Samsung Galaxy A71 - Silver
Quicklinx: FN1TWS00 Mfr#: SM-A715FZSUBTU
Colours:
  • microSDHC
  • Android
Behind Galaxy A71's symmetrically aligned 6.7" Infinity-O Display, Super AMOLED Plus colour technology delivers real-to-life colour in everything you watch and do—from gaming and movies, to web-surfing and multi-tasking. Start enjoying more of what you love, without the screen getting in your way.
Captivating pastel colours paired with a dynamic pattern
With its smooth, elegant curved-edge screen design, Galaxy A71 is beautiful to look at and fits comfortably in your hand. Its premium gloss finish makes it easy to hold, and the rhythmical pattern adds a unique touch of personality to each of its Prism Crush Black, Silver and Blue editions.
More cameras to capture more of your world
Whether the moment calls for a close-up, an ultra-wide shot, a nighttime photo or some artistic Bokeh blur, the A71 Quad Cam delivers with pro-level quality and ease. From a 64MP Main Cam to a 123° 12MP Ultra Wide Cam, to a 5MP Macro Cam and 5MP Depth Cam, A71 is ready for any moment.
Expand your shot with Ultra Wide Cam
Capture the wider world with the Ultra Wide Camera's wider field of vision. The 123-degree angle of view is similar to human sight, which means less panning when you’re getting that perfect cityscape shot.
Macro Cam brings tiny details into the spotlight
Quad Cam’s built-in 5MP Macro Cam (40mm) shoots with clarity and quality, helping you bring out the ultra-fine details of your close-up shots. Apply and adjust natural background blur (Bokeh) to isolate your subject and increase its visual impact.
Super Steady shoots everyday action with impressive stability
Galaxy A71 records like a pro-level action camera, utilising the Ultra Wide Camera and predictive software. Super steady gives you smooth live videos, even when your journey is on the adventurous side.
Enough power to maximise your day
When out living life, you need a phone that can last. Galaxy A71's 4,500mAh (typical) battery gives you the power to stream, share and game on. And if you start running low, plug in and power up with 25W Super-Fast Charging.
Powerful performance to do more
Galaxy A71 has fast processing and spacious storage, so you can focus on now. An advanced Octa-core processor and up to 8GB of RAM deliver smooth and efficient performance. Download more and delete less with up to 128GB internal storage. Add even more with a 512GB microSD card (sold separately).
Play longer and stronger with Game Booster
Maximise performance with Game Booster. Cut distractions and up your game with a dedicated interface and easy-to-reach menu. Frame Booster gives graphics smooth, life-like motion. And play at your best as Game Booster learns your usage patterns to optimize battery, temperature and memory.
Defence-grade security available to everyone
Built into the phone's hardware and software from the start, Samsung Knox protects your phone from the minute it's turned on. Offering multi-layered security, it defends your most sensitive information from malware and malicious threats.
Your fingerprint is the key
Galaxy A71 comes with high-tech biometric authentication. The On-Screen Fingerprint scanner recognises your unique fingerprint, so you are the only one who can press and unlock in one easy move.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Advanced camera experience
    Featuring a main camera, Ultra-Wide, Macro and Depth cameras, combined with intelligent features, the Galaxy A71 allows you to capture almost anything you experience in clear detail and stunning scale. The main camera photographs stunning images with a 64-megapixel camera on the Galaxy A71. Taking crisp and vivid shots, this camera will let you snap the best photo possible - day or night. The Ultra-Wide camera has a 123-degree angle lens, giving you the same view as the human eye and if the shot requires it, the intelligent switch function will recommend Wide Shot and automatically switch it on for you. The Macro camera brings objects into crystal clear focus to capture every last detail while the Depth camera lets your subjects stand out using Live Focus effects.
  • High-quality video recording
    With Super Steady Video you can now capture smooth and stable videos on any adventure. Super Steady Video removes camera shake when you are shooting a video of a moving object or even when you're moving yourself. Whether you're running, hiking or even chasing your pets, the Super Steady Video will help you capture the moment perfectly.
  • Uninterrupted visual display
    The Galaxy A71 offers a Super AMOLED Plus edge-to-edge Infinity-O display. It provides an expansive and immersive experience - forget the world around you and watch your favorite show or game on the incredibly larges screen.
  • Stay connected longer
    The Galaxy A71 comes with a large 4500mAh battery so you can use your phone longer throughout the day. With 25W fast charging capabilities you have come to expect from Galaxy smartphones, you won't be without your phone long when it needs a boost to recharge.
Samsung Galaxy A71 - prism crush silver - 4G smartphone - 128 GB - GSM
4G smartphone
Manufacturer Model Number
SM-A715F/DS
Display
OLED display - 2400 x 1080 pixels - 6.7" - Super AMOLED Plus - HDR
Qualcomm Snapdragon 730 2.2 GHz (8-core) - 64-bit
RAM 6 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 10 with Samsung One UI 2
Main Camera
64 Megapixel - f/1.8 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
5 Megapixel - f/2.4 - macro camera
Fourth Camera
5 Megapixel - f/2.2 - depth camera
Front Camera
32 Megapixel f/2.2
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+
Security Devices
Fingerprint reader (under display)
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 2520 minutes
Prism crush silver
76 mm x 7.7 mm x 163.6 mm
179 g
0.512 W/kg (head) , 1.562 W/kg (body)
SAR Category (Belgium)
B
Smartphone
SM-A715F/DS
Touch
76 mm
7.7 mm
163.6 mm
179 g
Body Colour
Prism crush silver
B
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 10
User Interface
Samsung One UI 2
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 28, Band 38, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
Security Devices
Additional Features
Samsung KNOX, Bixby Vision, Game Booster, Bixby Routines
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
Clock Speed
2.2 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
6 GB
Internal Memory Capacity
128 GB
User Memory
106.1 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
32 Megapixel
Lens Aperture
F/2.2
Camera Modes
Selfie focus
Light Source
Display flash
Background blur
Main Camera
Sensor Resolution
64 Megapixel
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Digital Zoom
8x
Special Effects
Bokeh effect
Light Source
LED flash
Video Resolutions
Slo-mo video 1920 x 1080 (1080p) at 120 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, Slo-mo video 1280 x 720 (720p) at 120 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Slo-mo video 1920 x 1080 (1080p) at 960 fps, Slo-mo video 1280 x 720 (720p) at 960 fps, Slo-mo video 1280 x 720 (720p) at 480 fps
Live Focus
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Third Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Fourth Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.2
Functions
Depth camera
Display
OLED display
Super AMOLED Plus
Diagonal Size
6.7"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Colour Depth
16.7 million colours
HDR
Infinity O display
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
4500 mAh
Fast Charging Technology
Samsung Super Fast Charging
Talk Time
2520 minutes
Run Time Details
Active online usage (4G): up to 16 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (audio): up to 107 hrs , Talk (4G): up to 2520 min , Playback (video): up to 24 hrs
Power adapter
