Samsung Galaxy Tab S8 Ultra 5G 128GB - Grey
Quicklinx: GPLFWS00 Mfr#: SM-X906BZAAEUA
  • Android
More than just space. Built to take fun on the go. The Galaxy Tab S8 Ultra is designed so you can create like a pro. Shoot with the ultra wide front camera and edit on the large screen.
  • S Pen snaps right into place to charge
    The S Pen comes included and magnetically snaps to the back of Galaxy Tab S8 Ultra to charge. Write, sketch, doodle or draw all your wildest ideas into reality with S Pen with ultra-low latency. A thousand tools in one, the S Pen gives you impressive levels of control.
  • It's tough, so creativity comes easy
    The Armor Aluminum casing guards against all sorts of bumps and drops. The Galaxy Tab S8 Ultra balances impressive durability with a super lightweight, slim design.
  • Ready for anything noteworthy
    Samsung Notes is the quickest way to jot down all your brilliant million dollar ideas in an instant. It can do it all: memos, sketches, drawings - it can even turn handwriting into text to keep your ideas flowing.
  • Be the center of attention, wherever you are
    The Dual Front Camera (Ultra Wide + Wide) boasts an impressive field of view that provides optimal 4K video recording.
  • Auto Framing
    Auto Framing gives the spotlight the speaker deserves. So you can record a dance lesson and the camera will automatically zoom in to keep focus on you and your moves as you give instruction. The spotlight continues on video calls. When new friends join the call, the Dual Front Camera (Ultra Wide + Wide) even knows to automatically zoom out to include them, making it feel like you are talking to them in person.
  • Divide your screen, conquer your day
    Size. Position. And number of windows. You're in charge with Multi Window. That means you can research decor inspirations, sketch out architectural plans, and video chat with your friend - all at once.
  • Lightweight but packed with fun
    Stream all your favorite shows or movies from the comfort of your - well, wherever you want really. The vibrant display and enhanced bass create an immersive experience.
  • Ditch your gaming chair, keep the performance
    Get console quality performance on the massive screen anywhere you want. And with the 120Hz display, everything runs smoothly for you to be on the leaderboard in no time.
    Experience lightning fast speeds on your various action-packed games and editing software with the 4nm mobile processor - the Snapdragon 8 Gen 1 Mobile Platform.
  • Fast connect to productivity
    Galaxy Tab S8 Series has Wi-Fi 6E. You've got an incredibly fast Wi-Fi connection to boost your productivity. Share files between your Galaxy devices with speeds of up to 2.4Gbps.
Samsung Galaxy Tab S8 Ultra - tablet - Android - 128 GB - 14.6" - 3G, 4G, 5G
Tablet
Operating System
Android
Display
14.6" Super AMOLED - 2960 x 1848 - Multi-Touch
Qualcomm Snapdragon 8 Gen 1 SM8450 (8-core)
Processor Clock Speed
2.99 GHz
Storage
128 GB
RAM
8 GB
User Available Memory
Flash: 101 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Cellular Technology
3G, 4G, 5G
Cellular Protocols
GSM, UMTS, FDD LTE, TDD LTE
Wireless Connectivity
Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
Rear Camera
13 Megapixel focus: automatic
Second Rear Camera
6 Megapixel
Front Camera
12 Megapixel
Second Front Camera
12 Megapixel
Navigation System
GPS/GLONASS/Galileo/BeiDou/QZSS
Security Devices
Fingerprint reader
Battery Run Time
Up to 14 hours
20.86 cm x 0.55 cm x 32.64 cm
728 g
Graphite
0.689 W/kg (body) , 0.689 W/kg (limb)
Tablet
Operating System
Android
Display
14.6" Super AMOLED
Resolution
2960 x 1848
Colour Depth
16 million colours
Touchscreen
Multi-Touch
120 Hz refresh rate
2.99 GHz
Number of Cores
8-core
Storage
128 GB
RAM
8 GB
Flash: 101 GB
Max Supported Capacity
1 TB
Communications
Cellular Technology
3G, 4G, 5G
Cellular Protocols
Band
GSM 850/900/1800/1900 / UMTS 850/900/AWS/1900/2100 / LTE B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B20/B25/B26/B28/B32/B66/B38/B40/B41 / 5G N1/N3/N5/N7/N8/N20/N28/N66/N38/N40/N41/N77/N78
Security Protocols & Features
Wi-Fi Direct
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
Sensor Resolution
13 Megapixel
Focus Adjustment
Automatic
Light Source
Flash
Video Resolutions
3840 x 2160 (4K) at 30 fps
Second Rear Camera
Sensor Resolution
6 Megapixel
Front Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Video Resolutions
3840 x 2160 (4K)
Auto framing
Second Front Camera
Sensor Resolution
12 Megapixel
Wide-angle lens
Navigation System
Receiver
Multimedia
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID, Dolby Atmos
Supported Digital Video Standards
MPEG-4, AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM
Audio
3 microphones, four speakers
Input Device
S Pen
Security Devices
Fingerprint reader
Software
Preloaded Software
Samsung Smart Switch
Expansion and Connectivity
Expansion Slots
1 x microSDXC
1 x USB-C 3.2 Gen 1
11200 mAh
Run Time
Up to 14 hours
Talk Time
3780 min
Run Time Details
Web browsing over Wi-Fi: up to 8 hour(s) , Video playback: up to 14 hour(s) , Audio playback: up to 148 hour(s) , Web browsing over 4G: up to 8 hour(s) , Talk time: up to 63 hour(s)
Graphite
Case Material
Reinforced aluminium
Sensors
Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
MIMO technology, Drop Protection, tuned by AKG speakers, Samsung DeX, 4nm processor, 45W ultra fast charging
20.86 cm
0.55 cm
32.64 cm
728 g
