Samsung Galaxy A52 5G 128GB - Awesome Violet
Quicklinx: G7W4WS00 Mfr#: SM-A526BLVDEUA
  • microSDHC
  • microSD
  • Android
On the next-generation mobile data network, the power of 5G fast speeds changes the way you experience and share content - from super-smooth gaming and streaming, to ultrafast sharing and downloading. Upgrade to the Galaxy A52 5G and speed up your smartphone experience.
  • Awesome screen, super smooth scrolling
    Feast your eyes on vibrant details with the Full HD+ Super AMOLED display, reaching 800 nits for clarity even in bright daylight. Eye Comfort Shield lowers blue light, and Super Smooth keeps the view smooth, whether you're gaming or scrolling. All on the expansive Infinity-O display.
  • Great camera, always sharp and steady
    Galaxy A52 5G multilens camera system takes photos to the next level. Go ultra-high-res on the 64MP main camera with OIS for crisp, clear photos throughout the day. Expand the viewing angle with ultra-wide camera. Customize focus with depth camera, or get closer to the details with macro camera.
  • Capture details even in low light with OIS
    Say bye to blurry photos and videos. OIS (Optical Image Stabilization) helps stabilize your shots to keep motion smooth and stills crisp - even when it's low light. The camera pulls in more light to brighten up your low light shots.
  • Ultra-wide camera, ultra-wide experiences
    Similar to human eyesight, the 12MP ultra-wide camera sees the world with a 123-degree angle of view, adding more perspective to everything you shoot.
  • Macro camera pays attention to the tiny details
    Get in close with the 5MP macro camera and bring out the ultra-fine details in your picture. It applies natural bokeh effect to your pictures, allowing your subject to stand out from the background.
  • Bring the focus to the front with depth camera
    The 5MP depth camera lets you adjust the depth of field in your photos. With a simple touch, you can easily fine-tune the background blur behind your subject for high-quality portrait shots that truly stand out.
  • High-resolution front camera, superstar selfies
    Galaxy A52 5G's 32MP front camera snaps clear, high-resolution selfies throughout the day. And with bokeh effect to gently blur the background, your face becomes the star.
  • Spill-, splash- and splatter-resistant
    Rated IP67 for water and dust resistance. So, it's fine to keep on playing and capturing if your phone gets a little wet.
  • Surround sound in the palm of your hand
    With two speakers - one on top and one at the bottom - you can get a stereo audio experience without earphones. Take movie night or your favorite games to the next level with cinematic sound that immerses you in the scene.
  • Reliable battery
    A reliable battery gives you more time to do what you love - streaming, sharing, gaming and more. AI power management detects and adjusts to your mobile usage habits for long-lasting power.
  • Powerful performance to do more at once
    Whether you're focused on one task or multiple tasks at once, Galaxy A52 5G delivers a big boost in performance thanks to an advanced Octa-core processor. Store more and delete less with ample internal storage.
  • Game Booster gives you the edge
    Maximize performance with Game Booster. Cut distractions and up your game with a dedicated interface and easy-to-reach menu. Frame Booster gives graphics smooth, lifelike motion. And play at your best as Game Booster learns your usage patterns to optimize battery, temperature and memory.
Samsung Galaxy A52 5G - awesome violet - 5G smartphone - 128 GB - GSM
5G smartphone
Manufacturer Model Number
SM-A526B/DS
Display
OLED display - 2400 x 1080 pixels - 6.5" - Super AMOLED
2.2 GHz (8-core)
RAM 6 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
With One UI
Main Camera
64 Megapixel - f/1.8 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
5 Megapixel - f/2.4 - macro camera
Fourth Camera
5 Megapixel - f/2.4 - depth camera
Front Camera
32 Megapixel f/2.2 - focus free
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader (under display)
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1920 minutes
Protection
Water-resistant, dust-resistant
Awesome violet
75.1 mm x 8.4 mm x 159.9 mm
189 g
1.055 W/kg (head) , 1.42 W/kg (body) , 2.7 W/kg (limb)
Smartphone
SM-A526B/DS
Touch
Protection
75.1 mm
8.4 mm
159.9 mm
189 g
Body Colour
Awesome violet
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
User Interface
One UI
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n3, n5, n7, n8, n20, n28, n38, n41, n66, n78, n40
5G NR Frequency
FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3500, TDD 2300
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
Security Devices
Additional Features
Samsung KNOX, Game Booster, Virtual Proximity Sensing, dual stereo speakers
Media Player
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Clock Speed
2.2 GHz
Processor Core Qty
8-core
RAM
6 GB
Internal Memory Capacity
128 GB
User Memory
101.5 GB
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
32 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Focus free
Special Effects
Bokeh effect
Main Camera
Sensor Resolution
64 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Digital Zoom
10x
Camera Modes
Portrait mode
Light Source
Flash
Video Resolutions
Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Third Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Fourth Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Depth camera
Display
OLED display
Super AMOLED
Diagonal Size
6.5"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Max Brightness
800 cd/m²
Colour Depth
16.7 million colours
Enhancement Technology
Eye Comfort Shield, Real Smooth
Infinity O display
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
4500 mAh
Fast Charging Technology
Samsung Super Fast Charging
Talk Time
1920 minutes
Run Time Details
Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 20 hrs , Playback (audio): up to 120 hrs , Talk (4G): up to 1920 min
IP67, SGS
Headset, power adapter, SIM card removal tool, USB-C cable
Max Depth of Water Resistance
1 m
