Samsung Galaxy Chromebook Go WiFi Grade A
Quicklinx: HTJ7WS00 Mfr#: XE310XDA-KA1UK/GRADEA
Screen Size: 11.6in
Processor Model: 1005M
Operating System: Google Chrome OS
Hard Drive Capacity: 64GB
Graphics: Intel UHD Graphics
  • Celeron
  • IEEE 802.11n
£124.17 ex VAT
£149.00 inc VAT
Express delivery Order within the next 16 hours for delivery on Monday
Backpack, meet your new best friend. With its slim design, Galaxy Chromebook Go is an incredibly light Chromebook yet, making it perfect for busy lives on the go. With a 14" screen and weighing 3.2 lbs., this Chromebook helps you stay light and fast on your feet by not weighing you down. Plus, Galaxy Chromebook Go is easy to use and ready for action - simply unpack it, turn it on and you're ready.
Grade A Returned Device Looking for your next phone, tablet, or Laptop, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
  • Can be used on any network
  • 12 months warranty
  • Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
  • Re-sealed, original packaging
  • Skillfully designed and military tough
    Go ahead, do you - Galaxy Chromebook Go is built to withstand the inevitable hiccups that come with everyday life. Made with a military-grade design, your Galaxy Chromebook Go is carefully built to be durable - it's even strong enough to withstand the occasional drop, ding or spill. Open and close the lid with confidence - the hinge is built to take it too. Plus, the hinge features a 180-degree design that gives you multiple viewing angles to fully enjoy your Galaxy Chromebook Go.
  • All-day, all-in-one charging
    Always on the lookout for a power outlet? No longer. Now you can breeze through your schoolwork with plenty of power left for some me time - the battery goes for up to 12 hours on a single charge. Plus, say goodbye to that tangled knot of cords in your bag with a universal charger. Conveniently power up your many Samsung devices, including your Chromebook, phone, tablet and buds, all on the same charger.
  • Wi-Fi 6: three times faster than the previous generation of Wi-Fi
    Blaze through every assignment, and hit every due date with fast Wi-Fi speed. Three times faster than the previous generation of Wi-Fi, Wi-Fi 6 gives you the speed you need for all of your tasks - whether personal or school-related - so you can own the day while staying at the top of your class.
Samsung Galaxy Chromebook Go - 11.6" - Intel Celeron - N4500 - 4 GB RAM - 64 GB eMMC
Chromebook - 180-degree hinge design
Operating System
Chrome OS
Intel Celeron N4500 / 1.1 GHz, up to 2.8 GHz
4 GB LPDDR4X (provided memory is soldered)
Storage
64 GB eMMC
Display
11.6" LED backlight 1366 x 728 / HD
Graphics
Intel UHD Graphics
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1
Up to 11 hours
Security
Trusted Platform Module (TPM) Security Chip
28.79 cm x 20.23 cm x 1.59 cm
1.06 kg
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Cache
L3
RAM
4 GB (provided memory is soldered)
LPDDR4X SDRAM
Storage
Main Storage
64 GB eMMC
Display
11.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 728 (HD)
Widescreen
Anti-glare
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Video Resolutions
720p
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Communications
Wireless
Dual stream (2x2)
40.2 Wh
Run Time
Up to 11 hours
AC Adapter
Output
45 Watt
Connections & Expansion
Slots
1 x microSD
Interfaces Details
USB-C , USB 3.2 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
45W USB-C power adapter
MIL-STD 810G
1.06 kg
Sustainability Information
TCO Certified
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HTJ7 050605
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £81.69
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Screen Size: 11.6in
Brand: Samsung
Stock Status: While stocks last
Stock Status: Used Stock
Stock Status: Clearance
