Fits all your fits
The era of planning looks around your phone is over. Small but mighty when folded, Galaxy Z Flip4 is a compact full-sized smartphone, and just the right size to slip in a pocket when it's time to slay.
Holds up from flex to flat
The 6.7-inch display unfolds a beautiful view thanks to Ultra Thin Glass. Advanced durability makes it stronger than ever — staying tough through up to 200,000 folds.
Flippin' strong
From the inside out, Galaxy Z Flip4 is made to be durable. These are our toughest foldables ever with exclusive Corning® Gorilla® Glass Victus®+. And the hinge is protected by Armor Aluminum — our toughest aluminum frame.
Still unafraid of water
Water you worried about? These are the world’s first water-resistant foldable smartphones. It can hang out in 1.5 meters of water for up to 30 minutes without breaking a sweat.
MULTI-CAMERA SYSTEM
Live your best nightlife
The night just got brighter with Nightography on the Rear Camera. Details are brought to light even in the dark with bigger pixels on the Wide Camera. Say cheese!
Nightography isn't just for stills — it's also got video skills. When the action gets going, recordings stay smooth, not shaky, with enhanced OIS and VDIS. Powerful processing allows Super Night Solution to minimise noise so clips of the crew stay clear well into the night.
12MP Ultra Wide Camera
12MP Wide Camera
10MP Selfie Camera
Go ahead, flex on them
Introducing FlexCam, a versatile, hands-free camera experience. Take advantage of your phone’s agile angles to capture group shots, selfies and videos from mind-blowing perspectives and impressive true-to-life detail — even in your go-to social apps.
Enter your self-portrait era
Take selfies with the Rear Camera while the Cover Screen gives you a real-time preview. Check yourself from afar with a full-screen view finder, or tap to see the original ratio to make sure everyone is in frame. And with new software upgrades, Quick Shot is ready for even more action at all the angles between folded and FlexCam.
Power to the pocket
With this much juice, you can let every call go into overtime. An upgraded 4nm processor works with the long-lasting 3700mAh (typical) battery to power through the hours.
When it's low, plug in for Super Fast Charging or bypass the cord with Fast Wireless Charging 2.0. With all that power to spare, you can even share a charge with your friend or your earbuds with Wireless PowerShare.
Put your style on display
With a customisable 1.9-inch Cover Screen, you get yet another canvas to play with. Change it up as much as you want using your videos, photos or your own AR emoji to personalise the clock face. With this much control, you can easily update it with your mood, the weather or to match your outfits.
Fits all your fits
The era of planning looks around your phone is over. Small but mighty when folded, Galaxy Z Flip4 is a compact full-sized smartphone, and just the right size to slip in a pocket when it's time to slay. -
The 6.7-inch display unfolds a beautiful view thanks to ultra thin Glass. Advanced durability makes it stronger than ever - staying tough through up to 200,000 folds. -
Flippin' strong
From the inside out, Galaxy Z Flip4 is made to be durable. These are their toughest foldables ever with exclusive Corning Gorilla Glass Victus+. And the hinge is protected by Armor Aluminum - their toughest aluminum frame. -
Water you worried about. These are the water-resistant foldable smartphones. It can hang out in 1.5 meters of water for up to 30 minutes without breaking a sweat. -
The night just got brighter with Nightography on the Rear Camera. Details are brought to light even in the dark with bigger pixels on the Wide Camera. Nightography isn't just for stills - it's also got video skills. When the action gets going, recordings stay smooth, not shaky, with enhanced OIS and VDIS. Powerful processing allows Super Night Solution to minimize noise so clips of the crew stay clear well into the night. -
Introducing FlexCam, a versatile, hands-free camera experience. Take advantage of your phone's agile angles to capture group shots, selfies and videos from mind-blowing perspectives and impressive true-to-life detail - even in your go-to social apps. -
Take selfies with the rear camera while the cover screen gives you a real-time preview. Check yourself from afar with a full-screen view finder, or tap to see the original ratio to make sure everyone is in frame. And with software upgrades, Quick Shot is ready for even more action at all the angles between folded and FlexCam. -
Give your feed a glow-up
Content creation just got easier. FlexCam holds its own to broaden your directorial POV, letting you film yourself, your friends or your actors from fresh angles. And once your movie is premiere-ready, it's simple to upload right to your social media for well-deserved accolades. -
Power to the pocket
With this much juice, you can let every call go into overtime. An upgraded 4 nm processor works with the long-lasting 3700 mAh battery to power through the hours. -
With a customizable 1.9-inch cover screen, you get yet another canvas to play with. Change it up as much as you want using your videos, photos or your own AR emoji to personalize the clock face. With this much control, you can easily update it with your mood, the weather or to match your outfits. -
Glance, act and go
Your daily digital regulars, right on the cover screen. Control your phone with taps and swipes on the 1.9-inch cover screen. Access quick settings, reply to texts and add widgets to keep apps at your fingertips - no main screen necessary.
- Samsung Galaxy Z Flip4 - bora purple - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-F721B
- Display
- OLED display - 2640 x 1080 pixels - 6.7" - 425 ppi - (120 Hz) - Dynamic AMOLED 2X - HDR - Samsung Ultra Thin Glass - inward - foldable
- Display (2nd)
- OLED display - colour - 1.9"
- Display (Unfolded)
- 6.7 in - 2640 x 1080 pixels
- Processor
- 3.18 GHz (8-core)
- Memory
- RAM 8 GB / Internal Memory 128 GB
- Operating System
- Android 12 with One UI
- Main Camera
- 12 Megapixel - wide-angle lens - f/1.8 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Front Camera
- 10 Megapixel f/2.4 - focus free
- Service Provider
- Not specified
- Form Factor
- Folder (flip) - touch screen, dual screen
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, Bluetooth
- Security Devices
- Face recognition, fingerprint reader (side)
- Connectors
- USB-C
- Talk Time
- Up to 2040 minutes
- Wireless Charging Standards
- WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare, Reverse wireless charging
- Protection
- Water-resistant
- Bora purple
- 71.9 mm x 6.9 mm x 165.2 mm
- 187 g
- Repairability Index
- 7.6 (out of 10)
- Specific Absorption Rate (SAR)
- 1.151 W/kg (head) , 1.198 W/kg (body) , 2.75 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-F721B
- Form Factor
- Protection
- Water-resistant
- 71.9 mm
- 6.9 mm
- 165.2 mm
- 187 g
- Dimensions Details
- Unfolded - 71.9 mm x 6.9 mm x 165.2 mm , Folded - 71.9 mm x 17.1 mm x 84.9 mm
- Body Colour
- Bora purple
- Body Material
- Corning Gorilla Glass Victus, Armour Aluminium frame
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 12
- User Interface
- One UI
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, LAA, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n75, n77, n78, n40, n25, n12
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12
- NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.2 LE
Phone Features
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
- Security Devices
- Additional Features
- MIMO technology, Samsung KNOX, High AOP Mic, Bixby Vision, Secure Folder function, TalkBack, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung Smart Switch, Flex mode
Media Player
- Supported Digital Audio Standards
- WAV, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound
- Clock Speed
- 3.18 GHz
- Processor Core Qty
- 8-core
- RAM
- 8 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 99.8 GB
- Memory Interface
- UFS 3.1
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.4
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- 83 degree(s)
- Pixel Size
- 1.8 µm
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Self-Timer Delay
- Special Effects
- HDR, Grid Line
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Quick Shot, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Portrait, Night, Mountain, Filter mode, Single Take, Pro Video, Portrait video, Director's View
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Hyperlapse 4K video support at 30 fps, Super Steady 1080p video support at 30 fps
- Playback zoom, Motion photo, QR-code scanner, RAW image capture, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, Dual Pixel Autofocus technology, AR sticker, Scene Optimiser, Flaw detection, Shot suggestions, AR Emoji, HDR10+ recording, Super steady, HEIF image capture, AR Doodle, Microphone Control, HEVC (High Efficiency Video coding), Dual preview, Auto framing, Corning Gorilla Glass DX (protective lens glass), Auto FPS, AR Emoji Studio, Deco PIC, FlexCam
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1.12 µm
Display
- OLED display
- Technology
- Dynamic AMOLED 2X
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- Full HD+
- Foldable
- Design
- Inward folding
- Pixel Density
- 425 ppi
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10+
- Refresh Rate
- 120 Hz
- Protection
- AOD(Always On Display), Video Wallpaper
Display (2nd)
- Diagonal Size
- 1.9"
- 512 x 260 pixels
- Colour Depth
Display (Unfolded)
- Diagonal Size
- 6.7 in
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 3700 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging
- Wireless Charging
- Talk Time
- 2040 minutes
- Run Time Details
- Talk (4G): up to 2040 min , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (wireless video): up to 19 hrs , Playback (wireless audio): up to 56 hrs
- VDE, IPX8
- Included Accessories
- SIM card removal tool, USB-C cable
- Limited warranty - 2 years
Sustainability Information
- 7.6 (out of 10)
- Max Depth of Water Resistance
- 1.5 m
