Samsung Galaxy A80 6.7" Android - Black
Quicklinx: F76SWS00 Mfr#: SM-A805FZKDBTU
Colours:
  • Android
Get a vivid viewing experience with the Infinity-V display. Capture stunning shots and stand out with the 13MP rear + 5MP front camera. Run multiple apps without missing a beat on this powerful multi-tasker.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Rotating camera to capture all your moments
    The Galaxy A80 changes how you document life. The triple camera slides and rotates to catch what's happening in front and behind. Therefore, now you have one camera that shoots on both sides to capture all your moments.
  • Capture more detail in your stories
    The Galaxy A80's 48MP camera gives you super crisp, clear resolution for shot-worthy moments. You'll notice the difference when vlogging and streaming your day-to-day adventures.
  • More room to play
    The maximized Infinity Display is near bezel-less, no notches, and no distractions. Galaxy A80's 6.7" Full HD+ Super AMOLED offers a big and bright canvas to explore content, stories, connections, and creativity.
  • Easy to hold for longer
    Going live 24/7 means you need a phone that fits in your hand comfortably. Galaxy A80's smooth curves are designed for ease of use. Its striking design comes with a glass and metal frame that's easy to hold day and night.
  • The battery that keeps you live
    To stay live in an always-on world, you need power. Connect, stream, and share with a 3,700 mAh (typical) battery and the 25W Super Fast Charging technology that lives to tell the tale. The Galaxy A80 learns your daily routines and usage patterns while optimizing power by closing unused apps.
  • Share, stream, and play faster
    Galaxy A80 is the phone that's up for the challenge. The Intelligent Performance Enhancer recognizes your mobile habits and optimizes the powerful octa-core processor and 8GB of RAM so you can stream, game, and use your phone with incredibly high performance.
  • Tap and go with your fingerprint
    The On-Screen Fingerprint is fused right into the glass, right where you need it, making it easy to tap and go. You'll have peace of mind knowing that your data is fully secure and that you can have access to your phone when you need it.
  • Samsung Knox protects your privacy at every layer
    Built into the phone's hardware and software from the start, Samsung Knox protects your phone from the minute it's turned on. Offering multi-layered security, it defends your most sensitive information from malware and malicious threats.
Samsung Galaxy A80 - phantom black - 4G smartphone - 128 GB - GSM
4G smartphone
Manufacturer Model Number
SM-A805F/DS
Display
OLED display - 2400 x 1080 pixels - 6.7" - 393 ppi - Super AMOLED
2.2 GHz (8-core)
RAM 8 GB / 128 GB
Operating System
Android 9.0 Pie
Main Camera
48 Megapixel - wide-angle lens - f/2.0 - focus: automatic
Second Camera
8 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
- f/1.2 - 3D depth camera
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader (under display)
Messaging Services
SMS, MMS
Connectors
USB-C
Talk Time
Up to 1800 minutes
Phantom black
76.5 mm x 9.3 mm x 165.2 mm
220 g
0.22 W/kg (head) , 1.43 W/kg (body)
Smartphone
SM-A805F/DS
Touch
76.5 mm
9.3 mm
165.2 mm
220 g
Body Colour
Phantom black
Body Material
Glass, metal frame
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 26, Band 28, Band 38, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
Security Devices
Additional Features
Multi Window, MIMO technology, Fast Charging, Samsung KNOX, Bixby Vision, Secure Folder function, Bixby Routines
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Atmos Surround Sound
Clock Speed
2.2 GHz
Processor Core Qty
8-core
RAM
8 GB
Internal Memory Capacity
128 GB
User Memory
108.2 GB
Main Camera
Sensor Resolution
48 Megapixel
Design
Slide and rotate
Lens Type
Wide-angle lens
Lens Aperture
F/2.0
Field of View (FoV)
80 degree(s)
Pixel Size
0.8 µm
Focus Adjustment
Automatic
Digital Zoom
8x
Special Effects
HDR, Grid Line
Camera Modes
Panorama, Pro mode, HYPERLAPSE, Watermark mode, Live Focus mode, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video, Night, Mountain
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, Super slow motion video 1280 x 720 (720p) at 480 fps
Quick Launch, Playback zoom, Time Rewind, VDIS (Video Digital Image Stabilisation), Video location tags, location tags, Scene Optimiser, Full view, 9.1MP still photos recording 4K video, AR Emoji, Floating shutter button, Super steady, Quick Measure
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Pixel Size
1.12 µm
Third Camera
Lens Aperture
F/1.2
Field of View (FoV)
72 degree(s)
Pixel Size
10 µm
Functions
3D depth camera
Display
OLED display
Super AMOLED
Diagonal Size
6.7"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Pixel Density
393 ppi
Colour Depth
16.7 million colours
Infinity Display, Edge-to-Edge screen, AOD(Always On Display)
Connector Type
USB Type-C - 24 pin USB-C
3700 mAh
Fast Charging Technology
Samsung Fast Charging
Talk Time
1800 minutes
Run Time Details
Active online usage (LTE): up to 13 hrs , Active online usage (Wi-Fi): up to 13 hrs , Playback (wireless video): up to 17 hrs , Playback (wireless audio): up to 51 hrs , Talk (4G): up to 1800 min
Power adapter, SIM card removal tool, USB-C cable, USB-C stereo headset
