Samsung Galaxy Book 3 Pro
Quicklinx: HFGQWS00 Mfr#: NP960XFG-KC2UK
  • Core i7
  • IEEE 802.11n
A processor that means business
Stay on top of your to-do list with the latest 13th Gen Intel® Core™ processor. It delivers superior multi-core performance, powering through workloads at incredible speeds.
Your work on full display
Get lost in crisp 3K (2880x1800) resolution and super-smooth 120Hz as they deliver a cinematic and seamless viewing experience. Every detail comes to life on the 14 or 16-inch screen. Stay in the zone for as long as you like thanks to reduced blue light emission for extra eye care.
More touch pad. More possibility
With an expanded touch pad and wide range of built-in ports, get the plugs and versatility you've been searching for — HDMI, USB-A, microSD slot and even two Thunderbolt 4 ports for blazing-fast 40 Gbps file transfers. No dongle needed
Battery that lasts through overtime
Power through the day's projects with a long-lasting 76Wh (typical) battery for up to 19 hours of video runtime. Then grab a coffee as you top up your laptop with up to 6.7 hours of video runtime in just 30 minutes — with a compact charger that even works with your other Samsung Galaxy devices.
Break time sounds good
From project kickoff to match kickoff, catch everything with the depth and clarity of the quad-speaker system on Galaxy Book3 Pro. The four immersive speakers are tuned with AKG and Dolby Atmos, so every victory sounds better than ever.
  • Career-accelerating speed
    This processor means business. Achieve it all with the powerful processor. Plus, this on-the-go powerhouse seamlessly syncs with other Galaxy devices to multiply multitasking with ease.
  • Your work on full display
    See your ambitions come to life on a 3K AMOLED screen. This jaw-dropping laptop continues Samsung's rich heritage of innovative displays with a 16:10 aspect ratio, the largest ever for Galaxy.
  • Thin, light, premium design
    Pursue your ambitions from anywhere with an amazingly thin, lightweight design. This powerful PC is ready to move with you on your trip to the top.
  • Packed with ports
    Look like a pro while you're owning the day with a wide range of ports - plus a larger touchpad. No need for a clunky adapter. Connect to bigger screens, external storage devices and more with ease.
  • Power to move forward
    Get your hustle on all day long with a powerful battery that keeps you on the move for hours and hours.
  • Command the room from anywhere
    Whether you're live streaming or video conferencing, make an impact with a Full HD webcam, studio-quality dual mics and four AKG-tuned speakers to help you hear every word.
  • Break time sounds good
    From conference calls to streaming shows, hear every comment with depth and clarity. Four immersive speakers are tuned with AKG and Dolby Atmos for a superb audio experience.
  • Advanced security
    Work confidently from any location with aadvanced Galaxy Book security. Plus, a fingerprint reader gives you secure and easy access to your laptop while keeping out unwanted users.
  • The Galaxy connected experience
    Multiply your productivity with one seamless experience across all your devices. Galaxy breaks down barriers so you can do more effortlessly.
Samsung Galaxy Book3 Pro - 16" - Intel Core i7 - 1360P - Evo - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 11 Home
Platform Technology
Intel Evo
Intel Core i7 (13th Gen) - 1360P / 2.2 GHz, up to 5 GHz / 18 MB Cache
16 GB LPDDR5 (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
16" 2880 x 1800 / WQXGA+ @ 120 Hz - 212 ppi
Graphics
Intel Iris Xe Graphics
Input Device
ClickPad
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 5.1, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
Ambient light sensor
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Graphite
35.54 cm x 25.04 cm x 1.25 cm
1.56 kg
0.607 W/kg (body) , 0.607 W/kg (limb)
Notebook
Operating System
Windows 11 Home
Processor / Chipset
CPU
Intel Core i7 (13th Gen) 1360P / 2.2 GHz
Max Turbo Speed
5 GHz
Number of Cores
12-core
Cache
L3 - 18 MB
Platform Technology
Intel Evo
RAM
16 GB (provided memory is soldered)
LPDDR5 SDRAM
Speed
6000 MHz
Storage
Main Storage
512 GB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
16" - AMOLED
Resolution
2880 x 1800 (WQXGA+)
V-Sync Rate at Max Res.
120 Hz
Widescreen
Pixel Density (ppi)
212
Image Aspect Ratio
16:10
Image Brightness
500 cd/m²
Colour Support
16 million colours
Colour Gamut
120% DCI-P3
HDR 500 True Black, 0.2 ms response rate, Eye Caring, gaming performance
Keyboard Name
Pro keyboard
Audio & Video
Graphics Processor
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Yes - 1080p
Sound
AKG stereo speakers, dual array microphone
Dolby Atmos
Audio Features
Output: Smart Amp
Input
Keyboard, ClickPad
Keyboard Backlight
Numeric Keypad
Backlit
Communications
Wireless
Dual stream (2x2)
Lithium Ion
76 Watt
AC Adapter
Output
65 Watt
Connections & Expansion
Slots
2 x SSD (1 free)
Interfaces Details
HDMI , USB 3.2 , Headphone/microphone combo jack , 2 x USB-C (supports Thunderbolt 4)
Memory Card Reader
Yes (microSD)
Software
Software Included
Live Wallpaper, Screen Recorder, Samsung Gallery, Quick Search, Samsung Flow, Samsung Notes, Samsung Recovery Solution, Samsung Settings, Studio Plus, Samsung Update, Samsung Pass, Second Screen, Quick Share, Private Share, Galaxy Book Smart Switch, Galaxy Book Experience
Graphite
Integrated Options
Security
65W USB-C power adapter
IEC 61960
1.56 kg
