Grade A Returned Device
Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
- Can be used on any network
- minimum 12 months manufacturer warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Sealed packaging
Galaxy Tab S8
The power to take you anywhere
Built to take fun on the go. The 11" LCD screen has a ton to offer. From a huge battery to a 12MP Ultra Wide Front Camera. And of course, the S Pen is included.
S Pen
No matter which tablet size you select, the brand new S Pen comes included and magnetically snaps to the back of Galaxy Tab S8 Series to charge.
Write, sketch, doodle or draw all your wildest ideas into reality with the S Pen ultra-low latency. A thousand tools in one, the new S Pen gives you impressive levels of control.
5G keeps you streaming on the go
HyperFast 5G delivers the power to keep you streaming whatever you want — music, movies or content. Stream wherever — even outdoors and on the go.
S Pen snaps right into place to charge
The S Pen comes included and magnetically snaps to the back of Galaxy Tab S8 to charge. Write, sketch, doodle or draw all your wildest ideas into reality with S Pen with ultra-low latency. A thousand tools in one, the S Pen gives you impressive levels of control. -
It's tough, so creativity comes easy
The Armor Aluminum casing guards against all sorts of bumps and drops. The Galaxy Tab S8 balances impressive durability with a super lightweight, slim design. -
Ready for anything noteworthy
Samsung Notes is the quickest way to jot down all your brilliant million dollar ideas in an instant. It can do it all: memos, sketches, drawings - it can even turn handwriting into text to keep your ideas flowing. -
Be the center of attention, wherever you are
The Dual Front Camera (Ultra Wide + Wide) boasts an impressive field of view that provides optimal 4K video recording. -
Auto Framing
Auto Framing gives the spotlight the speaker deserves. So you can record a dance lesson and the camera will automatically zoom in to keep focus on you and your moves as you give instruction. The spotlight continues on video calls. When new friends join the call, the Dual Front Camera (Ultra Wide + Wide) even knows to automatically zoom out to include them, making it feel like you are talking to them in person. -
Divide your screen, conquer your day
Size. Position. And number of windows. You're in charge with Multi Window. That means you can research decor inspirations, sketch out architectural plans, and video chat with your friend - all at once. -
Lightweight but packed with fun
Stream all your favorite shows or movies from the comfort of your - well, wherever you want really. The vibrant display and enhanced bass create an immersive experience. -
Ditch your gaming chair, keep the performance
Get console quality performance on the massive screen anywhere you want. And with the 120Hz display, everything runs smoothly for you to be on the leaderboard in no time. -
Ready for anything
Experience lightning fast speeds on your various action-packed games and editing software with the 4nm mobile processor - the Snapdragon 8 Gen 1 Mobile Platform. -
Fast connect to productivity
Galaxy Tab S8 Series has Wi-Fi 6E. You've got an incredibly fast Wi-Fi connection to boost your productivity. Share files between your Galaxy devices with speeds of up to 2.4Gbps.
- Samsung Galaxy Tab S8 - tablet - Android - 128 GB - 11" - 3G, 4G, 5G
- Product Type
- Tablet
- Operating System
- Android
- Display
- 11" TFT - 2560 x 1600 - Multi-Touch
- Processor
- Qualcomm Snapdragon 8 Gen 1 SM8450 (8-core)
- Processor Clock Speed
- 2.99 GHz
- Storage
- 128 GB
- RAM
- 8 GB
- User Available Memory
- Flash: 100.9 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Cellular Technology
- 3G, 4G, 5G
- Cellular Protocols
- GSM, UMTS, FDD LTE, TDD LTE
- Wireless Connectivity
- Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
- Rear Camera
- 13 Megapixel focus: automatic
- Second Rear Camera
- 6 Megapixel
- Front Camera
- 12 Megapixel
- Navigation System
- GPS/GLONASS/Galileo/BeiDou/QZSS
- Security Devices
- Fingerprint reader
- Battery Run Time
- Up to 15 hours
- 16.5 cm x 0.63 cm x 25.38 cm
- 507 g
- Graphite
- SAR
- 0.869 W/kg (body), 0.869 W/kg (limb)
- Product Type
- Tablet
- Operating System
- Android
Display
- 11" TFT
- Resolution
- 2560 x 1600
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- 120 Hz refresh rate
- Processor
- 2.99 GHz
- Number of Cores
- 8-core
- Storage
- 128 GB
- RAM
- 8 GB
- Flash: 100.9 GB
- Max Supported Capacity
- 1 TB
Communications
- 3G, 4G, 5G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/AWS/1900/2100 / LTE B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B20/B25/B26/B28/B32/B66/B38/B40/B41 / 5G N1/N3/N5/N7/N8/N20/N28/N66/N38/N40/N41/N77/N78
- Wi-Fi Direct
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
- Sensor Resolution
- 13 Megapixel
- Focus Adjustment
- Automatic
- Light Source
- Flash
- Video Resolutions
- 3840 x 2160 (4K UHD) at 30 fps
Second Rear Camera
- Sensor Resolution
- 6 Megapixel
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Auto framing
Navigation System
- Receiver
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MPEG-4, AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM
- Audio
- 3 microphones, speaker
Input Device
- S Pen
- Security Devices
Software
- Preloaded Software
- Samsung Smart Switch
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC
- 1 x USB-C 3.2 Gen 1
- Capacity
- 8000 mAh
- Run Time
- Up to 15 hours
- Talk Time
- 2880 min
- Run Time Details
- Web browsing over Wi-Fi: up to 15 hour(s) , Video playback: up to 15 hour(s) , Audio playback: up to 110 hour(s) , Web browsing over 4G: up to 15 hour(s) , Talk time: up to 48 hour(s)
- Graphite
- Case Material
- Reinforced aluminium
- Sensors
- Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
- MIMO technology, Drop Protection, Samsung DeX, 4nm processor, 45W ultra fast charging
- SAR Value
- 16.5 cm
- 0.63 cm
- 25.38 cm
- 507 g
