There is never been an easier way to make a call when you are on the move. You can place and answer calls, or even record a voice memo, directly from your Samsung Galaxy Gear. It is the simple way to keep up when you have a lot going on.
Phone on your wrist
There is never been an easier way to make a call when you are on the move. You can place and answer calls, or even record a voice memo, directly from your Samsung Galaxy Gear. It is the simple way to keep up when you have a lot going on. -
A more intelligent way to interact
When you get a notification on your Galaxy Gear that requires a more in-depth look, the moment you pick up your Galaxy phone, smart relay automatically opens the app that corresponds with what is on your wrist. -
Lock it down
No need to worry about keeping your sensitive information private. Auto lock is easy to set up, and intuitively senses when you have walked more than five feet away from your Galaxy Note 3, then automatically secures your phone for you. And when you return, your phone is automatically unlocked - no PIN required.
- Samsung Galaxy Gear smart watch - 4 GB - wild orange
- Product Type
- Smart watch
- Tracking Data
- Distance, calories burned, activity, steps taken
- Connectivity
- NFC, Bluetooth
- Display
- Super AMOLED - 1.63" - 320 x 320 pixels
- Storage
- 4 GB
- Case
- Stainless steel
- Camera
- 1.9 Megapixel
- Input
- Touch screen
- Notifications
- Missed calls
- Call handling, hands-free, auto focus, macro, BSI sensor, Sound & Shot, Text-to-Speech (text recognition), Smart Relay
- Battery
- Lithium Ion - 315 mAh
- Battery Run Time
- Up to 25 hours
- Wild orange
- 36.8 mm x 11.1 mm x 56.6 mm
- 73.8 g
- Designed For
- Galaxy Note 3
- Product Type
- Smart watch
- Supported Mobile Messaging Services
- SMS
- Notifications
- Missed calls
- Messaging Services
- LINE, SMS
- Tracking Data
- Digital Player
- MPEG-4, H.264 AAC, M4A
- Audio Input
- 2 microphones
- Audio Output
- Speaker
- Wild orange
- Sensors
- Accelerometer, pedometer, gyro sensor, gesture
Storage
- Capacity
- 4 GB
Display
- Super AMOLED - colour
- Resolution
- 320 x 320 pixels
- Diagonal Size
- 1.63"
Camera
- Sensor Resolution
- 1.9 Megapixel
- Videos
- 1280 x 720 (720p)
- Wireless Interface
- NFC, Bluetooth 4.0
Input Device
- Touch sensitive screen
CPU
- Clock Speed
- 800 MHz
RAM
- Size
- 512 MB
- Technology
- Lithium Ion
- Capacity
- 315 mAh
- Run Time (Up To)
- 25 hours
- Standby Time
- 150 h
- 36.8 mm
- 11.1 mm
- 56.6 mm
- 73.8 g
- Preloaded Software
- Clock, Stopwatch, Contacts, Voice Memo, Camera, Dialer, Samsung Apps, Gallery, Weather, TripIt, S Voice, Timer, Samsung ChatON, eBay, Find my device, Evernote watch, Atooma, Banjo, Glympse, MyFitnessPal, Vivino Wine Scanner, RunKeeper, Path, Pocket
- System Requirements for PC Connection
- Microsoft Windows XP SP3 or later
- Vibrating Alert
- Body Material
- Stainless steel
- Designed For
- Samsung Galaxy Note 3
