Samsung Galaxy Gear SmartWatch - Orange
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9FD1WS00 Mfr#: SM-V7000ZOABTU
There is never been an easier way to make a call when you are on the move. You can place and answer calls, or even record a voice memo, directly from your Samsung Galaxy Gear. It is the simple way to keep up when you have a lot going on.
  • Phone on your wrist
  • A more intelligent way to interact
    When you get a notification on your Galaxy Gear that requires a more in-depth look, the moment you pick up your Galaxy phone, smart relay automatically opens the app that corresponds with what is on your wrist.
  • Lock it down
    No need to worry about keeping your sensitive information private. Auto lock is easy to set up, and intuitively senses when you have walked more than five feet away from your Galaxy Note 3, then automatically secures your phone for you. And when you return, your phone is automatically unlocked - no PIN required.
Samsung Galaxy Gear smart watch - 4 GB - wild orange
Smart watch
Tracking Data
Distance, calories burned, activity, steps taken
NFC, Bluetooth
Display
Super AMOLED - 1.63" - 320 x 320 pixels
Storage
4 GB
Case
Stainless steel
Camera
1.9 Megapixel
Input
Touch screen
Notifications
Missed calls
Call handling, hands-free, auto focus, macro, BSI sensor, Sound & Shot, Text-to-Speech (text recognition), Smart Relay
Lithium Ion - 315 mAh
Battery Run Time
Up to 25 hours
Wild orange
36.8 mm x 11.1 mm x 56.6 mm
73.8 g
Galaxy Note 3
Smart watch
Supported Mobile Messaging Services
SMS
Notifications
Missed calls
Messaging Services
LINE, SMS
Tracking Data
Digital Player
MPEG-4, H.264 AAC, M4A
Audio Input
2 microphones
Audio Output
Speaker
Wild orange
Sensors
Accelerometer, pedometer, gyro sensor, gesture
Storage
4 GB
Display
Super AMOLED - colour
Resolution
320 x 320 pixels
Diagonal Size
1.63"
Camera
Sensor Resolution
1.9 Megapixel
Videos
1280 x 720 (720p)
Wireless Interface
NFC, Bluetooth 4.0
Input Device
Touch sensitive screen
CPU
Clock Speed
800 MHz
RAM
Size
512 MB
Lithium Ion
315 mAh
Run Time (Up To)
25 hours
Standby Time
150 h
36.8 mm
11.1 mm
56.6 mm
73.8 g
Preloaded Software
Clock, Stopwatch, Contacts, Voice Memo, Camera, Dialer, Samsung Apps, Gallery, Weather, TripIt, S Voice, Timer, Samsung ChatON, eBay, Find my device, Evernote watch, Atooma, Banjo, Glympse, MyFitnessPal, Vivino Wine Scanner, RunKeeper, Path, Pocket
System Requirements for PC Connection
Microsoft Windows XP SP3 or later
Vibrating Alert
Body Material
Stainless steel
Samsung Galaxy Note 3
