Samsung Galaxy Book WiFi Core i5-7200 8GB 256GB SSD 12" Windows 10 Home
Portable SSD bundle available - See below for details
Bundles
Quicklinx: CZV8WS00 Mfr#: SM-W720NZKABTU
Display Size: 12in
Processor Model: I5-7200U
Operating System: Windows 10 Home
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£1,099.13 ex VAT
£1,318.95 inc VAT
A new chapter for the PC!
Reliable performance
Have your workflow running smoothly and efficiently without interruption. Engineered with the 7th Gen Intel® Core™ processor, Windows 10 and an In-box Island Type Keyboard, the Galaxy Book has all the performance you need to keep you multitasking on the move.
Supremely vivid
Whether you’re working on a presentation or watching that new series, all your content is brought to life on screen, brilliantly. Choose either a bright and crisp 12" sAMOLED display* or 10.6" FHD TFT display. And on the Galaxy Book 12" you can fully immerse yourself in HDR videos with stunning detail and true-to-life colours.
Streamlined for mobility
With eye-catching dimensions made perfect for carrying your life on the go the Galaxy Book defies convention. Its slim, lightweight and portable design makes it the ultimate content companion for wherever your creativity may lead you.
Optimise your workflow
With adjustable angles, the Galaxy Book has unbeatable versatility to work the way you like. Boost your typing capabilities and make everything from drawing and sketching to note taking and marking documents with S Pen easier. Choose from 4 dynamic viewing modes on the 12" Galaxy Book and 3 viewing modes on the 10.6" version.
A refined S Pen
The new in-box S Pen and optimised applications open up a world of possibilities. Boost your productivity and efficiency with enhanced sensitivity, comfortable grip, ultra-precise 0.7mm tip and battery-free operation.
Maximised power
Powerful enough to last even longer so you get everything done. The Galaxy Book gives you up to11 hours of continuous usage on a full charge, so you can enjoy your content whenever you want it without any disruption
Seamless synchronisation
Move beyond wires for good. Samsung Flow syncs with your SAMSUNG smartphone to receive notifications and transfer data as seamlessly as possible. It even lets you start something on a different device, then pause and pick it up again from the same place on your Galaxy Book.
*Only applies to 12" model
  • Effortless connectivity
    Stay seamlessly connected with your phone. Start by signing into with your fingerprint sensor. Then easily share files, access your phone's hotspot and even respond to a text or IM, all without touching your phone.
  • Seamless usability
    The full-size magnetic keyboard allows for multiple viewing angles, adapts to your work environment and with backlight keys and a large trackpad, it allows you to work in just about any condition.
Samsung Galaxy Book - 12" - Core i5 7200U - 8 GB RAM - 256 GB SSD
Tablet - with detachable keyboard
Operating System
Windows 10 Home
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB LPDDR3
Storage
256 GB SSD
Display
12" OLED touchscreen 2160 x 1440 / Full HD Plus
Graphics
Intel HD Graphics 620
Input Device
Touchpad, detachable keyboard, S Pen
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
Up to 11 hours
Accelerometer, ambient light sensor, hall sensor
Silver, black (keyboard)
Image Colour Disclaimer
The displayed product image may be a different colour
Dimensions (WxDxH) - tablet
29.13 cm x 19.98 cm x 0.74 cm
754 g
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD
Display
12" OLED - Super AMOLED
Touchscreen
Resolution
2160 x 1440 (Full HD Plus)
Widescreen
Image Aspect Ratio
3:2
Colour Support
16 million colours
Audio & Video
Graphics Processor
Memory Allocation Technology
Dynamic Video Memory Technology 5.0
Camera
Yes - 4096 x 3072 (rear), 2560 x 1440 (front)
Resolution
13 Megapixel (rear), 5 Megapixel (front)
Image Sensor Type
CMOS
Video Resolutions
3840 x 2160
Frame Rate
30 frames per second
Camera Features
Autofocus, Panorama
Sound
Stereo speakers
Input
Communications
Wireless
Navigation
Receiver
GPS/GLONASS
5070 mAh
Run Time
Up to 11 hours
Connections & Expansion
2 x USB-C 3.1
Memory Card Reader
Yes (microSDXC)
Integrated Options
MIMO technology, fast charging
Power adapter, keyboard, S Pen, keyboard case
USB-C cable
754 g
Software applications
Samsung Galaxy Book WiFi Core i5-7200 8GB 256GB SSD 12 Bundle deal on Samsung Galaxy Book WiFi Core i5-7200 8GB 256GB SSD 12" Windows 10 Home
£1,284.35
saving £8.33
£1,198.30
Display Size: 12in
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: Samsung
Price Range Ex VAT: 1000 - 1500
