The Samsung Galaxy Watch Active 2 is designed to help you learn more so you can achieve more. It goes beyond tracking steps and calories to offer actionable insights on everything from your running style to your heart rate.
Better insights to reach your fitness goals
Get more out of every movement with the Galaxy Watch Active 2. Its advanced sensors keep your pace on a jog, helping you better achieve your goals. It also automatically tracks your popular activities, from cycling to swimming, and lets you manually track other exercises. -
Comfortably sleek
With a thin, light design, Galaxy Watch Active 2 is fit for any time and for any occasion, from working out to sleeping in. The AMOLED display is all screen from edge to edge. The touch bezel allows you to easily navigate with a quick turn, touch or tap. -
Keep your beat
You can see if your heart rate is where you want it with Galaxy Watch Active 2. Get automatically alerted if your watch detects a high or a low heart rate.
 - Samsung Galaxy Watch Active 2 - pink gold aluminium - smart watch with band - pink gold - 4 GB
- Product Type
 - Smart watch
- Manufacturer Model Number
 - SM-R820
- Tracking Data
 - Distance, calories burned, activity, sleep activity, heart rate, steps taken, stress level
- Connectivity
 - Wi-Fi, NFC, Bluetooth
- Navigation
 - A-GPS/GPS/GLONASS/BeiDou receiver
- Display
 - Super AMOLED - 1.4" - 360 x 360 pixels - Corning Gorilla Glass DX+ - always-on display
- Processor
 - Samsung Exynos 9110
- Storage
 - 4 GB
- Operating System
 - Tizen OS
- Case
 - Round - 44 mm - aluminium
- Band
 - Pink gold - band - fluoroelastomer - changeable
- Input
 - Touch screen
- Notifications
 - SMS, social apps, incoming calls
 - Music remote handling, camera remote control, automatic exercise recognition, Wireless PowerShare support
- Supported Host Device OS
 - iOS, Android
- Battery
 - Rechargeable 340 mAh - WPC
 - 44 mm x 10.9 mm x 44 mm
 - 30 g
- Product Type
 - Smart watch
 - SM-R820
 - iOS 9 or later, Android 5.0 (Lollipop) or later
- Notifications
- Navigation
- Tracking Data
- Audio Input
 - Microphone
- Operating System
 - Tizen OS
- Wearing Style
 - Watch style
- Feedback Type
 - Vibration alert, visual interface, rotating bezel
- Clock Display
- Set Goals
- Sensors
 - Accelerometer, ambient light sensor, barometer, gyro sensor, optical heart sensor, electrical heart sensor
Storage
- Capacity
 - 4 GB
Display
 - Super AMOLED - colour
- Resolution
 - 360 x 360 pixels
- Diagonal Size
 - 1.4"
- Protection
 - Corning Gorilla Glass DX+ (scratch resistant glass)
- Always On Display (AOD)
- Wireless Interface
 - IEEE 802.11b/g/n, NFC, Bluetooth 5.0
Input Device
 - Touch sensitive screen
CPU
- Manufacturer
 - Samsung
 - Exynos 9110
- Clock Speed
 - 1.15 GHz
RAM
- Size
 - 768 MB
- Rechargeable Battery
- Capacity
 - 340 mAh
- Wireless Charging
- Wireless Charging Standards
 - WPC
Smart Watch Case
- Case Shape
 - Round
- Case Size
 - 44 mm
- Case Details
 - Pink gold aluminium
Band
- Name
 - Band
- Changeable
- Clasp Type
 - Buckle
 - 20 mm
- Material
 - Fluoroelastomer
 - Pink gold
 - 44 mm
 - 10.9 mm
 - 44 mm
 - 30 g
- Vibrating Alert
- Body Material
 - Aluminium
- Protection
 - Waterproof
 - MIL-STD 810G, IP68
- Included Accessories
 - Wireless charging dock
- Max Depth of Water Resistance
 - 50 m
