The front and rear lenses each capture 180 degrees horizontally and vertically, creating a seamless and complete 360-degree field of view. Sometimes a concentrated view of the world is enough to tell the full story. Use just one of the two lenses to capture a striking wide-angled view either in video or stills.
Compatable with Samsung Galaxy S6, S6 edge, S6 edge+, Note 5, S7, S7 Edge with Samsung Gear Manager 360 app & PCs with the Gear 360 ActionDirector Software
Redefine what a phone can do
Capture some of the best times of your life with Gear 360 and relive the moments through your Gear VR and Galaxy smartphone. -
Real 360º
From the little moments in your day to the horizons you pursue, capture life as it happens with Gear 360. -
The world through dual lens
The front and rear lenses each capture 180 degrees horizontally and vertically, creating a seamless and complete 360-degree field of view. -
Single lens mode
Sometimes a concentrated view of the world is enough to tell the full story. Use just one of the two lenses to capture a striking wide-angled view either in video or stills. -
High resolution details
Whether you're celebrating your best friend's birthday or breaking out some new moves, every single experience is recorded in 3840 x 1920 high resolution video and 25.9MP Photos. -
Outdoor-friendly
Just slip the Gear 360 into your bag as you head outside. From camping to dining alfresco, the dust and splash resistant Gear 360 can take on your world. -
Seamless connection
Pair up your Galaxy smartphone via Bluetooth, then use Wi-Fi Direct to transform its large screen into a very handy remote viewfinder and to transfer files in one simple move.
- Samsung GALAXY Gear 360 - action camera
- Product Type
- Action camera - 4K
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Image Processor
- DRIMeVs
- Sensors
- Accelerometer, gyro sensor
- Wireless Interface
- NFC, Wi-Fi, Bluetooth
- Sensor Resolution
- 2 x 15.0 MP
- Max Video Resolution
- 3840 x 1920
- Lens System
- 2 x fisheye lens f/2.0
- Lens System (2nd)
- Fisheye lens - f/2.0
- Focus Adjustment
- Focus free
- Supported Battery
- 1350 mAh (included)
- Interface
- USB 2.0
- White
- 6.67 cm x 5.63 cm x 6.01 cm
- 152 g
- Product Type
- Enclosure Colour
- White
- Sensor Resolution
- 2 x
- Camcorder Sensor Resolution
- 15.0 MP
- Camcorder Interpolated Photo Resolution
- 30.0 MP
- 360° Camera
- Optical Sensor Type
- Dual CMOS
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 30 fps
- Image Processor
- DRIMeVs
- Sensors
- Digital Video Format
- H.265
- Image Recording Format
- JPEG
- 3840 x 1920
- Interface
- USB 2.0, NFC (Near Field Communication), IEEE 802.11a/b/g/n/ac, Bluetooth 4.1
- Connectivity Features
- Remote control via mobile devices, remote live view, Wireless Image Transfer
Lens System
- 2 x fisheye lens f/2.0 - fisheye
- Focus Adjustment
- Focus free
- Max View Angle
- 180 degree(s)
Lens System (2nd)
- Focus Adjustment
- Focus free
Additional Features
- Additional Features
- Time-Lapse recording, Loop recording, 360° spherical capture
Action Camera Features
- Camera Type
- Mountable
360° Camera
- Optical Sensor Qty
- 2
- Connector Type
- USB 2.0
- Protection
- Splashproof, dust-resistant
- Battery Type
- Manufacturer-specific
- Details
Memory / Storage
- RAM Installed
- 1 GB
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 200 GB
- 6.67 cm
- 5.63 cm
- 6.01 cm
- 152 g
