Samsung Galaxy A42 5G 128GB - Prism Dot White
Quicklinx: G03BWS00 Mfr#: SM-A426BZWDEUA
  • microSDHC
  • microSD
  • Android
Go faster with Galaxy A42 5G
On the next-generation mobile data network, the power of 5G fast speeds change the way you experience and share content—from super-smooth gaming and streaming, to ultra-fast sharing and downloading. Upgrade to the Galaxy A42 5G and speed up your smartphone experience.
Maximise your view to the fullest
Expand your view to the 6.6-inch Infinity-U Display of Galaxy A42 5G and enjoy an uninterrupted view of everything you love. Thanks to Super AMOLED technology, your everyday content always looks its best—sharp, crisp and clear.
Advanced Quad Camera, advanced photography powers
Start with the 48MP Main Camera to capture life's moments with more clarity. Expand the viewing angle with Ultra Wide Camera. Customise focus with Depth Camera, or get closer to the details with Macro Camera.
Power that keeps you going
Stay ahead of the day with a battery that won't slow you down. A 5,000mAh (typical) battery lets you continue what you're doing without worrying about the battery bar. And with up to 15W of Adaptive Fast Charging, Galaxy A42 5G gets back to full power quickly.
Give yourself more room to play
Galaxy A42 5G combines Octa-core processing power with up to 8GB of RAM for fast and efficient performance for the task at hand. Enjoy 128GB of internal storage or add even more space with a 1TB microSD card.
  • Maximize your view to the fullest
    Expand your view to the 6.6-inch Infinity-U display of Galaxy A42 5G and enjoy an uninterrupted view of everything you love. Thanks to Super AMOLED technology, your everyday content always looks its best - sharp, crisp and clear.
  • A glossy back that's comfortable to hold
    Galaxy A42 5G's sleek design gives it an eye-catching, prismatic look. Refined curves make it comfortable to hold and provide easy screen navigation.
  • Advanced quad camera, advanced photography powers
    Start with the 48MP main camera to capture life's moments with more clarity. Expand the viewing angle with ultrawide camera. Customize focus with depth camera, or get closer to the details with macro camera.
  • Ultrawide camera, ultrawide moments
    Similar to human eyesight, the 8MP ultrawide camera sees the world with a 123-degree angle of view, adding more perspective to everything you shoot.
  • Macro camera pays attention to the tiny details
    Get in close with the 5MP macro camera and bring out the ultrafine details in your picture. It applies natural bokeh effect to your pictures, allowing your subject to stand out from the background.
  • Bring the focus to the front with depth camera
    The 5MP depth camera lets you adjust the depth of field in your photos. With a simple touch, you can easily fine-tune the background blur behind your subject for high-quality portrait shots that truly stand out.
  • Front camera, attention-grabbing selfies
    With the Galaxy A42 5G 20MP front camera and live focus, it's easy to snap stunning selfies that feature more you and less background.
  • Power that keeps you going
    Stay ahead of the day with a battery that won't slow you down. A 5,000mAh battery lets you continue what you're doing without worrying about the battery bar. And with up to 15W of adaptive fast charging, Galaxy A42 5G gets back to full power quickly.
  • Game Booster gives you the edge
    Maximize performance with Game Booster. Cut distractions and up your game with a dedicated interface and easy to reach menu. Frame booster gives graphics smooth, lifelike motion. And play at your best as Game Booster learns your usage patterns to optimize battery, temperature and memory.
  • Defense-grade security
    Built into the phone's hardware and software from the start, Samsung KNOX protects your phone from the minute it's turned on. Offering multilayered security, it defends your most sensitive information from malware and malicious threats.
  • Made to focus with One UI Core
    One UI Core helps you focus on what matters to you. Hardware and software work together, giving you content and features at your fingertips so you can get to them faster. Use night mode for a comfortable experience in the dark, and with clear and intuitive visuals using your phone is like second nature.
Samsung Galaxy A42 5G - prism dot white - 5G smartphone - 128 GB - GSM
5G smartphone
Manufacturer Model Number
SM-A426B/DS
Display
OLED display - 1600 x 720 pixels - 6.6" - Super AMOLED
2.2 GHz (8-core)
RAM 4 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
Google Android with One UI
Main Camera
48 Megapixel - f/1.8 - focus: automatic
Second Camera
8 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
5 Megapixel - f/2.4 - macro camera
Fourth Camera
5 Megapixel - f/2.4 - depth camera
Front Camera
20 Megapixel f/2.2 - focus free
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 2160 minutes
Prism dot white
75.9 mm x 8.6 mm x 164.4 mm
193 g
1.154 W/kg (head) , 1.334 W/kg (body)
Smartphone
SM-A426B/DS
Touch
75.9 mm
8.6 mm
164.4 mm
193 g
Body Colour
Prism dot white
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Google Android
User Interface
One UI
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 28, Band 38, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
5G NR Band
N1, n3, n5, n7, n8, n28, n41, n78, n40
5G NR Frequency
FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 700APT, TDD TD 2500, TDD TD 3500, TDD 2300
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, gyro sensor, geomagnetic sensor, light sensor
Security Devices
Fingerprint reader
Additional Features
Samsung KNOX, Game Booster
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
Clock Speed
2.2 GHz
Processor Core Qty
8-core
RAM
4 GB
Internal Memory Capacity
128 GB
User Memory
106 GB
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
20 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Focus free
Camera Modes
Live Focus mode
Video Resolutions
3840 x 2160 (4K) at 30 fps
Main Camera
Sensor Resolution
48 Megapixel
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Digital Zoom
10x
Special Effects
Bokeh effect
Camera Modes
Live Focus mode
Light Source
Flash
Video Resolutions
Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, Slo-mo video 1280 x 720 (720p) at 480 fps
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Third Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Fourth Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Depth camera
Display
OLED display
Super AMOLED
Diagonal Size
6.6"
Display Resolution
1600 x 720 pixels
Display Format
HD+
Colour Depth
16.7 million colours
Night mode, Edge-to-Edge screen, Infinity U Display
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
5000 mAh
Fast Charging Technology
Talk Time
2160 minutes
Run Time Details
Active online usage (LTE): up to 21 hrs , Active online usage (Wi-Fi): up to 22 hrs , Playback (audio): up to 130 hrs , Talk (4G): up to 2160 min , Playback (video): up to 34 hrs
Power adapter
