Samsung Galaxy Tab S6 LTE 128GB - Rose blush
Quicklinx: FCHVWS00 Mfr#: SM-T865NZNABTU
Operating System: Android 9.0 (Pie)
Processor: Snapdragon 855
Screen Size: 10.5in
RAM: 6GB
Capacity: 128GB
47 in stock
£574.17 ex VAT
£689.00 inc VAT
Maximize your potential and turn challenge into opportunity with a tablet that prepares you for whatever life throws your way.
  • Multiply the things you do
    Take full advantage of apps that work in split view on the Galaxy Tab S6 in multi window. Split the view with just a click to use apps like Gallery, Email and Samsung Notes simultaneously that share the screen at the size you choose so you can work the way you want.
  • A full film studio from step one to done
    Now get a dual camera for the first time in a Galaxy Tab with rear-facing 13 MP and 5 MP cameras. Use Ultra-Wide angle and smart AI to shoot like a pro and optimize the tone of your shots.
  • Next-generation neural processing power
    Galaxy Tab S6 packs processing power that brings not just next-generation specs for lag-free gaming but a whole lot more. Accelerated neural network processing accelerates the efficiency of AI applications, while Bixby Vision adds improved deep learning in scene recognition.
  • Tap the screen to instantly unlock
    Galaxy Tab S6 incorporates an onscreen optical fingerprint scanner for maximum convenience and security. Just touch your finger to the screen to unlock your tablet - a single press on the front screen is all you need, and no password to remember.
  • Finally a reason to put down your phone
    Stay in touch when your phone is out of reach. Galaxy Tab S6 seamlessly syncs your Galaxy smartphone, so you never miss a call when it comes in. It also allows you to reply to urgent text messages, so you're never out of the loop.
  • Seamlessly connect your Galaxy Tab S6
    Sync up to an ecosystem that lets your devices work seamlessly together right out of the box. Turn your Galaxy Tab S6 into a control hub for your other devices and take your content with you.
  • Pick up your best match
    Galaxy Tab S6 packs all this into a device this small so your potential isn't weighed down.
  • Kick back with stunning visuals and sound
    The nearly bezel-less sAMOLED display provides 10.5 inches of 2560 x 1600 WQXGA screen at 287 ppi and a 16:10 screen ratio that's ideal for hours of viewing and reading. Draw yourself into your content with four speakers that give immersive audio depth in a body this slim.
Samsung Galaxy Tab S6 - tablet - Android 9.0 (Pie) - 128 GB - 10.5" - 3G, 4G
Tablet
Operating System
Android 9.0 (Pie)
Display
10.5" Super AMOLED - 2560 x 1600 (287 ppi) - Multi-Touch
Qualcomm Snapdragon 855 (8-core)
Processor Clock Speed
2.8 GHz
Storage
128 GB
RAM
6 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Cellular Technology
3G, 4G
Cellular Protocols
GSM, UMTS, LTE, TDD LTE
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 5.0
Camera
13 Megapixel (ultra wide rear), 5 Megapixel (wide rear), 8 Megapixel (front)
HD Video Recording
4K
Navigation System
GPS/GLONASS/Galileo/BeiDou
Security Devices
Fingerprint reader, face recognition
Battery Run Time
Up to 15 hours
15.95 cm x 0.57 cm x 24.45 cm
420 g
Rose blush
Tablet
Operating System
Android 9.0 (Pie)
Display
10.5" Super AMOLED
Resolution
Colour Depth
16 million colours
Touchscreen
Multi-Touch
Image Aspect Ratio
16:10
Smart View Technology
2.8 GHz
Number of Cores
8-core
Storage
128 GB
RAM
6 GB
Max Supported Capacity
1 TB
Communications
Cellular Technology
3G, 4G
Cellular Protocols
Band
GSM 850/900/1800/1900 / UMTS 800/850/900/AWS/1900/2100 / LTE 700/800/850/900/AWS/AWS-3/1800/1900/2100/2300/2500/2600
Security Protocols & Features
Wi-Fi Direct, ANT+
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Camera
Resolution (MP)
Lens Aperture
F/2.2 (ultra wide) / f/2.0 (wide) (rear) / f/2.0 (front)
Focus Adjustment
Automatic
Video Resolutions
3840 x 2160
Frame Rate
30 frames per second
HD Video Recording
4K
Live focus
Navigation System
Receiver
Multimedia
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
AVI, WMV, MKV, 3GP, ASF, FLV, 3G2, M4V, WEBM, MP4
Audio
Microphone, four speakers
Input Device
Security Devices
Software
Preloaded Software
Samsung KNOX
Expansion and Connectivity
Expansion Slots
1 x microSD , 1 x Nano-SIM card
1 x USB-C , 1 x POGO pin
7040 mAh
Run Time
Up to 15 hours
Talk Time
43 hours
Run Time Details
Web browsing over 4G: up to 9 hour(s) , Web browsing over Wi-Fi: up to 9 hour(s) , Talk time: up to 43 hour(s) , Video playback: up to 15 hour(s) , Audio playback: up to 105 hour(s)
Rose blush
Sensors
Gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
Pen holder, Dolby Surround, Dolby Atmos, MU-MIMO technology, tuned by AKG speakers, Samsung DeX
IEC 61960
15.95 cm
0.57 cm
24.45 cm
420 g
Samsung Galaxy Tab S6 LTE 128GB - Rose blush Bundle deal on Samsung Galaxy Tab S6 LTE 128GB - Rose blush
£673.34
Screen Size: 10.5in
RAM: 6GB
Capacity: 128GB
Brand: Samsung
Price Range Ex VAT: 500 - 750
