The next generation of wireless technology is coming.
With the Galaxy S10 5G - our first 5G-Ready device - you'll be able to stream and download movies and share life's moments HyperFast without Wi-Fi.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Stream HyperFast
The Galaxy S10 5G puts the unrivaled power, speed, and connectivity of 5G networks to work for you. So you'll be able to stream your favorite movies, shows, and games with faster speeds than 4G. -
A world of exciting features in one Galaxy
The Cinematic Infinity Display has so much screen, and so little bezel. That means more detail and clarity, more immersive and uninterrupted content, in a slim, balanced form. -
Six powerful cameras, one innovative phone
Front Dual 3D Depth Sensing Camera puts pro portraits in your pocket and delivers nuanced depth and beautiful portraits through two front-facing lenses embedded in the Infinity Display. -
Pro-Grade camera helps you upload epic posts in a flash
Galaxy S10 5G features six pro-grade cameras enhanced with intelligence so you can take effortlessly shareworthy shots. The 16 MP Ultra Wide lens lets you capture your view as you see it with its 123° field of vision. -
Video bokeh revolutionizes the way you shoot
Film in Ultra Wide. Take your video-making skills to the next level with the pro-grade, soft, out-of-focus effect known as bokeh. -
Quick Measure
Detects depth, distance, and so much more. The 3D Depth Sensing Camera's ability to measure both distances and objects pairs with AR intelligence to give you Quick Measure. Make sure your new stool will fit before you take it home. -
Browse at the speed of thought
With 5G and a supernaturally fast processor, the Galaxy S10 5G loads sites and apps HyperFast. Stream shows or play graphics-rich cloud games with faster speeds than 4G. Even level up your AR and VR experiences on the 5G network. -
Intelligently accesses power
The All-Day Intelligent Battery4 is a powerful battery that intelligently accesses power by learning how and when you use your phone to optimize usage based on how you live, to deliver intuitive and energetic peak performance throughout the day.
- Samsung Galaxy S10 5G - crown silver - 5G smartphone - 256 GB - TD-SCDMA / UMTS / GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-G977B
- Display
- OLED display - 3040 x 1440 pixels - 6.7" - 505 ppi - 19:9 - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
- Heart rate sensor
- Processor
- 2.73 GHz (8-core) - 64-bit
- Memory
- RAM 8 GB / 256 GB
- Operating System
- Android 9.0 Pie with One UI
- Main Camera
- 12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
- Second Camera
- 12 Megapixel - wide-angle lens - f/1.5 and f/2.4
- Third Camera
- 16 Megapixel - ultra wide-angle lens - f/2.2
- Fourth Camera
- - f/1.2 - 3D depth camera
- Front Camera
- 10 Megapixel f/1.9 - automatic
- Second Front Camera
- F/1.6 - 3D depth camera
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT, Wi-Fi 6
- Security Devices
- Fingerprint reader (under display), face recognition
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Wireless Charging Standards
- WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, water-resistant
- Crown silver
- 77.1 mm x 7.9 mm x 162.6 mm
- 198 g
- Specific Absorption Rate (SAR)
- 0.264 W/kg (head) , 1.55 W/kg (body)
- Product Type
- Smartphone
- SM-G977B
- Form Factor
- Touch
- Protection
- Integrated Components
- Heart rate sensor
- 77.1 mm
- 7.9 mm
- 162.6 mm
- 198 g
- Body Colour
- Crown silver
- Body Material
- Gorilla glass 6
- SAR Value
- 1.55 W/kg (body), 0.264 W/kg (head)
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- User Interface
- One UI
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor, ultrasonic sensor, HR sensor
- Security Devices
- Additional Features
- HD Voice, Multi Window, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, High AOP Mic, Smart View, Live message, Samsung DeX support, Bixby Vision, Neural Network Processing Unit, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung KNOX 3.3
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound, Qualcomm TrueWireless, Qualcomm Broadcast Audio, Qualcomm Aqstic audio, Qualcomm aptX audio
- Clock Speed
- 2.73 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- LPDDR4X SDRAM - 8 GB
- Internal Memory Capacity
- 256 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/1.9
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Camera Modes
- Live Focus mode, AR Emoji, Live focus video
- Dual Pixel AF
Second Front Camera
- Lens Aperture
- F/1.6
- 75 degree(s)
- Pixel Size
- 10 µm
- Functions
- 3D depth camera
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Dual OIS (Optical Image Stabilisation)
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
- 45 degree(s)
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic, manual
- Optical Zoom
- 2x
- Digital Zoom
- 10x
- Self-Timer Delay
- Special Effects
- HDR, Grid Line, Motion photos
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video
- Face Detection
- Face detection
- HDR Mode
- HDR+
- White Balance
- Custom, automatic
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, 9.1MP still photos recording 4K video, Shot suggestions, AR Emoji, blur detection, HDR10+ recording, Floating shutter button, Super steady, Quick Measure
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.5 and f/2.4
- 77 degree(s)
- Pixel Size
- 1.4 µm
- Dual Pixel AF, OIS (Optical Image Stabilisation)
Third Camera
- Sensor Resolution
- 16 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1 µm
Fourth Camera
- Lens Aperture
- F/1.2
- 72 degree(s)
- Pixel Size
- 10 µm
- Functions
- 3D depth camera
Display
- OLED display
- Technology
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 505 ppi
- Aspect Ratio
- 19:9
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10+
- Contrast Ratio
- 2000000:1
- Protection
- Edge Screen, DCI-P3 Wide colour gamut, AOD(Always On Display)
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 4500 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Samsung Super Fast Charging
- Wireless Charging
- VDE, IP68
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, headset (tuned by AKG), USB connector (OTG)
