Meet the stylish smartwatch that looks and feels like a timeless timepiece. Bringing back the rotating bezel to add a tactile touch alongside the larger watch screen yet.
Bigger screen with a rotating bezel
Look your great and see even more at a glance with a 30% larger screen. Plus a slimmer, rotating bezel that you can turn to easily access apps, stats and more. All packed into a sleek silhouette with the elevated style of a classic watch. -
Sapphire crystal: clearly durable
Expertly crafted with Sapphire crystal glass to keep your screen looking great while protecting it from bumps and scratches. And this fashion piece isn't afraid to get a little dirty with IP68 water and dust resistance. -
A stylish spin on an iconic look
Inspired by the iconic designs of vintage diving watches, the slim spinning bezel makes navigating apps easy and accurate with a simple turn of the dial. Its timeless design is sure to click with your impeccable sense of style, too. -
Change out your look in a snap
From boardroom to weight room, own your look with a band for any occasion - even easier to swap with one simple click. Then accent your look with digital faces to complete your outfit. -
Track your period on your wrist
Your Galaxy Watch6 Classic uses skin temperature readings, measured while you sleep, to help track your monthly period, ovulation cycle and fertility windows. All collected data is encrypted and stored securely on your own device, giving you control over your information. -
Heart health made simple
Get ahead of your heart health with heart monitoring. Your Galaxy Watch6 Classic periodically scans your heart rate to inform you when it's detected an irregular rhythm. -
Keep your body in balance
Stay in the know about your body with the advanced BIA sensor. Get readings on body fat, skeletal muscle, body water, Body Mass Index (BMI) and more - so you have all the stats to stay on track. -
Detects a fall and sends for help
Your Galaxy Watch6 Classic is on standby in case of an emergency. Fall Detection will catch when you've suffered a fall and send an SOS notification to your emergency contact if you need help. -
Keep fitness goals on track
Work out to your full potential with useful performance insights on duration, distance, calories burned and more. Galaxy Watch6 Classic automatically tracks popular activities, like running and swimming, and makes it simple to manually track over 90 additional exercises. -
Target your ideal intensity
Make every run count with personalized heart rate zones that let you train at different intensities to achieve your goals. -
Stay connected on the go
Have the power to call, text, play music and find your phone all from your wrist. Your Galaxy Watch6 Classic connects with your other Galaxy devices seamlessly so you can do more from anywhere. -
Snap a photo with your watch
Frame and snap the shot you want. Simply open up the camera app on your Watch and pinch the screen or twist the bezel to zoom in and out. Then pose, set a timer or tap to snap a shot. -
Go phone-free with LTE
Get out into the world without having to carry your phone with you. Call and text your friends, jam out to your favorite playlist and more with LTE connectivity. -
Bring more and carry less
Conveniently carry your payment cards, digital IDs, boarding passes and more in your Galaxy Watch6 Classic.
- Samsung Galaxy Watch6 Classic smart watch with band - black - 16 GB - black
- Product Type
- Smart watch
- Manufacturer Model Number
- SM-R950
- Tracking Data
- Distance, calories burned, activity, sleep activity, heart rate, steps taken, skin temperature, body composition, ECG, REM phases, sleep quality score
- Connectivity
- NFC, Wi-Fi, Bluetooth
- Navigation
- GPS/GLONASS/Galileo/BeiDou receiver
- Display
- Super AMOLED - 1.3" - 432 x 432 pixels - 330 ppi - always-on display
- Processor
- Samsung Exynos W930
- Storage
- 16 GB
- Operating System
- Wear OS by Samsung
- Case
- Round - 43 mm - stainless steel
- Band
- Black - band - hybrid eco-leather - size: S/M - changeable
- Input
- Touch screen, rotating bezel, push buttons
- Notifications
- Calendar, SMS, social apps, incoming calls, irregular rhythm
- Camera remote control, find phone function, Emergency SOS, music playback control, Body composition measurement tool, Sleep Coaching, fast charge
- Supported Host Device OS
- Android
- Battery
- Rechargeable 300 mAh - WPC
- Battery Run Time
- Up to 40 hours
- Black
- 42.5 mm x 10.9 mm x 42.5 mm
- 52 g
- Specific Absorption Rate (SAR)
- 0.177 W/kg (head) , 0.288 W/kg (limb)
- Product Type
- Smart watch
- SM-R950
- Android 10 or later
- Notifications
- Navigation
- Tracking Data
- Modes
- 90+ exercise modes
- Digital Player
- MP3, WAV, AAC, AMR, M4A, OGG, 3GA, AWB, OGA
- Audio Input
- Microphone
- Audio Output
- Speaker
- Operating System
- Wearing Style
- Watch style
- Feedback Type
- Audio alert, vibration alert, visual interface
- Clock Display
- Set Goals
- Black
- Sensors
- Accelerometer, barometer, gyro sensor, hall sensor, geomagnetic sensor, optical heart sensor, electrical heart sensor, light sensor, infrared temperature sensor, bioelectrical impedance analysis sensor
Storage
- Capacity
- 16 GB
- User Memory
- 7.1 GB
Display
- Super AMOLED - colour
- Resolution
- 432 x 432 pixels
- Diagonal Size
- 1.3"
- Pixel Density
- 330 ppi
- Always On Display (AOD)
- Colour Depth
- 24-bit (16.7 million colours)
- Wireless Interface
- NFC, IEEE 802.11a/b/g/n, Bluetooth 5.3
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Input Device
- Touch sensitive screen, rotating bezel, push buttons
CPU
- Manufacturer
- Samsung
- Exynos W930
- Clock Speed
- 1.4 GHz
RAM
- Size
- 2 GB
- Rechargeable Battery
- Capacity
- 300 mAh
- Wireless Charging
- Wireless Charging Standards
- WPC
- Run Time (Up To)
- 40 hours
- Run Time Details
- Typical usage (AOD Off) - up to 40 hour(s) , Typical usage (AOD On) - up to 30 hour(s)
Smart Watch Case
- Case Shape
- Round
- Case Size
- 43 mm
- Crystal Type
- Sapphire crystal
Band
- Name
- Band
- Changeable
- Size
- S/M
- Clasp Type
- Buckle
- Material
- Hybrid eco-leather
- Black
- 42.5 mm
- 10.9 mm
- 42.5 mm
- 52 g
- Preloaded Software
- Google Maps, Samsung Wallet
- Vibrating Alert
- Body Material
- Stainless steel
- Protection
- Water-resistant
- IP68, MIL-STD-810H
- Max Depth of Water Resistance
- 50 m
