Impossibly thin design
High-polish metal and glass meld seamlessly — all in an impressively slim design.
Cinematic Infinity-O Display
With a tiny, front-facing camera lens, the display is a Dynamic AMOLED that's brilliant in all conditions.
Power to get you through your most demanding days
Our cutting-edge battery ensures your Galaxy Note10+ keeps up with your day.
The multi-camera system takes photography to a whole new level
Galaxy Note10 and Note10+ have all the camera essentials, from the dual aperture lens to the Ultra Wide Camera, Live focus and even Scene Optimiser.
Control your device through clicks and gestures
Air actions let you zoom in or out with the camera, change the volume, or flip through photos and more with a simple wave or click.
The screen you can write on when you need it
Take notes and draw on the screen whenever inspiration strikes without opening an app.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Designed to be as beautiful as it is powerful
The effortless, ergonomic grip and lightweight build set a new standard for smartphone design. -
One UI helps you focus on what matters most
Using Galaxy Note10 feels like second nature. Samsung's intuitive, sophisticated One UI interactions are built to give you a simple Galaxy experience. -
On-screen Ultrasonic Fingerprint scanner for vault-like security
Hidden within the screen is the Ultrasonic Fingerprint scanner. It pulses to detect the 3D ridges and valleys of your fingerprint for invisible security. -
Infinity-O Display creates an uninterrupted view
The front camera is tiny and discreetly positioned to minimize interruptions onscreen. And with bezels pushed way back, Samsung has given you a truly epic view. -
A cinema-grade viewing experience on mobile
Enjoy a cinematic experience whether outside in bright daylight or in the dark. It's HDR10+ certified with Dynamic Tone Mapping for playback with tone and contrast true to how it's intended to be seen, so watching HDR10+ content on YouTube is vivid and exciting. -
Eye comfort display reduces eyestrain without sacrificing color
The display lessens eyestrain and sleep disturbance by reducing harmful blue light at the pixel level, without compromising color. -
Super Fast Charging - a 30 minute charge to last all day
Harness 25W of power for a 30 minute power-up that goes all day. Or ditch the cord with Fast Wireless Charging 2.0. -
Wireless PowerShare gives you the power to charge other devices
Place your friend's phone, your Galaxy Buds, or Qi-compatible devices on the back of your phone to start reverse charging. No cables necessary. -
Hybrid SIM keeps you connected and expands your storage
Insert a microSD card for more storage, or swap it out to a second SIM card for dual SIM capability - making you twice as connected with one device. -
Handles your data in the blink of an eye
Stream, game, or download at unbelievable speeds even when multitasking. The intelligent processor also preloads frequently used apps for a fast launch. -
The pro-grade camera that turns everyday photos and videos into epic moments
Samsung packed powerful pro-grade technology in your pocket with the multi-camera system, giving you the power to go from shoot to edit instantly. -
HDR10+ captures the moment the way you saw it
Shoot incredible color and detail in 4K UHD. Experience rich hues and contrast that stay accurate in each scene with HDR10+ and Dynamic Tone Mapping. -
Ultra Wide Camera captures what others miss
Go wide for a 123° field of vision with the 16MP Ultra Wide Camera. Crop in with the 12MP Wide-angle Camera, or get closer with the 2x optical zoom on the 12MP Telephoto Camera. -
Redesigned to put more power at your fingertips
Samsung's most advanced S Pen yet. With an elegant, unibody design, it follows your movements, and writes, draws, and controls longer.
- Samsung Galaxy Note10 - aura black - 4G - 256 GB - TD-SCDMA / UMTS / GSM - smartphone
- Product Type
- Smartphone 4G
- Manufacturer Model Number
- SM-N970F/DS
- Display
- OLED display - 2280 x 1080 pixels - 6.3" - 401 ppi - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
- Processor
- 2.7 GHz (8-core) - 64-bit
- Memory
- 256 GB - RAM 8 GB
- Operating System
- Android 9.0 Pie with One UI
- Rear Camera
- 16 Megapixel - ultra wide-angle lens - 2x optical zoom - f/2.2 - focus: automatic
- Second Rear Camera
- 12 Megapixel - wide-angle lens - f/1.5 and f/2.4
- Third Rear Camera
- 12 Megapixel - telephoto lens - f/2.1
- Front Camera
- 10 Megapixel f/2.2 - automatic
- Service Provider
- Not specified
- SIM Card Type
- (4FF)
- SIM Card Qty
- Dual-SIM
- Wireless Interface
- NFC, Bluetooth, ANT+, Wi-Fi
- Security Devices
- Face recognition, fingerprint reader (under display)
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 1440 minutes
- Wireless Charging Standards
- WPC, PMA, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, waterproof
- Aura black
- 71.8 mm x 7.9 mm x 151 mm
- 168 g
- SAR
- 1.523 W/kg (body), 0.209 W/kg (head)
- 2-year warranty
- Product Type
- Smartphone
- SM-N970F/DS
- Form Factor
- Touch
- Protection
- 71.8 mm
- 7.9 mm
- 151 mm
- 168 g
- Body Colour
- Aura black
- SAR Value
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- User Interface
- One UI
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, Bluetooth 5.0 LE, ANT+, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
- Security Devices
- Additional Features
- S Pen multi-input, Face Unlock, Wi-Fi Miracast, Screen mirroring, Screen Write, Smart Select, MU-MIMO technology, Samsung KNOX, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Secure Folder function, Dual Audio, S Pen remote function, Bixby Routines, Intelligent Performance Enhancer, AR Doodle, PENUP
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, apt-X, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
- Clock Speed
- 2.7 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 8 GB
- Internal Memory Capacity
- 256 GB
- User Memory
- 224.6 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Special Effects
- HDR, Grid Line
- Camera Modes
- Timer mode, wide selfie mode, selfie mode, Live Focus mode, AR Emoji, selfie focus, Live focus video
- Quick launch, Motion photo, Stamps, location tags, VDIS (Video Digital Image Stabilization), Full view, Flaw detection, Dual Pixel AF
Rear Camera
- Sensor Resolution
- 16 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic
- Optical Zoom
- 2
- Digital Zoom
- 10
- Special Effects
- HDR, Grid Line
- Camera Modes
- Panorama, Pro mode, Timer mode, HYPERLAPSE, Super Slow-mo, AR Emoji, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Motion Photos, Food, Baby, Person, Dog, Cat, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Night, Mountain
- Face Detection
- Face detection
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Quick Launch, Playback zoom, Motion photo, blink detection, VDIS (Video Digital Image Stabilisation), Live Focus, High CRI LED flash, Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, Shot suggestions, blur detection, HDR10+ recording, Floating shutter button, Super steady, Quick Measure, 9.1MP still photos recording 4K UHD, Zoom-In Mic
Second Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.5 and f/2.4
- 77 degree(s)
- Pixel Size
- 1.4 µm
- OIS (Optical Image Stabilisation), Super Speed Dual Pixel AF
Third Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.1
- 45 degree(s)
- Pixel Size
- 1 µm
- OIS (Optical Image Stabilization), Phase Detect Auto-Focus (PDAF)
Display
- OLED display
- Technology
- Diagonal Size
- 6.3"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 401 ppi
- Max Brightness
- 1200 cd/m²
- Colour Depth
- 16.7 million colours
- HDR
- Contrast Ratio
- 2000000:1
- Protection
- Edge Screen, DCI-P3 Wide colour gamut, Infinity Display, Edge-to-Edge screen, HDR10+, AOD(Always On Display), Edge Lighting
- Connector Type
- USB Type-C
- Capacity
- 3500 mAh
- Fast Charging Technology
- Samsung Super Fast Charging 2.0
- Wireless Charging
- Talk Time
- 1440 minutes
- Run Time Details
- Talk (4G): up to 1440 min , Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 15 hrs , Playback (wireless audio): up to 50 hrs , Playback (wireless video): up to 17 hrs
- VDE, IP68, HAC (Hearing Aid Compatible), TUV Rheinland Eye Comfort Certification
- Included Accessories
- Power adapter, tweezer, SIM card removal tool, USB-C cable, S Pen, Pen nibs, Earphones (USB Type-C) with sound by AKG
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
