The Galaxy S10 features a large curved-edge screen and puts vault-like security at your fingertips with our new Ultrasonic Fingerprint Scanner. With a front camera and 3 rear cameras featuring an ultra-wide and zoom lens, the Galaxy S10 lets you capture every angle of a scene. It also comes with a battery with so much power you’ll be able to share it with your friends.
Discover an endlessly beautiful screen
Enjoy uninterrupted viewing on the Galaxy S10. The stunning 6.1-inch Infinity-O Display is crafted from flawless glass which wraps from edge to edge, with no home button, no notch for the receiver and a simple dot opening for the front camera.
The superpower to share your power
Introducing PowerShare. Bring your friend’s phone back to life if it’s drained. Stack your Galaxy Watch on top of your Galaxy S10 and charge them at the same time. Or top up your Galaxy Buds when you’re on the move.
Capture every moment as you see it
Capture moments as you see them. With a front camera, 3 rear cameras and the ultra-wide and ultra-zoom lens, the Galaxy S10 lets you shoot every scene just as your eyes see it, even in low light.
Bring video to life
Capture incredible 4K UHD videos with a front-facing camera for the first time on a Samsung Galaxy phone. Achieve super steady footage with the Galaxy S10’s ultra-wide rear camera and intelligent software for smooth filming, even when your journey is on the adventurous side.
Vault like security at your fingertips
Keep your phone secure with the new Ultrasonic Fingerprint Scanner. It reads every ridge and notch of your finger, and because it sits under the screen, your finger won’t accidentally smudge your rear camera ever again. It even performs in low temperatures and strong sunlight.
Designed around you
See only what you need, find focus in what you’re doing and use your phone in a way that feels like second nature. Our new interface, One UI, works with the way you use your phone. Screens are uncluttered, icons pop with colour, and we’ve even made it easier to use one-handed.
Charge when it matters most
Go further and do more. The Galaxy S10 has a battery that will keep you in charge when it matters most. Binge on boxsets or flick through playlists with plenty of power to keep up. And with Wireless Charging 2.0, simply pop your phone on the charging pad (sold separately) for a quick power boost.
Make tasks quicker and smoother
Open apps fast and see the detail in every game you play. The processer in the Galaxy S10 is built to perform and makes tasks quicker and smoother.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
So much screen, so little bezel
A nearly frameless Cinematic Infinity Display allows for deeper, more detailed immersion in your content in a slim, balanced form. -
One UI simplifies the way you use your phone
One UI is designed for how you use your phone: with one hand. Less clutter, less friction, less putting all your stuff down to do something on your phone. -
Cinema-grade display you'll have to see to believe
Immerse yourself in rich tones and amazing contrast in every scene with a HDR10+ certified Infinity screen that delivers clear picture even in bright daylight. -
Completely redesigned to remove interruptions
No notch, no distractions. Precise laser cutting and a Dynamic AMOLED screen that's easy on the eyes make the Infinity Display the most innovative. -
Power is yours to share
Wireless PowerShare lets you charge Galaxy devices or even a friend's phone right from your device. -
Stream and share, wherever life takes you
Intelligent Wi-Fi reaches faster speeds with Wi-Fi, connecting reliably and securely even on public networks. -
A total game changer
Samsung has engineered both hardware and software to give you performance-enhanced gaming with minimal lag. -
Capture the wider world
Use the Ultra Wide Camera to take stunning, cinematic photos with a full field of vision, just like the human eye. -
A smarter camera for better photos
Pro Assist knows what you're looking at and can offer suggestions and adjust settings to help you get epic shots with a tap. -
Daily rituals, elevated
Bixby Routines suggests frequently used apps and tasks based on time or location to develop a naturally smart experience - just for you.
- Samsung Galaxy S10+ - prism white - 4G smartphone - 128 GB - TD-SCDMA / UMTS / GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G975F/DS
- Display
- OLED display - 3040 x 1440 pixels - 6.4" - 522 ppi - 19:9 - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
- Processor
- Exynos 2.7 GHz (8-core) - 64-bit
- Memory
- RAM 8 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Operating System
- Android 9.0 Pie with One UI
- Main Camera
- 12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
- Second Camera
- 16 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 12 Megapixel - wide-angle lens - f/1.5 and f/2.4
- Front Camera
- 10 Megapixel - wide-angle lens - f/1.9 - automatic
- Second Front Camera
- 8 Megapixel - f/2.2 - capture depth information
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT, Wi-Fi 6
- Security Devices
- Fingerprint reader (under display), face recognition
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1500 minutes
- Wireless Charging Standards
- WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, waterproof
- Prism white
- 74.1 mm x 7.8 mm x 157.6 mm
- 175 g
- Specific Absorption Rate (SAR)
- 0.516 W/kg (head) , 1.582 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-G975F/DS
- Form Factor
- Touch
- Protection
- 74.1 mm
- 7.8 mm
- 157.6 mm
- 175 g
- Body Colour
- Prism white
- Body Material
- Gorilla glass 5
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- User Interface
- One UI
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS)
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor, HR sensor
- Security Devices
- Additional Features
- Multi Window, Smart Select, MU-MIMO technology, Samsung KNOX, High AOP Mic, Smart View, Live message, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, stereo speakers tuned by AKG, Dolby Digital sound
- Exynos
- Clock Speed
- 2.7 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- LPDDR4X SDRAM - 8 GB
- Internal Memory Capacity
- 128 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.9
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Camera Modes
- Wide selfie mode, AR Emoji, selfie focus
- Dual Pixel AF
Second Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.2
- 90 degree(s)
- Pixel Size
- 1.12 µm
- Functions
- Capture depth information
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Dual OIS (Optical Image Stabilisation)
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
- 45 degree(s)
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic, manual
- Optical Zoom
- 2x
- Digital Zoom
- 10x
- Self-Timer Delay
- Special Effects
- HDR, Grid Line, Motion photos
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view
- Face Detection
- Face detection
- HDR Mode
- Auto HDR mode
- White Balance
- Custom, automatic
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, 9.1MP still photos recording 4K video, Shot suggestions, AR Emoji, blur detection, HDR10+ recording, Floating shutter button, Super steady
Second Camera
- Sensor Resolution
- 16 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Pixel Size
- 1 µm
Third Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.5 and f/2.4
- 77 degree(s)
- Pixel Size
- 1.4 µm
- Dual Pixel AF
Display
- OLED display
- Technology
- Diagonal Size
- 6.4"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 522 ppi
- Aspect Ratio
- 19:9
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10+
- Protection
- Edge Screen, AOD(Always On Display)
- Connector Type
- USB Type-C - 24 pin USB-C ¦ Headset jack - mini-phone 3.5mm
- Capacity
- 4100 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging
- Wireless Charging
- Talk Time
- 1500 minutes
- Run Time Details
- Talk (WCDMA): up to 1500 hrs , Active online usage (3G): up to 14 hrs , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (video): up to 22 hrs , Playback (audio): up to 101 hrs
- VDE, IP68, TUV Rheinland Eye Comfort Certification
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, headset (tuned by AKG), USB connector (OTG)
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
