Career-accelerating speed
This processor means business. Achieve it all with the powerful processor. Plus, this on-the-go powerhouse seamlessly syncs with other Galaxy devices to multiply multitasking with ease. -
Your work on full display
See your ambitions come to life on a 3K AMOLED screen. This jaw-dropping laptop continues Samsung's rich heritage of innovative displays with a 16:10 aspect ratio, the largest ever for Galaxy. -
Thin, light, premium design
Pursue your ambitions from anywhere with an amazingly thin, lightweight design. This powerful PC is ready to move with you on your trip to the top. -
Packed with ports
Look like a pro while you're owning the day with a wide range of ports - plus a larger touchpad. No need for a clunky adapter. Connect to bigger screens, external storage devices and more with ease. -
Power to move forward
Get your hustle on all day long with a powerful battery that keeps you on the move for hours and hours. -
Command the room from anywhere
Whether you're live streaming or video conferencing, make an impact with a Full HD webcam, studio-quality dual mics and four AKG-tuned speakers to help you hear every word. -
Break time sounds good
From conference calls to streaming shows, hear every comment with depth and clarity. Four immersive speakers are tuned with AKG and Dolby Atmos for a superb audio experience. -
Advanced security
Work confidently from any location with aadvanced Galaxy Book security. Plus, a fingerprint reader gives you secure and easy access to your laptop while keeping out unwanted users. -
The Galaxy connected experience
Multiply your productivity with one seamless experience across all your devices. Galaxy breaks down barriers so you can do more effortlessly.
- Samsung Galaxy Book3 Pro - 16" - Intel Core i7 - 1360P - Evo - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 11 Home
- Platform Technology
- Intel Evo
- Processor
- Intel Core i7 (13th Gen) - 1360P / 2.2 GHz, up to 5 GHz / 18 MB Cache
- Memory
- 16 GB LPDDR5 (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe
- Display
- 16" 2880 x 1800 / WQXGA+ @ 120 Hz - 212 ppi
- Graphics
- Intel Iris Xe Graphics
- Input Device
- ClickPad
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.1, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
- Ambient light sensor
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Graphite
- 35.54 cm x 25.04 cm x 1.25 cm
- 1.56 kg
- Environmental Standards
- - EPEAT Climate+
- Specific Absorption Rate (SAR)
- 0.607 W/kg (body) , 0.607 W/kg (limb)
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 11 Home
Processor / Chipset
- CPU
- Intel Core i7 (13th Gen) 1360P / 2.2 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 12-core
- Cache
- L3 - 18 MB
- Intel Evo
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR5 SDRAM
- Speed
- 6000 MHz
Storage
- Main Storage
- 512 GB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
- 16" - AMOLED
- Resolution
- 2880 x 1800 (WQXGA+)
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Pixel Density (ppi)
- 212
- Image Aspect Ratio
- 16:10
- Image Brightness
- 500 cd/m²
- Colour Support
- 16 million colours
- Colour Gamut
- 120% DCI-P3
- HDR 500 True Black, 0.2 ms response rate, Eye Caring, gaming performance
- Keyboard Name
- Pro keyboard
Audio & Video
- Graphics Processor
- Video System Features
- Functions as Intel UHD graphics (for single-channel memory)
- Camera
- Yes - 1080p
- Sound
- AKG stereo speakers, dual array microphone
- Dolby Atmos
- Audio Features
- Output: Smart Amp
Input
- Keyboard, ClickPad
- Numeric Keypad
- Backlit
Communications
- Wireless
- Dual stream (2x2)
- Technology
- Lithium Ion
- Capacity
- 76 Watt
AC Adapter
- Output
- 65 Watt
Connections & Expansion
- Slots
- 2 x SSD (1 free)
- Interfaces Details
- HDMI , USB 3.2 , Headphone/microphone combo jack , 2 x USB-C (supports Thunderbolt 4)
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Samsung Recovery Solution, Samsung Update, Samsung Settings, Samsung Gallery, Studio Plus, Samsung Flow, Live Wallpaper, Quick Search, Samsung Notes, Screen Recorder, Galaxy Book Smart Switch, Quick Share, Samsung Pass, Second Screen, Private Share, Galaxy Book Experience
- Graphite
- Integrated Options
- Security
- Included Accessories
- 65W USB-C power adapter
- IEC 61960
- 1.56 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HFGQ 048380 Condition: Customer return - item has been opened but is in excellent condition |
£717.64 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
