Explore, work and watch your favorite shows on a clear and stunningly brilliant screen. Transform your Galaxy Tab S4 into the PC experience with the taskbar you're used to with the DeX. Create a PowerPoint presentation and revise budgets in Excel at your favorite café. Then edit, sketch and capture inspiration with the included S Pen. And using far field mics, you can even control your Tab S4 from a distance with Google Assistant.
- Samsung Galaxy Tab S4 - tablet - Android 8.0 (Oreo) - 64 GB - 10.5" - 3G, 4G
- Product Type
- Tablet
- Operating System
- Android 8.1 (Oreo)
- Display
- 10.5" Super AMOLED - 2560 x 1600 (287 ppi) - Multi-Touch
- Processor
- QUALCOMM Snapdragon 835 MSM8998 (8-core) - 64-bit
- Processor Clock Speed
- 2.35 GHz
- Storage
- 64 GB
- RAM
- 4 GB
- Total User Available Memory
- 50.5 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, UMTS, LTE, FDD LTE, TDD LTE
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Camera
- 13 Megapixel (rear), 8 Megapixel (front)
- HD Video Recording
- 4K
- Navigation System
- GPS/GLONASS/Galileo/BeiDou
- Security Devices
- Eye scan
- USB Type C, 3.5mm earphone jack
- 16.43 cm x 0.71 cm x 24.93 cm
- 483 g
- Black
- Product Type
- Tablet
- Operating System
Display
- Resolution
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- Processor
- 2.35 GHz
- Number of Cores
- 8-core
- 64-bit Computing
- Storage
- 64 GB
- RAM
- 4 GB
- 50.5 GB
- Max Supported Capacity
- 400 GB
Communications
- 3G, 4G
- Bluetooth Profiles
- Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Audio/Video Control Transport Protocol (AVCTP), Audio/Video Distribution Transport Protocol (AVDTP), General Audio/Video Distribution Profile (GAVDP), Device ID Profile (DIP), Generic Attribute Profile (GATT), HID Over GATT Profile (HOGP)
Camera
- Resolution (MP)
- Lens Aperture
- F/1.9 (rear)
- Focus Adjustment
- Automatic
- Camera Light Source
- Flash
- Video Resolutions
- 3840 x 2160
- Frame Rate
- 30 frames per second
- 4K
Navigation System
- Receiver
Multimedia
- Supported Digital Audio Standards
- WAV, WMA, AAC, Ogg Vorbis, AMR, MP3, FLAC, XMF, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, OTA, RTTTL/RTX, MID
- Supported Digital Video Standards
- AVI, WMV, MKV, 3GP, ASF, FLV, 3G2, M4V, WEBM, MP4
Input Device
- Security Devices
- Eye scan
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC , SIM card
- 1 x USB-C , 1 x headphones mini jack (3.5mm)
- USB Host
- Capacity
- 7300 mAh
- Run Time Details
- Web browsing over 3G: up to 9 hour(s) , Web browsing over 4G: up to 10 hour(s) , Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 16 hour(s) , Audio playback: up to 195 hour(s) , Talk time: up to 50 hour(s)
- Black
- Sensors
- Accelerometer, proximity sensor, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- MIMO technology, fast charging
- Included Accessories
- Power adapter
- Cables Included
- USB-C 3.1 cable
- 16.43 cm
- 0.71 cm
- 24.93 cm
- 483 g
