Samsung Galaxy S10 FE - Wi-Fi
Quicklinx: J549WS00 Mfr#: SM-X520NZAREUB
Operating System: Android
Processor: Exynos 1580
  • Android
More than 50 In Stock
£415.84 ex VAT
£499.00 inc VAT
"Capture your ideas quickly on the Samsung Galaxy Tab S10 FE and get inspired with the included S Pen to jot down meeting notes or sketch diagrams. Unlock next-level productivity with intelligent and powerful AI tools that are optimised for the Tab’s expansive screen and intuitive S Pen. And instantly summon your AI assistant if you need information fast (1).
Enjoy seamless control with one mouse, keyboard, or trackpad as well as a PC-like experience with Samsung DeX which lets you work across multiple windows at once. Effortlessly and quickly send large files wirelessly between devices without the need for pairing (2). Plus, Dual SIM (3) lets you easily separate your work and personal life while the eSIM option makes travelling easy.
The 10.9" display delivers colours and contrasts that are balanced, even in bright outdoor environments with Vision Booster automatically optimising the screen for peak clarity. The anti-reflective coating and SGS-certification minimise glare and reduce blue light emission, ensuring comfortable viewing in any light (4, 5).
It has a powerful Exynos 1580 processor that’s paired with increased memory (6), allowing you to multitask smoothly with plenty of space for all your files with up to 2TB microSD card support (7). And it’s designed to be with you all the way, whether you’re in the office or out and about thanks to its IP68-rated water and dust resistance (8).
  1. A network connection is required to use Bixby or Gemini. Requires Google Account login. Users may need to download or update Google Gemini app to the latest version.
  2. Quick Share between Galaxy devices available with the following OS: smartphones and tablets with Android OS version 10.0 (Q) and One UI 2.1 or above, PCs running Windows 10 or later.
  3. Dual SIM available on 5G model only.
  4. The display used in Galaxy Tab S10 FE and Tab S10 FE+ has received the ""Low Blue Light"" certification from SGS based on its ability to reduce some of the blue light emission from the screen. More information of this certification can be found on www.sgs.com/performance.
  5. Low Blue Light certification is under 9.9% (test from SGS).
  6. Compared to previous Galaxy Tab FE models
  7. MicroSD card sold separately.
  8. Based on test condition for submersion in up to 1.5 meter of fresh water for up to 30 mins. Not advised for beach or pool use."
Samsung Galaxy Tab S10 FE - tablet - Android - 128 GB - 10.9"
Tablet
Operating System
Android
Display
10.9" TFT - 2304 x 1440 - Multi-Touch
Samsung Exynos 1580 (8-core)
Processor Clock Speed
2.9 GHz
Storage
128 GB
RAM
8 GB
User Available Memory
Flash: 106.2 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
Bluetooth 5.3, 802.11a/b/g/n/ac/ax
Rear Camera
13 Megapixel focus: automatic
Front Camera
12 Megapixel
Navigation System
GPS/GLONASS/Galileo/BeiDou/QZSS
Security Devices
Fingerprint reader
Battery Run Time
Up to 20 hours
25.43 cm x 0.6 cm x 16.58 cm
497 g
Grey
0.381 W/kg (body)
Tablet
Operating System
Android
Display
10.9" TFT
Resolution
2304 x 1440
Colour Depth
16 million colours
Touchscreen
Multi-Touch
Image Brightness
800 cd/m²
90 Hz refresh rate, High Bright mode
Samsung Exynos 1580
2.9 GHz
Number of Cores
8-core
Storage
128 GB
RAM
8 GB - LPDDR5 SDRAM
Flash: 106.2 GB
Max Supported Capacity
2 TB
Communications
Security Protocols & Features
Wi-Fi Direct, MIMO technology
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hearing Access Profile (HAP), Human Interface Device Profile (HID), Hands-Free Profile (HFP), HID Over GATT Profile (HOGP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Public Broadcast Profile (PBP), Phonebook Access Profile (PBAP), Telephony and Media Audio Profile (TMAP)
Rear Camera
Sensor Resolution
13 Megapixel
Focus Adjustment
Automatic
Video Resolutions
3840 x 2160 (4K) at 30 fps
Front Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Video Resolutions
Navigation System
Receiver
Multimedia
Supported Digital Audio Standards
MP3, M4A, 3GA, AAC, OGG, OGA, WAV, AMR, AWB, FLAC, MID, MIDI, XMF, MXMF, IMY, RTTTL, RTX, OTA
Supported Digital Video Standards
MP4, M4V, 3GP, 3G2, AVI, FLV, MKV, WEBM
Audio
Two speakers
Input Device
S Pen
Security Devices
Fingerprint reader
Software
Preloaded Software
Samsung Smart Switch
Expansion and Connectivity
Expansion Slots
1 x microSDXC
1 x USB-C 2.0
8000 mAh
Run Time
Up to 20 hours
Run Time Details
Video playback over Wi-Fi: up to 20 hours
Grey
Sensors
Accelerometer, gyro sensor, geomagnetic sensor, hall sensor, light sensor
Water-resistant, dust-resistant, Galaxy AI, Vision Booster
IEC 60529 IP68
0.381 W/kg (body)
25.43 cm
0.6 cm
16.58 cm
497 g
Limited warranty - 2 years , Limited warranty - battery - 1 year
Max Depth of Water Resistance
1.5 m
Brand: Samsung
