Complete with a refined design, 5G performance and pro-grade camera, Galaxy A54 5G delivers all you need to live life to the fullest.
- With a premium glass finish, clean camera layout and energising colourways, Galaxy A54 5G wears the Awesome identity on a seamless and graceful frame.
 - With VDIS and a wider OIS angle, Galaxy A54 5G helps shoot high-quality videos with ease through automatic reframing and autofocus. *VDIS : Video Digital Image Stabilization.
 - No need to wait for the perfect shot. Take the photo and edit out unwanted objects, shadows, reflections and more with Object Eraser.
 - Love what you see. The 6.4-inch FHD+ Infinity-O display offers a vibrant view with awesome outdoor visibility and silky smooth screentime with refresh rates up to 120Hz
 - With 128GB/256GB of internal storage plus support for a microSD card up to 1TB, you've got room for all your precious moments.
 - Galaxy A54 5G’s boss-level 2 day battery gives you an insane amount of juice, freeing you up to get on with your life.
 - Your device is your partner. Ensured with 4 generations of OS updates and a 5-year security maintenance, your device experience with Galaxy A54 5G just gets better in time.
Crisp detail and clear display
View all your favorite shows, games and memories in vivid detail with the fluid display of Galaxy A54 5G. -
Take pro shots with ease
Snap clear images with Single Take and OIS, and even get shots in low light with Nightography. -
Charge up and charge on
Always be ready for an impromptu video or photo op with a battery that has your back. -
Powerful 5G performance
Play games and watch videos at full throttle with a powerful processor and virtually lag-free 5G.
 - Samsung Galaxy A54 - awesome violet - 5G smartphone - 256 GB - GSM
- Product Type
 - 5G smartphone
- Manufacturer Model Number
 - SM-A546B/DS
- Display
 - OLED display - 2340 x 1080 pixels - 6.4" - (120 Hz) - Super AMOLED
- Processor
 - 2.4 GHz (8-core)
- Memory
 - RAM 8 GB / 256 GB
- Supported Memory Card
 - microSDXC slot - up to 1 TB
- Operating System
 - With One UI
- Main Camera
 - 50 Megapixel - f/1.8 - focus: automatic
- Second Camera
 - 12 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
 - 5 Megapixel - f/2.4 - macro camera
- Front Camera
 - 32 Megapixel f/2.2 - focus free
- Service Provider
 - Not specified
- SIM Card
 - Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
 - NFC, Wi-Fi 6, Bluetooth
- Security Devices
 - Fingerprint reader
- Connectors
 - USB-C
- Talk Time
 - Up to 2760 minutes
- Protection
 - Water-resistant, dust-resistant
 - Awesome violet
 - 76.7 mm x 8.2 mm x 158.2 mm
 - 202 g
- Repairability Index
 - 8.4 (out of 10)
- Specific Absorption Rate (SAR)
 - 0.693 W/kg (head) , 1.338 W/kg (body) , 3.15 W/kg (limb)
- Product Type
 - Smartphone
 - SM-A546B/DS
- Form Factor
 - Touch
- Protection
 - 76.7 mm
 - 8.2 mm
 - 158.2 mm
 - 202 g
- Body Colour
 - Awesome violet
Cellular
- Technology
 - WCDMA (UMTS) / GSM
- Mobile Broadband Generation
 - 5G
- Service Provider
 - Not specified
- User Interface
 - One UI
- Navigation
 - GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
 - Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
 - Dual-SIM
- SIM Card Configuration Details
 - Nano SIM + nano SIM/microSD
- Input Device
 - Multi-touch
Communications
- Data Transmission
 - FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
 - 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
 - Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
 - 2100, 1900, 1700, 850, 900
- 4G LTE Band
 - Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
 - FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
 - N1, n3, n7, n8, n20, n28, n38, n41, n77, n78, n40
- 5G NR Frequency
 - FDD 2100, FDD 1800, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, TDD TD 3700, TDD TD 3500, TDD 2300
 - NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.3
Phone Features
- Sensors
 - Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
- Security Devices
- Additional Features
 - MIMO technology, Samsung KNOX, Samsung Smart Switch, Virtual Proximity Sensing, 5 years of Security Updates, 4 years of OS updates
Media Player
- Supported Digital Audio Standards
 - WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
 - MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
 - Dolby Atmos sound technology
- Clock Speed
 - 2.4 GHz
- Processor Core Qty
 - 8-core
- RAM
 - 8 GB
- Internal Memory Capacity
 - 256 GB
- User Memory
 - 219 GB
- Supported Flash Memory Cards
 - microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
 - 32 Megapixel
- Lens Aperture
 - F/2.2
- Focus Adjustment
 - Focus free
Main Camera
- Sensor Resolution
 - 50 Megapixel
- Optical Image Stabiliser
 - Optical Image Stabiliser (OIS)
- Lens Aperture
 - F/1.8
- Focus Adjustment
 - Automatic
- Digital Zoom
 - 10x
- Camera Modes
 - Nightography
- Light Source
 - LED flash
- Video Resolutions
 - Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
 - vDIS technology, Auto framing, object eraser, Photo Remaster
Second Camera
- Sensor Resolution
 - 12 Megapixel
- Lens Type
 - Ultra wide-angle lens
- Lens Aperture
 - F/2.2
Third Camera
- Sensor Resolution
 - 5 Megapixel
- Lens Aperture
 - F/2.4
- Functions
 - Macro camera
Display
 - OLED display
- Technology
 - Super AMOLED
- Diagonal Size
 - 6.4"
- Display Resolution
- Display Format
 - Full HD+
- Colour Depth
 - 16.7 million colours
- Refresh Rate
 - 120 Hz
 - Infinity O display
- Connector Type
 - USB Type-C - 24 pin USB-C
- Capacity
 - 5000 mAh
- Talk Time
 - 2760 minutes
- Run Time Details
 - Active online usage (LTE): up to 20 hrs , Active online usage (Wi-Fi): up to 19 hrs , Playback (wireless video): up to 21 hrs , Playback (wireless audio): up to 68 hrs , Talk (4G): up to 2760 min
 - IP67
Sustainability Information
 - 8.4 (out of 10)
- Max Depth of Water Resistance
 - 1 m
