Samsung Galaxy Z Flip4 128gb Pink Gold
Quicklinx: HQTRWS00 Mfr#: SM-F721BZDGEUB
The era of planning looks around your phone is over. Small but mighty when folded, Galaxy Z Flip4 is a compact full-sized smartphone, and just the right size to slip in a pocket when it's time to slay. The 6.7-inch display unfolds a beautiful view thanks to ultra thin Glass. Advanced durability makes it stronger than ever - staying tough through up to 200,000 folds. From the inside out, Galaxy Z Flip4 is made to be durable. These are their toughest foldables ever with exclusive Corning Gorilla Glass Victus+. And the hinge is protected by Armor Aluminum - their toughest aluminum frame.
  • Fits all your fits
  • Holds up from flex to flat
  • Flippin' strong
  • Still unafraid of water
    Water you worried about. These are the water-resistant foldable smartphones. It can hang out in 1.5 meters of water for up to 30 minutes without breaking a sweat.
  • Live your best nightlife
    The night just got brighter with Nightography on the Rear Camera. Details are brought to light even in the dark with bigger pixels on the Wide Camera. Nightography isn't just for stills - it's also got video skills. When the action gets going, recordings stay smooth, not shaky, with enhanced OIS and VDIS. Powerful processing allows Super Night Solution to minimize noise so clips of the crew stay clear well into the night.
  • Go ahead, flex on them
    Introducing FlexCam, a versatile, hands-free camera experience. Take advantage of your phone's agile angles to capture group shots, selfies and videos from mind-blowing perspectives and impressive true-to-life detail - even in your go-to social apps.
  • Enter your self-portrait era
    Take selfies with the rear camera while the cover screen gives you a real-time preview. Check yourself from afar with a full-screen view finder, or tap to see the original ratio to make sure everyone is in frame. And with software upgrades, Quick Shot is ready for even more action at all the angles between folded and FlexCam.
  • Give your feed a glow-up
    Content creation just got easier. FlexCam holds its own to broaden your directorial POV, letting you film yourself, your friends or your actors from fresh angles. And once your movie is premiere-ready, it's simple to upload right to your social media for well-deserved accolades.
  • Power to the pocket
    With this much juice, you can let every call go into overtime. An upgraded 4 nm processor works with the long-lasting 3700 mAh battery to power through the hours.
  • Put your style on display
    With a customizable 1.9-inch cover screen, you get yet another canvas to play with. Change it up as much as you want using your videos, photos or your own AR emoji to personalize the clock face. With this much control, you can easily update it with your mood, the weather or to match your outfits.
  • Glance, act and go
    Your daily digital regulars, right on the cover screen. Control your phone with taps and swipes on the 1.9-inch cover screen. Access quick settings, reply to texts and add widgets to keep apps at your fingertips - no main screen necessary.
Samsung Galaxy Z Flip4 - pink gold - 5G smartphone - 128 GB - GSM
5G smartphone
Manufacturer Model Number
SM-F721B
Display
OLED display - 2640 x 1080 pixels - 6.7" - 425 ppi - (120 Hz) - Dynamic AMOLED 2X - HDR - Samsung Ultra Thin Glass - inward - foldable
Display (2nd)
OLED display - colour - 1.9"
Display (Unfolded)
6.7 in - 2640 x 1080 pixels
3.18 GHz (8-core)
RAM 8 GB / 128 GB
Operating System
Android 12 with One UI
Main Camera
12 Megapixel - wide-angle lens - f/1.8 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
10 Megapixel f/2.4 - focus free
Service Provider
Not specified
Folder (flip) - touch screen, dual screen
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Wi-Fi 6, Bluetooth
Security Devices
Face recognition, fingerprint reader (side)
Connectors
USB-C
Talk Time
Up to 2040 minutes
Wireless Charging Standards
WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare, Reverse wireless charging
Protection
Water-resistant
Pink gold
71.9 mm x 6.9 mm x 165.2 mm
187 g
1.151 W/kg (head) , 1.198 W/kg (body) , 2.75 W/kg (limb)
Smartphone
SM-F721B
Protection
Water-resistant
71.9 mm
6.9 mm
165.2 mm
187 g
Dimensions Details
Unfolded - 71.9 mm x 6.9 mm x 165.2 mm , Folded - 71.9 mm x 17.1 mm x 84.9 mm
Body Colour
Pink gold
Body Material
Corning Gorilla Glass Victus, Armour Aluminium frame
SAR Value
2.75 W/kg (limb), 1.151 W/kg (head), 1.198 W/kg (body)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 12
User Interface
One UI
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, LAA, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n75, n77, n78, n40, n25, n12
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.2 LE
Phone Features
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
Security Devices
Additional Features
MIMO technology, Samsung KNOX, High AOP Mic, Bixby Vision, Secure Folder function, TalkBack, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung Smart Switch, Flex mode
Media Player
Supported Digital Audio Standards
WAV, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound
Clock Speed
3.18 GHz
Processor Core Qty
8-core
RAM
8 GB
Internal Memory Capacity
128 GB
User Memory
99.8 GB
Memory Interface
UFS 3.1
Front Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.4
Focus Adjustment
Focus free
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Field of View (FoV)
83 degree(s)
Pixel Size
1.8 µm
Focus Adjustment
Automatic
Digital Zoom
10x
Self-Timer Delay
Special Effects
HDR, Grid Line
Camera Modes
Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Quick Shot, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Portrait, Night, Mountain, Filter mode, Single Take, Pro Video, Portrait video, Director's View
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Hyperlapse 4K video support at 30 fps, Super Steady 1080p video support at 30 fps
Playback zoom, Motion photo, QR-code scanner, RAW image capture, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, Dual Pixel Autofocus technology, AR sticker, Scene Optimiser, Flaw detection, Shot suggestions, AR Emoji, HDR10+ recording, Super steady, HEIF image capture, AR Doodle, Microphone Control, HEVC (High Efficiency Video coding), Dual preview, Auto framing, Corning Gorilla Glass DX (protective lens glass), Auto FPS, AR Emoji Studio, Deco PIC, FlexCam
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Pixel Size
1.12 µm
Display
OLED display
Dynamic AMOLED 2X
Diagonal Size
6.7"
Display Resolution
2640 x 1080 pixels
Display Format
Full HD+
Foldable
Design
Inward folding
Pixel Density
425 ppi
Colour Depth
16.7 million colours
HDR
HDR Technology
HDR10+
Refresh Rate
120 Hz
Protection
AOD(Always On Display), Video Wallpaper
Display (2nd)
Diagonal Size
1.9"
Display Resolution
512 x 260 pixels
Colour Depth
Display (Unfolded)
Diagonal Size
6.7 in
Display Resolution
2640 x 1080 pixels
Connector Type
USB Type-C - 24 pin USB-C
3700 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging
Wireless Charging
Talk Time
2040 minutes
Run Time Details
Talk (4G): up to 2040 min , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (wireless video): up to 19 hrs , Playback (wireless audio): up to 56 hrs
VDE, IPX8
SIM card removal tool, USB-C cable
Max Depth of Water Resistance
1.5 m
