Samsung Galaxy S7 edge brings a new way of thinking about what a phone can do. You defined the possibilities. Rethink what a phone can do.
Design
The beauty of what was engineered is to give you the slimmest feel in your hand without compromising the big screen size. And the elegantly curved front and back fit in your palm just right. It's as beautiful to look at, as it is to use. -
Camera
Some of the most precious memories happen after dark. And this is the first smartphone camera to have a professional-grade Dual Pixel Sensor with which you'll now be able to take crisp, clear photos in the dark. With Galaxy S7 edge, you own the night. -
Gaming
Mobile gaming just got a whole lot better with a dedicated game control center and gameplay recording. And with the Galaxy S7 edge's powerful processor, it just got highly realistic. -
Hardware
The Galaxy S7 edge is redesigned to have memory that expands at your will. The incredibly fast processors and huge RAM keeps everything running smooth even when running at full capacity. While the bigger battery keeps you going for longer. -
Water & dust resistance
The Galaxy S7 edge goes everywhere you go. In the rain, the shower, or the pool. Up to 30 minutes or 1.5 meters under. It is also worked out how to completely seal off the inside components while keeping micro USB ports, earphone jacks open, so you won't have to fiddle with extra caps or covers. -
Shortcuts
Because you spend more time with the phones than ever before, you're constantly devising ways for you to get what you need at a touch and at a glance. And these shortcuts will get you everywhere.
- Samsung Galaxy S7 edge - black - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G935F
- Display
- OLED display - 2560 x 1440 pixels - 5.5" - 534 ppi - Quad HD Super AMOLED
- Heart rate sensor
- Processor
- 2.3 GHz (8-core) - 64-bit
- Memory
- RAM 4 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 200 GB
- Operating System
- Android 6.0 (Marshmallow) with Samsung TouchWiz + EtiquEdge
- Main Camera
- 12 Megapixel - f/1.7 - focus: automatic
- Front Camera
- 5 Megapixel - CMOS - wide-angle lens - f/1.7
- Service Provider
- Not specified
- SIM Card
- Nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader
- Messaging Services
- WhatsApp, Google+ Hangouts, SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 1620 minutes
- Wireless Charging Standards
- WPC, PMA
- Protection
- Dustproof, waterproof
- Black
- 72.6 mm x 7.7 mm x 150.9 mm
- 157 g
- Specific Absorption Rate (SAR)
- 0.264 W/kg (head) , 0.507 W/kg (body)
- SAR Category (Belgium)
- B
- Product Type
- Smartphone
- SM-G935F
- Form Factor
- Touch
- Protection
- Integrated Components
- Heart rate sensor
- 72.6 mm
- 7.7 mm
- 150.9 mm
- 157 g
- Body Colour
- Black
- Body Material
- Metal, glass
- SAR Value
- 0.507 W/kg (body), 0.264 W/kg (head)
- B
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- User Interface
- Samsung TouchWiz + EtiquEdge
- Navigation
- GPS, A-GPS, GLONASS, BeiDou
- SIM Card Type
- Nano SIM
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- Supported Email Protocols
- POP3, IMAP4
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 38, Band 39, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, TDD 2600, TDD 1900, TDD 2300, TDD 2500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Multitasking, Easy Mode, MIMO technology, Private Mode, Ultra Power Saving Mode, Screen mirroring, Dual Curved display, Alarm Clock
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Clock Speed
- 2.3 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 4 GB
- Internal Memory Capacity
- 32 GB
- User Memory
- 24.4 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 200 GB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Sensor Type
- CMOS
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.7
- Camera Modes
- Slow motion video, selfie panorama
- Light Source
- LED flash
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic
- Camera Modes
- Panorama, Pro mode, wide selfie mode, Virtual Shot, HYPERLAPSE, Motion panorama
- HDR Mode
- Auto HDR mode
- Light Source
- LED light
- Video Resolutions
- 3840 x 2160 (4K)
- Selective Focus, Dual Pixel technology, Motion photo, vDIS technology, Spotlight
Display
- OLED display
- Technology
- Diagonal Size
- 5.5"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 534 ppi
- Colour Depth
- 16.7 million colours
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Capacity
- 3600 mAh
- Wireless Charging
- WPC, PMA
- Talk Time
- 1620 minutes
- Run Time Details
- Talk (WCDMA): up to 1620 min , Active online usage (WCDMA): up to 12 hrs , Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 18 hrs , Playback (Music): up to 55 hrs , Playback (audio (Always On Display Off)): up to 74 hrs
- IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- USB adapter, stereo headset, USB cable, power adapter, SIM card removal tool
- Max Depth of Water Resistance
- 1.5 m
