Maximize your potential and turn challenge into opportunity with a tablet that prepares you for whatever life throws your way.
Multiply the things you do
Take full advantage of apps that work in split view on the Galaxy Tab S6 in multi window. Split the view with just a click to use apps like Gallery, Email and Samsung Notes simultaneously that share the screen at the size you choose so you can work the way you want. -
A full film studio from step one to done
Now get a dual camera for the first time in a Galaxy Tab with rear-facing 13 MP and 5 MP cameras. Use Ultra-Wide angle and smart AI to shoot like a pro and optimize the tone of your shots. -
Next-generation neural processing power
Galaxy Tab S6 packs processing power that brings not just next-generation specs for lag-free gaming but a whole lot more. Accelerated neural network processing accelerates the efficiency of AI applications, while Bixby Vision adds improved deep learning in scene recognition. -
Tap the screen to instantly unlock
Galaxy Tab S6 incorporates an onscreen optical fingerprint scanner for maximum convenience and security. Just touch your finger to the screen to unlock your tablet - a single press on the front screen is all you need, and no password to remember. -
Finally a reason to put down your phone
Stay in touch when your phone is out of reach. Galaxy Tab S6 seamlessly syncs your Galaxy smartphone, so you never miss a call when it comes in. It also allows you to reply to urgent text messages, so you're never out of the loop. -
Seamlessly connect your Galaxy Tab S6
Sync up to an ecosystem that lets your devices work seamlessly together right out of the box. Turn your Galaxy Tab S6 into a control hub for your other devices and take your content with you. -
Pick up your best match
Galaxy Tab S6 packs all this into a device this small so your potential isn't weighed down. -
Kick back with stunning visuals and sound
The nearly bezel-less sAMOLED display provides 10.5 inches of 2560 x 1600 WQXGA screen at 287 ppi and a 16:10 screen ratio that's ideal for hours of viewing and reading. Draw yourself into your content with four speakers that give immersive audio depth in a body this slim.
- Samsung Galaxy Tab S6 - tablet - Android 9.0 (Pie) - 128 GB - 10.5" - 3G, 4G
- Product Type
- Tablet
- Operating System
- Android 9.0 (Pie)
- Display
- 10.5" Super AMOLED - 2560 x 1600 (287 ppi) - Multi-Touch
- Processor
- Qualcomm Snapdragon 855 (8-core)
- Processor Clock Speed
- 2.8 GHz
- Storage
- 128 GB
- RAM
- 6 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, UMTS, LTE, TDD LTE
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Camera
- 13 Megapixel (ultra wide rear), 5 Megapixel (wide rear), 8 Megapixel (front)
- HD Video Recording
- 4K
- Navigation System
- GPS/GLONASS/Galileo/BeiDou
- Security Devices
- Fingerprint reader, face recognition
- Battery Run Time
- Up to 15 hours
- 15.95 cm x 0.57 cm x 24.45 cm
- 420 g
- Mountain grey
- 2-year warranty
- Product Type
- Tablet
- Operating System
- Android 9.0 (Pie)
Display
- Resolution
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- Image Aspect Ratio
- 16:10
- Smart View Technology
- Processor
- 2.8 GHz
- Number of Cores
- 8-core
- Storage
- 128 GB
- RAM
- 6 GB
- Max Supported Capacity
- 1 TB
Communications
- 3G, 4G
- Band
- GSM 850/900/1800/1900 / UMTS 800/850/900/AWS/1900/2100 / LTE 700/800/850/900/AWS/AWS-3/1800/1900/2100/2300/2500/2600
- Wi-Fi Direct, ANT+
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Camera
- Resolution (MP)
- Lens Aperture
- F/2.2 (ultra wide) / f/2.0 (wide) (rear) / f/2.0 (front)
- Focus Adjustment
- Automatic
- Video Resolutions
- 3840 x 2160
- Frame Rate
- 30 frames per second
- 4K
- Live focus
Navigation System
- Receiver
Multimedia
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- AVI, WMV, MKV, 3GP, ASF, FLV, 3G2, M4V, WEBM, MP4
- Audio
- Microphone, four speakers
Input Device
- Security Devices
Software
- Preloaded Software
- Samsung KNOX
Expansion and Connectivity
- Expansion Slots
- 1 x microSD , 1 x Nano-SIM card
- 1 x USB-C , 1 x POGO pin
- Capacity
- 7040 mAh
- Run Time
- Up to 15 hours
- Talk Time
- 43 hours
- Run Time Details
- Web browsing over 4G: up to 9 hour(s) , Web browsing over Wi-Fi: up to 9 hour(s) , Talk time: up to 43 hour(s) , Video playback: up to 15 hour(s) , Audio playback: up to 105 hour(s)
- Mountain grey
- Sensors
- Gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
- Pen holder, Dolby Surround, Dolby Atmos, MU-MIMO technology, tuned by AKG speakers, Samsung DeX
- IEC 61960
- 15.95 cm
- 0.57 cm
- 24.45 cm
- 420 g
- Limited warranty - 2 years
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£673.34
