Backpack, meet your new best friend. With its slim design, Galaxy Chromebook Go is an incredibly light Chromebook yet, making it perfect for busy lives on the go. With a 14" screen and weighing 3.2 lbs., this Chromebook helps you stay light and fast on your feet by not weighing you down. Plus, Galaxy Chromebook Go is easy to use and ready for action - simply unpack it, turn it on and you're ready.
Grade A Returned Device Looking for your next phone, tablet, or Laptop, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
- Can be used on any network
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
Skillfully designed and military tough
Go ahead, do you - Galaxy Chromebook Go is built to withstand the inevitable hiccups that come with everyday life. Made with a military-grade design, your Galaxy Chromebook Go is carefully built to be durable - it's even strong enough to withstand the occasional drop, ding or spill. Open and close the lid with confidence - the hinge is built to take it too. Plus, the hinge features a 180-degree design that gives you multiple viewing angles to fully enjoy your Galaxy Chromebook Go. -
All-day, all-in-one charging
Always on the lookout for a power outlet? No longer. Now you can breeze through your schoolwork with plenty of power left for some me time - the battery goes for up to 12 hours on a single charge. Plus, say goodbye to that tangled knot of cords in your bag with a universal charger. Conveniently power up your many Samsung devices, including your Chromebook, phone, tablet and buds, all on the same charger. -
Wi-Fi 6: three times faster than the previous generation of Wi-Fi
Blaze through every assignment, and hit every due date with fast Wi-Fi speed. Three times faster than the previous generation of Wi-Fi, Wi-Fi 6 gives you the speed you need for all of your tasks - whether personal or school-related - so you can own the day while staying at the top of your class.
- Samsung Galaxy Chromebook Go - 11.6" - Intel Celeron - N4500 - 4 GB RAM - 64 GB eMMC
- Product Type
- Chromebook - 180-degree hinge design
- Operating System
- Chrome OS
- Processor
- Intel Celeron N4500 / 1.1 GHz, up to 2.8 GHz
- Memory
- 4 GB LPDDR4X (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 11.6" LED backlight 1366 x 728 / HD
- Graphics
- Intel UHD Graphics
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Battery
- Up to 11 hours
- Security
- Trusted Platform Module (TPM) Security Chip
- 28.79 cm x 20.23 cm x 1.59 cm
- 1.06 kg
- Limited warranty - 2 years
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.8 GHz
- Cache
- L3
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR4X SDRAM
Storage
- Main Storage
- 64 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 728 (HD)
- Widescreen
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Video Resolutions
- 720p
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
Communications
- Wireless
- Dual stream (2x2)
- Capacity
- 40.2 Wh
- Run Time
- Up to 11 hours
AC Adapter
- Output
- 45 Watt
Connections & Expansion
- Slots
- 1 x microSD
- Interfaces Details
- USB-C , USB 3.2 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- 45W USB-C power adapter
- MIL-STD 810G
- 1.06 kg
Sustainability Information
- TCO Certified
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HTJ7 050605 Condition: Customer return - item has been repaired under warranty by the manufacturer |
£89.31 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
