Samsung Galaxy Buds2 Pro - Graphite
Quicklinx: H1YRWS00 Mfr#: SM-R510NZAAEUA
Every note sounds like the real thing because clear audio starts at the source with your favorite Samsung Galaxy device. The Samsung Seamless Codec encodes the full 24-bit audio to decode on the Galaxy Buds2 Pro, maintaining that same 24-bit high-quality sound.
With 3 high SNR (Signal-to-Noise Ratio) microphones, the Galaxy Buds2 Pro tracks and eliminates more outside sound - even soft sounds like wind.
Simply start talking and Voice Detect will turn off ANC and activate Ambient sound - allowing you to clearly hear the conversation without removing your Galaxy Buds2 Pro.
  • 24-bit Hi-Fi audio
  • Active Noise Canceling (ANC) is better than ever
  • Switching to in-person conversations is easy with Voice Detect
  • Hear it like you're there
    With Intelligent 360 Audio, the sound feels more realistic. The 360 Audio with Direct Multi-channel (5.1ch/7.1ch), Dolby Atmos and enhanced head tracking make every movement stay in sync - creating an immersive experience. 360 Audio can even pinpoint the direction of the sound as you move your head, giving you the spatial experience.
  • Pop open and tap in
    Galaxy Buds2 Pro will automatically pop up on your Samsung Galaxy devices and are ready to connect with a tap. As simple as that. Auto Switch on Samsung Galaxy Buds2 Pro intelligently detects mobile activity and seamlessly shifts its connection to your Samsung Galaxy phone, tablet and watch. Switching to answer the phone works even when you're connected to a Samsung TV. Once the Galaxy Buds2 Pro are connected to the Samsung TV via Bluetooth, there is no need to take the earbuds out to answer the phone. Incoming calls can be answered simply by tapping the Galaxy Buds2 Pro twice.
  • Keep track of your buds
    Worried about losing your Galaxy Buds2 Pro? Don't. With SmartThings Find, you can trace your coveted Galaxy Buds2 Pro with the location detection feature. You can even do it with or without the case. Walk away from your Galaxy Buds2 Pro and the integrated alarm is ready to let you know - your phone will send you a notification so that you don't accidentally leave them behind.
  • Fit in your comfort zone
    Samsung redesigned the earbuds to be 15% smaller than the Galaxy Buds Pro to fit snugly in your ear. Enjoy a comfortable fit, thanks to the ergonomically designed earbuds. Enhanced wind flow technology helps reduce ear canal pressure and minimizes noise - for comfort and clarity.
  • Play all the hits
    Get hours of continuous playtime with ANC on and dozens of hours in the cradle. Bluetooth 5.3 is available. Play on. Rain or shine. Galaxy Buds2 Pro is water resistant.
Samsung Galaxy Buds2 Pro - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Additional Functions
Custom coaxial 2-way, AirVent, SmartThings Find, neck stretch reminder, Bixby voice wake-up, 24-bit Hi-Fi audio
Graphite
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
5.1 channel surround
Sound Effects
Ambient Sound Mode, 360 Reality Audio
Microphone Noise Cancelling
Microphones Included
3
Intelligent Assistant
Bixby
0.231 W/kg (head) , 0.231 W/kg (body)
1-year warranty
Galaxy S22, S22 Ultra, S22+, Z Flip4, Z Fold4
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Earbud: 1.99 cm x 1.87 cm x 2.16 cm / 5.5 g , Charging case: 5.02 cm x 5.01 cm x 2.77 cm / 43.4 g
1.99 cm
1.87 cm
2.16 cm
5.5 g
Graphite
Recommended Use
Touch control, seamless connectivity, easy pairing
Protection
Water-resistant
High-Resolution Audio
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, SSC (Samsung Seamless Codec)
Bluetooth Version
Bluetooth 5.3
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Built-in Decoders
Dolby Atmos
Sound Effects
Auto Switch, voice detect
Microphone
Built-in
3
Noise Cancelling
Tracking
Sensors
Accelerometer, proximity sensor, gyro sensor, hall sensor, touch sensor, Voice Pickup Unit (VPU)
Internet of Things (IoT)
Bixby
Charging case (515 mAh)
IPX7
Headphone battery rechargeable
61 mAh
Run Time (Up To)
5 hour(s)
Run Time Details
Continuous talk (noise cancelling ON): up to 3.5 hours , Continuous talk (noise cancelling ON / with included charging case): up to 14 hours , Continuous playback (noise cancelling ON): up to 5 hours , Continuous playback (noise cancelling ON / with included charging case): up to 18 hours
Limited warranty - 1 year
Samsung Galaxy S22, S22 Ultra, S22+, Z Flip4, Z Fold4
