Grade A
Grade A returned device.
- Sold 'as good as new'
- Can be used on any network
- 6 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Sealed package
- No Galaxy Buds in the box
Galaxy Fold
A device unlike any before. Galaxy Fold 5G doesn't just change the face of the smartphone, it changes the face of tomorrow.
Today, we introduce the biggest breakthrough since the mobile phone. Today, the future unfolds with Galaxy Fold 5G.
A new dawn in display technology: the foldable Infinity Flex Display
A stunning 7.3-inch Dynamic AMOLED display that defies expectations. Made of a revolutionary polymer material layered for slim flexibility, it's the largest Galaxy smartphone screen yet. (You may notice a crease at the center of the main screen, which is a natural characteristic of the screen.)
The articulated spine makes folding smooth and graceful.
An engineering marvel, inspired by the precision of watch mechanics, the hinge delivers symmetrical movement that gently locks in place. So Galaxy Fold 5G intuitively folds like a book.
Take full advantage of the unfolded display with Multi Active Window
The Galaxy Fold is pioneering the seamless integration of hardware and software for a foldable device. Use up to three apps simultaneously and revolutionise the way you multitask.
Capture it all, no matter how you hold it.
With six state-of-the-art cameras, you'll be able to capture stunning photos and videos. And you can use the Infinity Flex Display as a massive viewfinder.
The future of speed and storage.
Featuring 12GB of RAM for intensive multitasking — from gaming to streaming, and even live broadcasting, all at once. Plus, 512GB built-in storage is ample space for your apps and media.
The dual cell battery delivering smarter power.
The dual cell battery with 4235mAh (typical) capacity is a game changer that uses and recharges both cells to prevent overcharging. To save power, intelligent battery management puts apps you’re not using on reserve.
The foldable Infinity Flex display
A stunning AMOLED display defies expectations. Made of a revolutionary polymer material layered for slim flexibility, it's an incredibly large Galaxy smartphone screen. -
The articulated spine makes folds smooth and graceful
An engineering marvel inspired by the precision of watch mechanics, the hinge delivers symmetrical movement that gently locks in place. So the Galaxy Fold intuitively folds like a book. -
Hold the future in one hand
When folded, the Galaxy Fold's slim silhouette slips easily into your bag or pocket. It also fits comfortably in your hand, putting all your apps within easy reach. -
A seamless experience from the outside in
As you unfold, the Galaxy Fold's displays work together seamlessly with impressive app continuity. -
A breakthrough in multitasking
The Galaxy Fold provides the seamless integration of hardware and software for a foldable device. Use up to three apps simultaneously - you can stream, game, and even text all at once. -
With six pro-grade cameras, you're sure to capture stunning photos and videos. And you can use the Infinity Flex Display as a massive viewfinder. -
The dual battery delivering smarter power
The dual battery is a game-changer that uses and recharges both cells to prevent overcharging. To save power, intelligent battery management puts apps you're not using on reserve.
- Samsung Galaxy Fold 5G - Space Silver - 5G - 512 GB - TD-SCDMA / UMTS / GSM - smartphone
- Product Type
- Smartphone 5G
- Manufacturer Model Number
- SM-F907B
- Display
- OLED display - 2152 x 1536 pixels - 7.3" - 362 ppi - 4.2:3 - Infinity Flex Dynamic AMOLED - HDR
- Display (2nd)
- OLED display - colour - 4.6"
- Stereo speakers, digital player, triple rear-facing camera, triple front-facing camera
- Processor
- 2.8 GHz (8-core) - 64-bit
- Memory
- 512 GB RAM 12 GB
- Operating System
- Android 9.0 Pie
- Rear Camera
- 16 Megapixel - ultra wide-angle lens - 2x optical zoom - f/2.2 - focus: automatic, manual
- Second Rear Camera
- 12 Megapixel - wide-angle lens - f/1.5-2.4
- Third Rear Camera
- 12 Megapixel - telephoto lens - f/2.4
- Front Camera
- 10 Megapixel f/2.2
- Second Front Camera
- 8 Megapixel - RGB Depth Camera
- Third Front Camera
- 10 Megapixels - f/2.2
- Service Provider
- Not specified
- Form Factor
- Folder - touch screen, dual screen
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Wireless Interface
- NFC, Bluetooth, ANT+/ANT, Wi-Fi
- Security Devices
- Face recognition, fingerprint reader (side)
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 2640 minutes
- Wireless Charging Standards
- WPC, PMA, Qi, Fast Wireless Charging, Wireless PowerShare
- Space Silver
- 62.8 mm x 17.1 mm x 160.9 mm
- 276 g
- SAR
- 1.267 W/kg (body) / 0.542 W/kg (head)
- SM-F907B
- Form Factor
- Integrated Components
- Voice recorder, stereo speakers, navigation, digital player, triple rear-facing camera, triple front-facing camera
- 62.8 mm
- 17.1 mm
- 160.9 mm
- 276 g
- Dimensions Details
- Folded - 62.8 mm x 17.1 mm x 160.9 mm , Unfolded - 117.9 mm x 6.9 mm x 160.9 mm
- Body Colour
- Space Silver
- SAR Value
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
- Supported Social Networks and Blogs
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, LAA, 5G NR FR1
- 2G Band
- GSM 850/900/1800/1900 / TD-SCDMA 1880/2010
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N78
- 5G NR Frequency
- TDD TD 3500
- NFC, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Multitasking, MU-MIMO technology, Samsung KNOX, High AOP Mic, Smart View, Samsung DeX support, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, dual battery
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, stereo speakers tuned by AKG, Dolby Digital sound
- Clock Speed
- 2.8 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 12 GB
- Internal Memory Capacity
- 512 GB
- User Memory
- 460.5 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.2
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Camera Modes
- Live Focus mode, AR Emoji
Second Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/1.9
- 85 degree(s)
- Pixel Size
- 1.12 µm
- Functions
- RGB Depth Camera
Third Front Camera
- Sensor Resolution
- 10 Megapixels
- Lens Aperture
- F/2.2
- 80 degree(s)
- Pixel Size
- 1.22 µm
Rear Camera
- Sensor Resolution
- 16 Megapixel
- Optical Image Stabiliser
- Dual OIS (Optical Image Stabilisation)
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic, manual
- Optical Zoom
- 2
- Digital Zoom
- 10
- Self-Timer Delay
- Special Effects
- HDR, Grid Line, Motion photos
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view
- Face Detection
- Face detection
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Quick Launch, Playback zoom, blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Lens smudge, Full view, Flaw detection, 9.1MP still photos recording 4K video, Shot suggestions, AR Emoji, blur detection, HDR10+ recording, Floating shutter button, Super steady, backlighting detection
Second Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.5-2.4
- 77 degree(s)
- Pixel Size
- 1.4 µm
- OIS (Optical Image Stabilisation), Super Speed Dual Pixel AF
Third Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
- 45 degree(s)
- Pixel Size
- 1 µm
- OIS (Optical Image Stabilization), Phase Detect Auto-Focus (PDAF)
Display
- OLED display
- Technology
- Diagonal Size
- 7.3"
- Display Resolution
- Display Format
- QXGA+
- Pixel Density
- 362 ppi
- Aspect Ratio
- 4.2:3
- Colour Depth
- 16.7 million colours
- HDR
- HDR10+, AOD(Always On Display), flex screen
Display (2nd)
- Diagonal Size
- 4.6"
- 1680 x 720 pixels
- Colour Depth
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 4235 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging
- Wireless Charging
- Talk Time
- 2640 minutes
- Run Time Details
- Active online usage (LTE): up to 12 hrs , Active online usage (Wi-Fi): up to 12 hrs , Playback (wireless video): up to 19 hrs , Playback (wireless audio): up to 73 hrs , Talk (LTE): up to 2640 min
- HAC (Hearing Aid Compatible)
- Included Accessories
- USB adapter, USB cable, power adapter, SIM card removal tool, cover
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FT2Z 043554 Condition: Customer return - item has been opened but is in excellent condition |
£712.80 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
