Samsung Galaxy S8+
Introducing the stunning Infinity display. The revolutionary design of the Galaxy S8+ begins from the inside out. We rethought every part of the phone's layout to break through the confines of the smartphone screen. So all you see is pure content and no bezel. It's the biggest, most immersive screen on a Galaxy smartphone of this size.
Buy a BT Mobile SIM only plan and get a £50 discount code to spend on select 4G mobile phones. View the complete range at http://www.bt.com/shop/mobilephones
*Delivery charge of £4.99 applies to each order.
Need help with setting up your phone and BT Mobile? View our short setup videos here.
Features:
4G
Nano SIM
12.0MP Dual Pixel rear camera, 8.0MP CMOS front camera, UHD 4K Video Recording
6.2” Quad HD+ dual edge Super AMOLED Display
Android 7.0 (Nougat)
MSM 8998 Octa-Core 2.35Ghz (Quad-Core) + 1.9GHz (Quad) Processor
64GB Internal Storage
External Storage - MicroSD up to 256GB
works with:
BT Mobile app
Keep track of the data, calls and texts you’ve used
BT Wi-Fi app
Access more than 5 million BT Wi-Fi hotspots on-the-go. It’s the UK’s largest wi-fi network
BT Sport app
Watch 3 great channels of unmissable sport on-the-go, showing Barclays Premier League, FA Cup and Aviva Premiership Rugby
Stunning Infinity Display
The revolutionary design of the Galaxy S8+ begins from the inside out. All you see is pure content and no bezel. It's a big, immersive screen. And it's easy to hold in one hand. -
Boundaries removed
The Infinity Display has an incredible end-to-end screen that spills over the phone's sides, forming a completely smooth, continuous surface with no bumps or angles. It's pure, pristine, uninterrupted glass. And it takes up the entire front of the phone, flowing seamlessly into the aluminum shell. The result is a beautifully curved, perfectly symmetrical, singular object. -
A camera built for every moment
Capture life as it happens with the Galaxy S8+ cameras. The 12MP rear camera and the 8MP front camera are so accurate and fast that you won't miss a moment, day or night. -
Security that's foolproof
Prying eyes are not a problem when you have iris scanning on the Galaxy S8+. No two irises have the same pattern, not even yours, and they're nearly impossible to replicate. That means with iris scanning, your phone and its contents open to your eyes only. And when you need to unlock really fast, face recognition is a handy option. -
Faster, even in rain
You never really stop using your phone. That's why Galaxy S8+ is driven by the advanced processor. It's fast and powerful and increases battery efficiency. Plus, there's the ability to expand storage, and to work through rain and dust. -
Say hello to Bixby
Bixby completely changes the way you interact with your phone. It's a personal assistant that understands talk, text, and taps so you're never confined to one mode of communication. It also completely changes the way you search. You don't even have to ask, just show Bixby what you want by opening your camera app. It's so incredibly easy. -
The phone that opens amazing worlds
The Galaxy S8+ is designed to be more than just smartphone. They're designed to change how you capture and view your life, whether it's in 360 degrees or in virtual reality. They're designed to change how you pay and work on the go. Break down the barriers in your world with the Galaxy S8+. -
Change your phone, easily keep your memories
From your photos and videos to contacts and music, Smart Switch lets you easily transfer your memories on your old phone to your Galaxy S8+. Now that you know all the memories are coming with you. -
Technology for all
The Galaxy S8+ is built to be more accessible for everyone. A well-thought-out range of technical solutions make it easy for anyone to make full use of the Galaxy S8+'s advanced capabilities.
- Samsung Galaxy S8+ - midnight black - 4G smartphone - 64 GB - TD-SCDMA / UMTS / GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G955F
- Display
- OLED display - 2960 x 1440 pixels - 6.2" - 529 ppi - Quad HD+ Super AMOLED - Corning Gorilla Glass 5 (scratch resistant glass)
- Heart rate sensor
- Processor
- Samsung Exynos 8895 (8-core) - 64-bit
- Graphics Accelerator
- Mali-G71 MP20
- Memory
- RAM 4 GB / 64 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Android 7.0 Nougat
- Main Camera
- 12 Megapixel - f/1.7 - focus: automatic, manual
- Front Camera
- 8 Megapixel - CMOS f/1.7 - automatic
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader, eye scan
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1440 minutes
- Wireless Charging Standards
- WPC, PMA
- Protection
- Dustproof, splashproof, waterproof
- Midnight black
- 73.4 mm x 8.1 mm x 159.5 mm
- 173 g
- Specific Absorption Rate (SAR)
- 0.26 W/kg (head) , 1 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-G955F
- Form Factor
- Touch
- Protection
- Integrated Components
- Heart rate sensor
- 73.4 mm
- 8.1 mm
- 159.5 mm
- 173 g
- Body Colour
- Midnight black
- SAR Value
- 1 W/kg (body), 0.26 W/kg (head)
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Intelligent Assistant
- Bixby
- Navigation
- GPS, A-GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS)
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, heart rate, pressure sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Wi-Fi Miracast, MU-MIMO technology, Fast Charging, Samsung KNOX
Media Player
- Supported Digital Audio Standards
- WAV, WMA, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, apt-X, DSF, DSD, MXMF, IMY, RTTTL, RTX, OTA, DFF, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Samsung Exynos
- Processor Number
- 8895
- Processor Core Qty
- 8-core
- 64-bit Architecture
Graphics System
- Mali-G71 MP20
- RAM
- LPDDR4 SDRAM - 4 GB
- Internal Memory Capacity
- 64 GB
- User Memory
- 52.3 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Sensor Type
- CMOS
- Sensor Size
- 1/3.6"
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic
- Camera Modes
- Wide selfie mode
Main Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/2.55"
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic, manual
- Digital Zoom
- 8x
- Self-Timer Delay
- Special Effects
- Motion effect, HDR, Stamp, Bokeh effect, Grid Line, Stickers
- Camera Modes
- Panorama, Slow motion mode, Pro mode, Timer mode, Virtual Shot, HYPERLAPSE, Food mode
- Face Detection
- Face detection
- White Balance
- Custom, automatic
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
- Selective Focus, Quick Launch, Playback zoom, Dual Pixel technology, Motion photo, Exposure, Shutter speed, geotagging, RAW image capture, VDIS (Video Digital Image Stabilisation)
Display
- OLED display
- Technology
- Diagonal Size
- 6.2"
- Display Resolution
- Pixel Density
- 529 ppi
- Colour Depth
- 16.7 million colours
- Protection
- Always-on display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3500 mAh
- Wireless Charging
- WPC, PMA
- Talk Time
- 1440 minutes
- Run Time Details
- Talk (WCDMA): up to 1440 min , Playback (MP3 (AOD on)): up to 50 hrs , Playback (MP3 (AOD off)): up to 78 hrs , Playback (video): up to 18 hrs , Active online usage (Wi-Fi): up to 15 hrs , Active online usage (3G): up to 13 hrs , Active online usage (LTE): up to 15 hrs
- IP68
- Included Accessories
- Power adapter, SIM card removal tool, AKG headphones, micro-USB connector (C to B), ear plugs, USB-C to A connector, USB-C cable
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
