Samsung Galaxy Note 10+ 5G 512GB - Aura Black
Quicklinx: FC29WS00 Mfr#: SM-N976BZKEBTU
Operating system: Android
Model: Note10+ 5G
Screen Size: 6.8in
Rear Camera: 16 Megapixel
Mobile Connectivity: 5G
  • microSDHC
  • Android
39 in stock
£999.17 ex VAT
£1,199.00 inc VAT
Impossibly thin design
High-polish metal and glass meld seamlessly — all in an impressively slim design.
Cinematic Infinity-O Display
With a tiny, front-facing camera lens, the display is a Dynamic AMOLED that's brilliant in all conditions.
Power to get you through your most demanding days
Our cutting-edge battery ensures your Galaxy Note10+ keeps up with your day.
The multi-camera system takes photography to a whole new level
Galaxy Note10 and Note10+ have all the camera essentials, from the dual aperture lens to the Ultra Wide Camera, Live focus and even Scene Optimiser.
Control your device through clicks and gestures
Air actions let you zoom in or out with the camera, change the volume, or flip through photos and more with a simple wave or click.
The screen you can write on when you need it
Take notes and draw on the screen whenever inspiration strikes without opening an app.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Impossibly thin design
    High-polish metal and glass meld seamlessly - all in an impressively slim design.
  • Cinematic display
  • All-day battery lasts as long as you do
    Superior intelligence recognizes and adjusts to your mobile habits to outlast the day.
  • Engineered for gaming, perfected for gamers
    The vapor chamber cooling system, improved AI, and enhanced NPU provide you with a smooth gaming experience with reduced lag, even when the game heats up.
  • Pro-grade camera that turns everyday photos and videos into epic moments
    Samsung packed a powerful pro-grade technology in your pocket with the multi-camera system, giving you the power to go from shoot to edit instantly.
  • Special effects for mobile video
    Blur out the backgrounds with video bokeh for movie-like depth of field and add special effects in real time to capture artistic moments that stand out.
  • Zoom-in mic lets you record the sounds you want
    Control the sound around you as you zoom in or out, giving you the power to capture the sound that matters.
  • Super steady makes action shots smooth and natural
    Get high-motion video without the motion sickness. The camera predicts movement by pulling from a library of over a million frames, reducing vibrations in your videos.
  • Air actions give you intuitive control with a wave of your hand
    Samsung re-engineered S Pen to match your movements, allowing you to control your phone via simple gestures.
  • Hyper-fast 5G
    Experience low latency and minimal lag with 5G. And with intelligent Wi-Fi, connect safely and quickly even in a crowded space.
Samsung Galaxy Note10+ 5G - aura black - 5G - 512 GB - TD-SCDMA / UMTS / GSM - smartphone
Smartphone 5G
Manufacturer Model Number
SM-N976B
Display
OLED display - 3040 x 1440 pixels - 6.8" - 498 ppi - Infinity-O Dynamic AMOLED - HDR
Front-facing camera, heart rate sensor, stereo speakers, digital player, quad rear-facing camera
Samsung Exynos 9 9825 / 2.7 GHz (8-core) - 64-bit
512 GB RAM 12 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
Android 9.0 Pie
Rear Camera
16 Megapixel - ultra wide-angle lens - 2x optical zoom - f/2.2 - focus: automatic
Second Rear Camera
12 Megapixel - telephoto lens - f/1.5 & f/2.4
Third Rear Camera
12 Megapixel - f/2.1
Fourth Rear Camera
0.3 Megapixel - depth camera
Front Camera
10 Megapixel f/2.2 - automatic
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Wireless Interface
NFC, Bluetooth, ANT+, Wi-Fi
Security Devices
Face recognition, fingerprint reader (under display)
Messaging Services
SMS, MMS
Connectors
USB-C
Talk Time
Up to 1680 minutes
Wireless Charging Standards
WPC, PMA
Protection
Dustproof, splashproof, waterproof
Aura black
77.2 mm x 7.9 mm x 162.3 mm
198 g
SAR
1.404 W/kg (body), 0.187 W/kg (head)
Smartphone
SM-N976B
Touch
Protection
Integrated Components
Front-facing camera, voice recorder, heart rate sensor, stereo speakers, navigation, digital player, quad rear-facing camera
77.2 mm
7.9 mm
162.3 mm
198 g
Body Colour
Aura black
SAR Value
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 9.0 Pie
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA, 5G NR FR1
2G Band
GSM 850/900/1800/1900 / TD-SCDMA 1880/2010
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N78
5G NR Frequency
TDD TD 3500
Wireless Interface
NFC, Bluetooth 5.0 LE, ANT+, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
Security Devices
Additional Features
S Pen multi-input, Face Unlock, Wi-Fi Miracast, Screen Write, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, Face recognition, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Smart Performance Adjuster, Dual Audio, water-carbon cooling system, S Pen remote function
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, apt-X, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
Samsung Exynos 9
Processor Number
9825
Clock Speed
2.7 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
12 GB
Internal Memory Capacity
512 GB
User Memory
461.4 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Special Effects
HDR, Grid Line
Camera Modes
Timer mode, wide selfie mode, selfie mode, Live Focus mode, AR Emoji, selfie focus, Live focus video
Quick launch, Motion photo, Stamps, location tags, VDIS (Video Digital Image Stabilization), Full view, Flaw detection, Dual Pixel AF
Rear Camera
Sensor Resolution
16 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Pixel Size
1 µm
Focus Adjustment
Automatic
Optical Zoom
2
Digital Zoom
10
Special Effects
HDR, Bokeh effect, Grid Line
Camera Modes
Panorama, Pro mode, Timer mode, HYPERLAPSE, Auto mode, Food mode, Super Slow-mo, AR Emoji, Portraits, Flowers, Indoor scenes, Animals, Landscapes, Greenery, Trees, Sky, Mountains, Beaches, Sunrises and sunsets, Watersides, Street scenes, Night scenes, Waterfalls, Snow, Birds, Backlit, Text, Disney AR Emoji
Face Detection
Face detection
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Quick Launch, Playback zoom, Motion photo, VDIS (Video Digital Image Stabilisation), Live Focus, Dual Capture, High CRI LED flash, Tracking AF, Video location tags, Stamps, location tags, Continuous autofocus video, Hyperlapse video support 1080p, Live focus with bokeh filters, Super Speed Dual Pixel, background blur, Scene Optimiser, Eye blink, Motion blur, Lens smudge, Backlit, Full view, Flaw detection, 9.1MP still photos recording 4K video, Super Speed Dual Pixel AF
Second Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Telephoto lens
Lens Aperture
F/1.5 & f/2.4
Pixel Size
1.4 µm
OIS (Optical Image Stabilisation)
Third Rear Camera
Sensor Resolution
12 Megapixel
Lens Aperture
F/2.1
Field of View (FoV)
45 degree(s)
Pixel Size
1 µm
OIS (Optical Image Stabilization), Phase Detect Auto-Focus (PDAF)
Fourth Rear Camera
Sensor Resolution
0.3 Megapixel
Functions
Depth camera
Display
OLED display
Diagonal Size
6.8"
Display Resolution
3040 x 1440 pixels
Display Format
QHD+
Pixel Density
498 ppi
Max Brightness
1200 cd/m²
Colour Depth
16.7 million colours
HDR
Contrast Ratio
2000000:1
Always-on display, Edge Screen, DCI-P3 Wide colour gamut, Infinity Display, Edge-to-Edge screen, HDR10+
Connector Type
USB Type-C
4300 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Samsung Super Fast Charging 2.0
Wireless Charging
WPC, PMA
Talk Time
1680 minutes
Run Time Details
Talk (4G): up to 1680 min , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (audio): up to 61 hrs , Playback (video): up to 19 hrs
IP68
Power adapter, tweezer, SIM card removal tool, USB-C cable, S Pen, Pen nibs, clear cover case, protective film, Earphones (USB Type-C) with sound by AKG
Max Depth of Water Resistance
1.5 m
Model: Note10+ 5G
Screen Size: 6.8in
Brand: Samsung
Price Range Ex VAT: 750 - 1000
