Slip on the Galaxy Ring for an easier way to help keep your health on track. Convenient, comfortable and packed with innovations.
Grade A Returned Device
Want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
The style you want, the insights you need
Introducing a Galaxy Ring for all-day wear with an elegant, lightweight design. Crafted from titanium with a scratch-resistant finish, Galaxy Ring combines timeless style with powerful wellness tracking enhanced with Galaxy AI. -
Three sensors, deeper understanding
Galaxy Ring packs health tracking innovations into a compact design that fits comfortably around your finger. -
Tracking on your finger, insights on your phone
Get the ultimate view into a better you. Galaxy Ring tracks your body to deliver a holistic view of your health on your phone. -
Your very own health dashboard
See all your insights at a glance with the Samsung Health app. Think of it as a convenient hub for all your wellness info from sleeping to fitness. -
The sleep tracker of your dreams
Rest easy with the comfortable sleep tracker. You won't even notice while it collects insights on the quality of your sleep. Then get personalized tips and suggestions for how to improve. -
Keep a finger on your pulse
Get a closer read on your body than ever before with improved Heart Rate Tracking from Galaxy Ring. It filters out your body's movement for a more precise reading so you can make informed decisions about your health and wellbeing. -
Ready, set, track
Let Galaxy Ring simplify your workouts. Just hop on the treadmill and start exercising - your Galaxy Ring intuitively starts tracking without you having to lift a finger. -
Less charging, more tracking
Slip it on and forget about it with up to a seven-day charge that won't slow you down. Combined with a full cradle charge, you can use Galaxy Ring for up to 14 days without plugging into an outlet. -
Modern design that shines
With its clear cover, the charging cradle is the place to get your Galaxy Ring ready to take on your week. LED lights help you know how far along Galaxy Ring is in its charging cycle. -
Feels like nothing, goes with everything
From workouts to nights out, sport the Galaxy Ring for any occasion, as it seamlessly blends with your look. -
Not afraid to take a splash
This remarkable design is built for your everyday needs with water resistance and a concave design that minimizes scratches.
- Samsung Galaxy Ring smart ring - 8 MB - titanium silver
- Product Type
- Smart ring
- Manufacturer Model Number
- SM-Q505
- Tracking Data
- Skin temperature, snoring, sleep activity, heart rate, steps taken, calories burned, sleep quality score, activity, female health management, cadence, heart rate variability
- Connectivity
- Bluetooth
- Storage
- 8 MB
- Case
- Titanium (grade 5)
- Input
- Double tap gesture
- Notifications
- High and low heart rate
- Galaxy AI, auto-activity detection, Find my Device, fast charge, Energy Score, Wellness Tips, inactivity alert, camera remote control
- Supported Host Device OS
- Android
- Battery
- Rechargeable 18.5 mAh - Fast Wireless Charging
- Battery Run Time
- Up to 6 day(s)
- Titanium silver
- Ring Size
- 5
- 7 mm x 2.6 mm x 7 mm
- 2.6 g
- Product Type
- Smart ring
- SM-Q505
- Android 11 or later
- Notifications
- Tracking Data
- Ring Size
- 5
- Wearing Style
- Ring
- Titanium silver
- Sensors
- Accelerometer, BioActive sensor, temperature sensor
Storage
- Capacity
- 8 MB
- Wireless Interface
- Bluetooth 5.4 BLE
Input Device
- Rechargeable Battery
- Capacity
- 18.5 mAh
- Wireless Charging
- Wireless Charging Standards
- Run Time (Up To)
- 6 day(s)
- Run Time Details
- Typical usage - up to 6 days
- Details
- Smart ring: 7 mm x 2.6 mm x 7 mm x 2.6 mm , Charging case: 49.9 mm x 49.9 mm x 24.51 mm 61.3 g
- Body Material
- Protection
- Water-resistant, dust-resistant, scratch-resistant
- IP68
- Included Accessories
- Charging case, charging cable
- Max Depth of Water Resistance
- 100 m
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J226 051156 Condition: Customer return - item has been used and shows signs of use tried on too small |
£93.50 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
