Samsung Galaxy S7 brings a new way of thinking about what a phone can do. You defined the possibilities. Rethink what a phone can do.
Design
The beauty of what was engineered is to give you the slimmest feel in your hand without compromising the big screen size. And the elegantly curved front and back fit in your palm just right. It's as beautiful to look at, as it is to use. -
Camera
Some of the most precious memories happen after dark. And this is the first smartphone camera to have a professional-grade Dual Pixel Sensor with which you'll now be able to take crisp, clear photos in the dark. With Galaxy S7, you own the night. -
Gaming
Mobile gaming just got a whole lot better with a dedicated game control center and gameplay recording. And with the Galaxy S7's powerful processor, it just got highly realistic. -
Hardware
The Galaxy S7 is redesigned to have memory that expands at your will. The incredibly fast processors and huge RAM keeps everything running smooth even when running at full capacity. While the bigger battery keeps you going for longer. -
Water & dust resistance
The Galaxy S7 goes everywhere you go. In the rain, the shower, or the pool. Up to 30 minutes or 1.5 meters under. It is also worked out how to completely seal off the inside components while keeping micro USB ports, earphone jacks open, so you won't have to fiddle with extra caps or covers. -
Shortcuts
Because you spend more time with the phones than ever before, you're constantly devising ways for you to get what you need at a touch and at a glance. And these shortcuts will get you everywhere.
- Samsung Galaxy S7 - platinum gold - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G930F
- Display
- OLED display - 2560 x 1440 pixels - 5.1" - 577 ppi - Quad HD Super AMOLED
- Heart rate sensor
- Processor
- 2.3 GHz (8-core) - 64-bit
- Memory
- RAM 4 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 200 GB
- Operating System
- Android 6.0 (Marshmallow) with Samsung TouchWiz
- Main Camera
- 12 Megapixel - f/1.7 - focus: automatic
- Front Camera
- 5 Megapixel - CMOS - wide-angle lens - f/1.7
- Service Provider
- Not specified
- SIM Card
- Nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader
- Messaging Services
- WhatsApp, Google+ Hangouts, SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 1320 minutes
- Wireless Charging Standards
- WPC, PMA
- Protection
- Dustproof, waterproof
- Platinum gold
- 69.6 mm x 7.9 mm x 142.4 mm
- 152 g
- Specific Absorption Rate (SAR)
- 0.406 W/kg (head) , 0.621 W/kg (body)
- Product Type
- Smartphone
- SM-G930F
- Form Factor
- Touch
- Protection
- Integrated Components
- Heart rate sensor
- 69.6 mm
- 7.9 mm
- 142.4 mm
- 152 g
- Body Colour
- Platinum gold
- Body Material
- Metal, glass
- SAR Value
- 0.621 W/kg (body), 0.406 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- User Interface
- Samsung TouchWiz
- Navigation
- GPS, A-GPS, GLONASS
- SIM Card Type
- Nano SIM
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- Supported Email Protocols
- POP3, IMAP4
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Multitasking, Easy Mode, MIMO technology, Private Mode, Ultra Power Saving Mode, Screen mirroring, Alarm Clock
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, Ogg Vorbis, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, H.264, H.263, M4V, WebM, 3G2, H.265
- Clock Speed
- 2.3 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 4 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 200 GB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Sensor Type
- CMOS
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.7
- Camera Modes
- Slow motion video, selfie panorama
- Light Source
- LED flash
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic
- Camera Modes
- Panorama, Pro mode, wide selfie mode, Virtual Shot, HYPERLAPSE, Motion panorama
- HDR Mode
- Auto HDR mode
- Light Source
- LED light
- Video Resolutions
- 3840 x 2160 (4K)
- Selective Focus, Dual Pixel technology, Motion photo, vDIS technology, Spotlight
Display
- OLED display
- Technology
- Diagonal Size
- 5.1"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 577 ppi
- Colour Depth
- 16.7 million colours
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Capacity
- 3000 mAh
- Wireless Charging
- WPC, PMA
- Talk Time
- 1320 minutes
- Run Time Details
- Talk: up to 1320 min
- IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Power adapter
