Samsung Galaxy Note 9 128GB 6.4" - Ocean Blue
Quicklinx: DQ8RWS00 Mfr#: SM-N960FZBABTU
  • microSDHC
  • Android
Meet the phone made to keep up with you. Our reinvented Bluetooth enabled S Pen allows you to control features remotely up to 10m, while an impressive 128GB of internal storage means you’ll never run out of space. Plus, our most powerful battery yet will keep going as long as you need.
  • Bluetooth enabled S Pen to control features remotely up to 10m
  • 4,000 mAh battery that lasts as long as you need it to
  • Cutting edge processor for super-fast internet
  • 128GB of internal memory means you’ll never run out of room
Rewrite the rules
The redesigned S Pen is unlike any other. Now Bluetooth enabled, use it remotely to take selfies up to 10m away, or as an impressive presentation clicker. And when inspiration strikes, scribble down ideas instantly thanks to the Screen Off Memo feature.
See beyond boundaries
Lose yourself in a large 6.4" Infinity Display with absolutely nothing to interrupt your view. If you’re into movie marathons or boxset binges, this screen was made for you. Plus, it’s easier to multi-task between tabs, split the screen or fully focus on important docs.
Shoot like a pro
The Note9 doesn’t just capture, it sees. The Intelligent Camera detects and adjusts to your surroundings, while Dual Aperture adapts to any lighting. Teamed with Flaw Detection to give you a heads up on blinking or blurring, you’ll shoot perfect pics day or night.
Charge ahead
With a battery that charges faster and lasts longer, the Crown is up for whatever you are. Whether you’ve got back-to-back meetings or you’re heading off on an adventure without a socket in sight, the Crown won’t let you down.
Speed up surfing
The cutting-edge processor is built to thrive off fast internet connections. So you can browse shopping sites, download huge presentations or upload high-resolution videos, all without having to wait around watching spinning wheels.
Store more, delete less
Never have to make those tough deleting decisions again. Thanks to an impressive 128GB of storage, you can keep all the shots, videos and files you want with no worries. You can even top it up with additional 512GB of external memory* to ensure you’ll never be tight for space again.
*External Memory may be used to store media (photos, video and music files) but not applications.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Samsung Galaxy Note9 - Ocean blue - 4G smartphone - 128 GB - TD-SCDMA / UMTS / GSM
4G smartphone
Manufacturer Model Number
SM-N960F
Display
OLED display - 2960 x 1440 pixels - 6.4" - 516 ppi - Quad HD+ Super AMOLED
Heart rate sensor
Samsung Exynos 9 9810 / 2.7 GHz (8-core) - 64-bit
Graphics Accelerator
Mali-G72 MP18
RAM 6 GB / Internal Memory 128 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 8.1 Oreo
Main Camera
12 Megapixel - wide-angle lens - 2x optical zoom - f/1.5 & f/2.4 - focus: automatic
Second Camera
12 Megapixel - telephoto lens - f/2.4
Front Camera
8 Megapixel - wide-angle lens - f/1.7 - automatic
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
Security Devices
Face recognition, fingerprint reader, eye scan
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1740 minutes
Wireless Charging Standards
WPC, PMA
Protection
Dustproof, splashproof, waterproof
Ocean blue
76.4 mm x 8.8 mm x 161.9 mm
201 g
0.381 W/kg (head) , 1.509 W/kg (body)
Smartphone
SM-N960F
Touch
Protection
Integrated Components
Heart rate sensor
76.4 mm
8.8 mm
161.9 mm
201 g
Body Colour
Ocean blue
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 8.1 Oreo
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
Security Devices
Additional Features
S Pen multi-input, Face Unlock, Wi-Fi Miracast, Screen Write, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, Face recognition, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Smart Performance Adjuster, Dual Audio, water-carbon cooling system, S Pen remote function
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, apt-X, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
Samsung Exynos 9
Processor Number
9810
Clock Speed
2.7 GHz
Processor Core Qty
8-core
64-bit Architecture
Graphics System
Mali-G72 MP18
RAM
LPDDR4 SDRAM - 6 GB
Internal Memory Capacity
128 GB
User Memory
108.9 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
8 Megapixel
Sensor Size
1/3.6"
Lens Type
Wide-angle lens
Lens Aperture
F/1.7
Focus Adjustment
Automatic
Special Effects
HDR, Grid Line
Camera Modes
Timer mode, wide selfie mode, selfie mode, AR Emoji, selfie focus
Quick launch, Motion photo, Stamps, location tags, VDIS (Video Digital Image Stabilization), Full view, Flaw detection
Main Camera
Sensor Resolution
12 Megapixel
Sensor Size
1/2.55"
Optical Image Stabiliser
Dual OIS (Optical Image Stabilisation)
Lens Type
Wide-angle lens
Lens Aperture
F/1.5 & f/2.4
Focus Adjustment
Automatic
Optical Zoom
2x
Digital Zoom
10x
Special Effects
HDR, Bokeh effect, Grid Line
Camera Modes
Panorama, Pro mode, Timer mode, HYPERLAPSE, Auto mode, Food mode, Super Slow-mo, AR Emoji, Portraits, Flowers, Indoor scenes, Animals, Landscapes, Greenery, Trees, Sky, Mountains, Beaches, Sunrises and sunsets, Watersides, Street scenes, Night scenes, Waterfalls, Snow, Birds, Backlit, Text, Disney AR Emoji
Face Detection
Face detection
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 2560 x 1440 (QHD) at 30 fps
Quick Launch, Playback zoom, Motion photo, VDIS (Video Digital Image Stabilisation), Live Focus, Dual Capture, High CRI LED flash, Tracking AF, Video location tags, Stamps, location tags, Continuous autofocus video, Hyperlapse video support 1080p, Live focus with bokeh filters, Super Speed Dual Pixel, background blur, Scene Optimiser, Eye blink, Motion blur, Lens smudge, Backlit, Full view, Flaw detection, 9.1MP still photos recording 4K video
Second Camera
Sensor Resolution
12 Megapixel
Sensor Size
1/3.4"
Lens Type
Telephoto lens
Lens Aperture
F/2.4
Display
OLED display
Diagonal Size
6.4"
Display Resolution
2960 x 1440 pixels
Display Format
QHD+
Pixel Density
516 ppi
Colour Depth
16.7 million colours
Always-on display, Edge Screen, Infinity Display, Edge-to-Edge screen
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
4000 mAh
Wireless Charging
WPC, PMA
Talk Time
1740 minutes
Run Time Details
Talk (3G): up to 1740 min , Active online usage (3G): up to 14 hrs , Active online usage (4G): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (audio): up to 59 hrs , Playback (audio (Always On Display Off)): up to 95 hrs , Playback (video): up to 20 hrs
IP68
Power adapter, tweezer, SIM card removal tool, USB connector, USB-C cable, S Pen, Pen nibs, headset (tuned by AKG)
Max Depth of Water Resistance
1.5 m
