out of 10)
Max Depth of Water Resistance
1.5 m
HBR6 Samsung Galaxy Z Flip5 Leather Case In Stock £46.74
Model: Z Flip5
Screen Size: 6.7in
Brand: Samsung
Price Range Ex VAT: £750 - £1000
