Samsung Galaxy S10 128GB Enterprise Edition
Quicklinx: FKP5WS00 Mfr#: SM-G973FZKDU07
  • microSDHC
  • Android
Business keeps getting faster every day and you need to be able to work anywhere - flexibly and collaboratively. With the Galaxy S10, you can do everything you need right on your phone as fast as you need to, and keep your company and personal data protected. Plus, customizable services make it easy to deploy, manage and update devices while on-the-go. Discover next-generation mobile technology, productivity and security, all designed to enable next-generation business to succeed.
  • Desktop computing, mobile-powered
    Connect the Galaxy S10 to any monitor with the DeX adapter, and it has the power to perform like a desktop PC. Using DeX, you can access your desktop anywhere with enterprise-ready VDI solutions. Working just got better, wherever you are. No laptop. No issue.
  • Take the bigger picture
    The Galaxy S10 for business has four cameras, helping you take true-to-life pictures, even in low-light environments. The pro-grade camera lets you capture images just as your eyes see them - whether you're in the field or a meeting room. Capture a detail or scale to snap your full eye's view and instantly share them with colleagues. The 16MP ultra-wide lens ensures you don't miss a single detail.
  • A bigger space for working
    See more than ever before with the 6.1" Infinity display. The flawless glass screen has no margins at the top or bottom, and no home button or notch. So, it's perfect for viewing and editing documents on the go and makes it easy to multi-task across different apps. Sure to turn heads in any environment, the stunning display gives you a better view of presentations, photos or anything you need for work.
  • Effortless use so you can focus on what matters
    See only what you need, find focus in what you're doing and use your phone in a way that feels like second nature. Samsung One UI works with the way you use your phone. Screens are uncluttered, icons pop and it is easier to use one-handed.
  • Security at your fingertips
    Secure your phone like never before with Ultrasonic Fingerprint ID. Simply press your finger and unlock with the first touch. It's quick and easy to use, so you can access files and get to work in an instant. It works in almost any light, rain or shine, the smallest conference rooms and the great outdoors. The in-display sensor reads every ridge and notch of your finger, to ensure your sensitive data won't fall into the wrong hands.
  • Defense-grade security for an open world
    The Galaxy S10 is protected by Samsung Knox, a defense-grade security platform built from the chip up. No matter where you and your team go or what you do, you can be sure your business' data stays secure with superior protection that's easy to manage.
  • Open customization meets management control
    From device configuration, enrollment and management to advanced mobile security controls and updates, Samsung has the mobility software and enterprise mobility services you need for every stage of the device lifecycle.
  • All-day intelligent battery
    In work and in life, there's never a good time to lose power. With the Galaxy S10, you get an intelligent battery designed to keep you working longer. Using machine learning, the Galaxy S10 tracks your habits, intuitively monitoring when you need battery life the most. So, even when you are in back-to-back meetings or using power-hungry Bluetooth and business apps, you don't have to worry about losing charge.
  • Wireless PowerShare
    Give colleagues or clients a boost when they're low on power, by sharing yours. Simply place other devices on the back of the Galaxy S10 and transfer up to 20% of your battery's charge, if they're set up for wireless charging. You can charge wearables, too.
  • The truly intelligent smartphone
    Work smarter with the intelligent phone that optimizes its performance for you. The Galaxy S10 uses machine learning to understand your daily usage patterns, loading what you need and closing what you don't do to drive performance throughout the day. It works in the background to optimize your activity, predicting what you need for all the ways your work.
  • Simplified routines, for a maximized work day
    Learning from the way you work, the Galaxy S10 monitors apps in the background to optimize how they serve you. Bixby anticipates what you need before you need it, keeping you to your set routines, and maybe even recommending a new one. Observant, helpful intelligence that helps maximize your work day.
Samsung Galaxy S10 Enterprise Edition - prism black - 4G smartphone - 128 GB - TD-SCDMA / UMTS / GSM
4G smartphone
Manufacturer Model Number
SM-G973F/DS
Display
OLED display - 3040 x 1440 pixels - 6.1" - 550 ppi - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
Heart rate sensor
2.7 GHz (8-core) - 64-bit
RAM 8 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 9.0 Pie with One UI
Main Camera
12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
Second Camera
12 Megapixel - wide-angle lens - f/1.5 & f/2.4
Third Camera
16 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
10 Megapixel - wide-angle lens - f/1.9 - automatic
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT, Wi-Fi 6
Security Devices
Fingerprint reader (under display), face recognition
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1260 minutes
Wireless Charging Standards
WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, splashproof, waterproof
Prism black
70.4 mm x 7.8 mm x 149.9 mm
157 g
0.477 W/kg (head) , 1.593 W/kg (body)
Smartphone
SM-G973F/DS
Touch
Protection
Integrated Components
Heart rate sensor
70.4 mm
7.8 mm
149.9 mm
157 g
Body Colour
Prism black
Body Material
Gorilla glass 5
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
User Interface
One UI
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Payment Technology
Samsung Pay
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS)
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
Security Devices
Additional Features
Smart Select, MU-MIMO technology, Samsung KNOX, High AOP Mic, Smart View, Live message, Samsung DeX support, Bixby Vision, Secure Folder function, Dual Audio, software updates E-FOTA (Enterprise Firmware Over-the-Air), Samsung Knox Configure, Bixby Routines, Intelligent Performance Enhancer
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, stereo speakers tuned by AKG, Dolby Digital sound
Clock Speed
2.7 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
LPDDR4X SDRAM - 8 GB
Internal Memory Capacity
128 GB
User Memory
107.8 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.9
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Camera Modes
Live Focus mode
Dual Pixel AF
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Dual OIS (Optical Image Stabilisation)
Lens Type
Telephoto lens
Lens Aperture
F/2.4
Field of View (FoV)
45 degree(s)
Pixel Size
1 µm
Focus Adjustment
Automatic, manual
Optical Zoom
2x
Digital Zoom
10x
Special Effects
HDR, Grid Line
Camera Modes
Panorama, Slow motion mode, Pro mode, Timer mode, HYPERLAPSE, Super Slow-mo, AR Emoji, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Motion Photos, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view
Face Detection
Face detection
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, 9.1MP still photos recording 4K video, Shot suggestions, blur detection, HDR10+ recording, Floating shutter button, Super steady
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.5 & f/2.4
Field of View (FoV)
77 degree(s)
Pixel Size
1.4 µm
Dual Pixel AF, OIS (Optical Image Stabilisation)
Third Camera
Sensor Resolution
16 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Display
OLED display
Diagonal Size
6.1"
Display Resolution
3040 x 1440 pixels
Display Format
QHD+
Pixel Density
550 ppi
Colour Depth
16.7 million colours
HDR
HDR Technology
HDR10+
Protection
Always-on display, Edge Screen
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
3400 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging
Wireless Charging
Talk Time
1260 minutes
Run Time Details
Talk (WCDMA): up to 1260 min , Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (video): up to 18 hrs , Playback (audio): up to 81 hrs
VDE, IP68, TUV Rheinland Eye Comfort Certification
Power adapter, SIM card removal tool, USB connector, USB-C cable, headset (tuned by AKG)
