Samsung Galaxy S8 64GB Midnight Black
Quicklinx: CY3NWS00 Mfr#: SM-G950FZKAXEU#BTCM
  • microSDHC
  • Android
Samsung Galaxy S8
Introducing the stunning Infinity display. The revolutionary design of the Galaxy S8 begins from the inside out. We rethought every part of the phone's layout to break through the confines of the smartphone screen. So all you see is pure content and no bezel. It's the biggest, most immersive screen on a Galaxy smartphone of this size. And it's easy to hold in one hand.
Buy a BT Mobile SIM only plan and get a £50 discount code to spend on select 4G mobile phones. View the complete range at http://www.bt.com/shop/mobilephones
*Delivery charge of £4.99 applies to each order.
Need help with setting up your phone and BT Mobile? View our short setup videos here.
Features:
4G
Nano SIM
12.0MP Dual Pixel rear camera, 8.0MP CMOS front camera
5.8” Quad HD+ dual edge Super AMOLED Display
Android 7.0 (Nougat)
Octa-core Processor (2.35GHz Quad + 1.9GHz Quad)
64GB Internal Storage
External Storage - MicroSD up to 256GB
works with:
BT Mobile app
Keep track of the data, calls and texts you’ve used
BT Wi-Fi app
Access more than 5 million BT Wi-Fi hotspots on-the-go. It’s the UK’s largest wi-fi network
BT Sport app
Watch 3 great channels of unmissable sport on-the-go, showing Barclays Premier League, FA Cup and Aviva Premiership Rugby
Samsung Galaxy S8
The world’s first Infinity Screen
The Galaxy S8 expansive display stretches from edge to edge, giving you the most amount of screen in the least amount of space. And the Galaxy S8+ is even more expansive—our biggest screen yet.
A camera built for every moment
Capture life as it happens with the Galaxy S8 and S8+ cameras. The 12MP rear camera and the 8MP front camera are so accurate and fast that you won't miss a moment, day or night.
Security that's foolproof
Prying eyes are not a problem when you have iris scanning on the Galaxy S8 and S8+. Your irises have patterns that are unique to you, and they're nearly impossible to replicate. That means with iris scanning, your phone and its contents open to your eyes only. And when you need to unlock really fast, face recognition is a handy option.
Faster, even in rain
You never really stop using your phone. That's why Galaxy S8 and S8+ are driven by the world's first 10nm processor. It's fast and powerful and increases battery efficiency. Plus, there's the ability to expand storage, and to work through rain and dust with IP68-rated performance.
Say hello to Bixby
Bixby completely changes the way you interact with your phone. It's a personal assistant that understands talk, text, and taps so you're never confined to one mode of communication. It also completely changes the way you use your phone. You don't even have to ask Bixby, just show it what you want by opening your camera app. It's so incredibly easy.
The phone that opens up new worlds
The Galaxy S8 and S8+ are designed to be more than just smartphones. They're designed to change how you capture and view your life, whether it's in 360 degrees or in virtual reality. They're designed to change how you pay and work on the go. Break down the barriers in your world with the Galaxy S8 and S8+.
  • Design - boundaries removed
    The Infinity Display has an incredible end-to-end screen that spills over the phone's sides, forming a completely smooth, continuous surface with no bumps or angles. It's pure, pristine, uninterrupted glass. And it takes up the entire front of the phone, flowing seamlessly into the aluminum shell. The result is a beautifully curved, perfectly symmetrical, singular object.
  • Infinity display - beyond the bezel
    The Infinity Display sets a new standard for uninterrupted, immersive experiences. It enables an expanded screen size without necessitating a larger phone. So while the view is grander, Galaxy S8 feels small in your hand, making them easy to hold and use.
  • The big screen that feels small
    You'll immediately notice the comfortable grip of the smooth curves, which allow you to hold on easily while you watch movies on the larger screen. And important shortcuts are a swipe away, as the edge screen is available on Galaxy S8.
  • Sleek all around
    Complementing the uniform front is the equally smooth silhouette on the back. The rear camera sits perfectly flush with the surface for a visually tranquil profile.
  • More screen means more is seen
    Be it movies or games, you'll get drawn into the action on the Galaxy S8 screen. Not only are they the biggest, most immersive displays for mobile devices of these sizes, with the 18.5:9 display ratio, you get the whole scene on your screen.
  • Scroll less, do more
    Text while you watch a movie or make a list while you browse. You're able to multitask efficiently due to the bigger screen, and you can choose what your focus is by easily resizing the windows. And when just one thing has your attention, you'll see more of the article or your social media feed, so you scroll less.
  • Invisible but accessible
    Navigation keys are no different from the physical ones you're used to. Only they're now beautifully inconspicuous - until you need them. The home key is where it normally is, and it works just as usual with a simple press.
  • Styled for the future
    Enjoy seamless navigation on the Galaxy S8 with a sleek and clean interface that aligns beautifully with the smooth Infinity Display. As you unlock from the AOD (Always On Display) and switch between apps, the visual journey on screen is just as striking as the exterior.
  • Selfies done right
    Turn on the selfie camera and take photos that everyone will want to share. Smart Auto Focus tracks faces, so whether you use your arm or a selfie stick, everyone in the shot will be in focus. And enhanced multi-frame image processing keeps all the selfies crisp and clear.
  • Capture the night
    The dark is no match for Galaxy S8's rear camera. The bright F1.7 lens and large 1.4µm pixels bring in more light when there's not enough around. So what you see is what you'll get in the shot.
  • Ready for action
    When you're quick enough to capture the moment, you need a camera that's just as fast and focused - like the Galaxy S8 camera. It focuses as swiftly as your eyes do using its Dual Pixel sensor and bright lens, delivering photos that are crisp and vivid.
  • Memories, crystal clear
    The stars aligned for that picture-perfect moment and with the Galaxy S8 camera, that moment is yours to keep. It uses enhanced image processing, taking multiple shots and combining them into one high-quality photo. All you have to do is press the shutter.
  • Turn pro
    Make full use of the Galaxy S8 superior camera performance by turning on Pro Mode. It gives you the option to adjust any of the six settings: ISO, Shutter speed, Exposure, Color tone, Manual focus, and WB (White Balance).
  • Focus on what matters
    With Selective focus mode you're able to choose the depth of field after taking the shot to choose whichever focus you fancy: foreground, background, or both.
  • Filtered moments
    The right filter can make a photo into a masterpiece. Use the preview option and choose from a range of filters to enhance your picture before you even take the shot.
  • Tasty shots
    Make your food photography stand out from the crowd. Food mode brings out the best in your lunch or dessert for mouthwatering shots.
  • It's easy
    So many features and modes, everything you need to take gorgeous photos is right at your fingertips.
  • Photos from Galaxy S8
    Get inspired or just be impressed by the stunning photos taken by the Galaxy S8.
  • Iris scan
    The patterns in your irises are unique to you and are virtually impossible to replicate, meaning iris authentication is one of the safest ways to keep your phone locked and the contents private.
  • Three hassle-free ways to unlock your phone
    Life is so much easier and simpler without the trouble of having to remember one more password, one more PIN. And that's why the Galaxy S8 comes with three easy ways to unlock your phone.
  • Iris scanner - open with your eyes
    Hold up your Galaxy S8 and align your eyes with the twin circles on-screen to scan your irises. Your phone is unlocked with a look.Circles around eyes of a person showing iris scanning
  • Open with your face
    Raise your phone as if taking a selfie to use face recognition. It's a fast and effortless way to unlock your Galaxy.
  • Fingerprint scanner - open with a touch
    As you pick up your Galaxy S8, your finger goes naturally to the fingerprint sensor on the back and it's unlocked in one seamless move. You don't even have to wake up the phone first.Hand holding Galaxy S8 showing fingerprint sensor on the back of the phone.
  • Convenient and safe
    Some of the most sensitive activities like paying with your credit or debit card and accessing bank accounts is fast, easy, and secure on your DREAM with biometric authentication. Scan your irises or fingerprint to make purchases with Samsung Pay in-store, check your bank accounts via Samsung Pass and log into your favorite sites right away with the Web sign-in feature. Keep private files and apps separately in the Secure Folder to keep them accessible only to you.
  • Defense-grade security from the chip up
    Samsung Knox is seriously secure and has been approved by governments worldwide. Its level of security begins at the chip level. Something only Samsung can do as chipmaker. Building on the chip-level security are five crucial layers of protection that work at hardware and software levels. On the Galaxy S8, the upgraded Knox 2.8 is in position to safeguard your data around the clock.
  • Gaming taken to new levels
    Your favorite games are taken to a new level when played on Galaxy S8 boundless screen. And with Vulkan capabilities, hours of immersive fun are at your fingertips with even the most graphic-intensive games.
  • Music for every occasion
    Access 40 million songs and thousands of playlists tailored for any mood or occasion. Upload and store up to 100,000 songs and save songs offline, so you always have your music with you.
  • Battery - power that lasts
    You're able to use your Galaxy S8 for longer with each charge because the better-performing processor means a more efficient use of battery life. And with wireless charging and fast charging capabilities, charging the battery is also easy and convenient.
  • Back in a flash
    Even if you drain the battery, Galaxy S8 won't be down for long with their fast charging capabilities.
  • Wireless Charging - wires be gone
    Wireless charging is as easy as putting your phone down. If you were watching something on your phone, just prop the charger up. With Galaxy S8 fast charging power, you can have it back in your hand in no time.
  • The phone that keeps you on your toes
    Healthy habits aren't developed in a day. Use the Samsung Health app on your Galaxy S8 to record your daily activities - sleep, eating, exercise, and more - and get recommendations on how to reach your goals.
Samsung Galaxy S8 - midnight black - 4G smartphone - 64 GB - TD-SCDMA / UMTS / GSM
4G smartphone
Manufacturer Model Number
SM-G950F
Display
OLED display - 2960 x 1440 pixels - 5.8" - 570 ppi - Quad HD+ Super AMOLED
Heart rate sensor
Samsung Exynos 8895 / 2.3 GHz (8-core) - 64-bit
Graphics Accelerator
Mali-G71 MP20
RAM 4 GB / 64 GB
Supported Memory Card
microSDXC slot - up to 256 GB
Operating System
Android 7.0 Nougat
Main Camera
12 Megapixel - f/1.7 - focus: automatic
Front Camera
8 Megapixel f/1.7 - automatic
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader, eye scan
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1200 minutes
Standby Time
Up to 81.12 hours
Protection
Water-resistant
Midnight black
68.1 mm x 8 mm x 148.9 mm
155 g
0.315 W/kg (head) , 1.27 W/kg (body)
Smartphone
SM-G950F
Touch
Protection
Water-resistant
Integrated Components
Heart rate sensor
68.1 mm
8 mm
148.9 mm
155 g
Body Colour
Midnight black
SAR Value
1.27 W/kg (body), 0.315 W/kg (head)
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 7.0 Nougat
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0, ANT+/ANT
Bluetooth Profiles
HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, heart rate, pressure sensor, geomagnetic sensor
Security Devices
Additional Features
Face Unlock, Samsung KNOX
Media Player
Supported Digital Audio Standards
WAV, WMA, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, RTTTL, RTX, OTA, DFF, MID
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM
Samsung Exynos
Processor Number
8895
Clock Speed
2.3 GHz
Processor Core Qty
8-core
64-bit Architecture
Graphics System
Mali-G71 MP20
RAM
LPDDR4 SDRAM - 4 GB
Internal Memory Capacity
64 GB
User Memory
52.3 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
8 Megapixel
Sensor Size
1/3.6"
Lens Aperture
F/1.7
Focus Adjustment
Automatic
Camera Modes
Slow motion video, Virtual Shot
Main Camera
Sensor Resolution
12 Megapixel
Sensor Size
1/2.55"
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.7
Focus Adjustment
Automatic
Digital Zoom
8x
Self-Timer Delay
Special Effects
Motion effect, HDR, Stamp, Bokeh effect, Grid Line, Stickers
Camera Modes
Panorama, Slow motion mode, Pro mode, wide selfie mode, Virtual Shot, HYPERLAPSE, Food mode
Light Source
Dual LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
Quick Launch, Tracking Focus, Dual Pixel technology, voice trigger, geotagging, Continuous Auto Focus (CAF), RAW image capture, VDIS (Video Digital Image Stabilisation)
Display
OLED display
Diagonal Size
5.8"
Display Resolution
2960 x 1440 pixels
Pixel Density
570 ppi
Colour Depth
16.7 million colours
Always-on display
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
3000 mAh
Talk Time
1200 minutes
Standby Time
81.12 hours
Run Time Details
Talk: up to 1200 min , Active online usage (Wi-Fi): up to 14 hrs , Active online usage (3G): up to 11 hrs , Active online usage (LTE): up to 12 hrs , Playback (audio (Always On Display Off)): up to 67 hrs , Playback (audio (Always On Display On)): up to 44 hrs , Playback (video): up to 16 hrs
IP68
Stereo headset, USB cable, power adapter, SIM card removal tool, micro-USB connector, 2 pair ear plugs, USB-C to Micro-USB Adapter
Max Depth of Water Resistance
1.5 m
