This is the phone that will change photography.
Meet Galaxy S20, S20+ and S20 Ultra. With revolutionary 8K Video Snap changing how you capture not just video but photography — and 5G changing the way you share it. Add in Samsung Knox security, an intelligent battery, powerful processor and massive storage — and the Galaxy S20 series unveils a whole new world for mobile.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
- Samsung Galaxy S20 5G - cosmic grey - 5G smartphone - 128 GB - TD-SCDMA / UMTS / GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-G981B/DS
- Display
- OLED display - 3200 x 1440 pixels - 6.2" - 563 ppi - (120 Hz) - Infinity-O Dynamic AMOLED 2X - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
- Heart rate sensor
- Processor
- Samsung Exynos 990 2.73 GHz (8-core) - 64-bit
- Neural Processor Unit (NPU)
- Samsung
- Memory
- RAM 12 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 10 with Samsung One UI 2
- Main Camera
- 64 Megapixel - telephoto lens - f/2.0 - focus: automatic, manual
- Second Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 12 Megapixel - wide-angle lens - f/1.8
- Front Camera
- 10 Megapixel f/2.2 - automatic
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT, Wi-Fi 6
- Security Devices
- Fingerprint reader (under display), face recognition
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 1200 minutes
- Wireless Charging Standards
- WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, water-resistant
- Cosmic grey
- 69.1 mm x 7.9 mm x 151.7 mm
- 163 g
- Specific Absorption Rate (SAR)
- 0.382 W/kg (head) , 1.525 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-G981B/DS
- Form Factor
- Touch
- Protection
- Integrated Components
- Heart rate sensor
- 69.1 mm
- 7.9 mm
- 151.7 mm
- 163 g
- Body Colour
- Cosmic grey
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 10
- User Interface
- Samsung One UI 2
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n28, n77, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 700APT, TDD TD 3700, TDD TD 3500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor, ultrasonic sensor, HR sensor
- Security Devices
- Additional Features
- HD Voice, Multi Window, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, High AOP Mic, Smart View, Live message, Samsung DeX support, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung KNOX 3.3
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound, Qualcomm TrueWireless, Qualcomm Broadcast Audio, Qualcomm Aqstic audio, Qualcomm aptX audio
- Clock Speed
- 2.73 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- Artificial Intelligence Processor Family
- Samsung
- RAM
- LPDDR5 SDRAM - 12 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 104 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Camera Modes
- Live Focus mode, AR Emoji, Live focus video
- Dual Pixel AF
Main Camera
- Sensor Resolution
- 64 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.0
- 76 degree(s)
- Focus Adjustment
- Automatic, manual
- Self-Timer Delay
- Special Effects
- HDR, Bokeh effect, Grid Line, Motion photos, video bokeh effect
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video
- Face Detection
- Face detection
- HDR Mode
- HDR+
- White Balance
- Custom, automatic
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (8K) at 24 fps
- Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, Shot suggestions, AR Emoji, blur detection, HDR10+ recording, Floating shutter button, Super steady, Quick Measure, 3x Hybrid Zoom
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 120 degree(s)
- Pixel Size
- 1.4 µm
- Dual Pixel AF, OIS (Optical Image Stabilisation)
Third Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/1.76"
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- 79 degree(s)
- Pixel Size
- 1.8 µm
- Super Speed Dual Pixel AF
Display
- OLED display
- Technology
- Diagonal Size
- 6.2"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 563 ppi
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10+
- Refresh Rate
- 120 Hz
- Protection
- Edge Screen, DCI-P3 Wide colour gamut, AOD(Always On Display)
- Connector Type
- USB Type-C
- Capacity
- 4000 mAh
- Fast Charging Technology
- Samsung Super Fast Charging 2.0
- Wireless Charging
- Talk Time
- 1200 minutes
- Run Time Details
- Talk: up to 1200 min , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 15 hrs
- VDE, IP68
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, clear cover case, protective film, Earphones (USB Type-C) with sound by AKG
- Limited warranty - 2 years
