Get sleek and stylish with the Galaxy A41. Enjoy an awesome camera for capturing your favorite moments, an amazing display for watching and browsing and a battery that will keep you going - all at an incredibly awesome price.
A wide display from edge to edge
Immerse yourself in the Galaxy A41's incredible 6.1" Infinity-U Display. Indulge in the crisp detail and vivid color of your favorite blockbusters and celebrate the exquisite elements of beautifully bright boxsets in vivid Full HD+. The Galaxy A41 makes no compromises when it comes to screen and picture quality with its wide aspect ratio that fills your screen with content from edge to edge. -
Light, compact design
Galaxy A41's slim 7.9 mm body and ergonomically curved back are neat and conveniently shaped. You can hold your phone comfortably in one hand whilst easily navigating on screen. -
Three advanced cameras to boost your photo skills
The Galaxy A41 boasts an incredibly advanced triple rear camera. So, whether you're looking to capture perfect portraits or breathtaking scenery, this device has you covered. -
Capture more view from the same spot
Capture the wider world, fitting in more of what you see with the 8MP Ultra Wide Camera's wider field of vision. And with a 48MP hi-resolution Main Camera, your memories will stay bright and clear throughout the day. -
Depth Camera brings your subject into the spotlight
The 5MP Depth Camera lets you adjust the depth of field before and after you nail the shot. The advanced 5MP Depth Camera knocks out unwanted background noise from your images to make them look more professional. -
Show off your sensational selfies
You don't need to be a celebrity to take selfies like one. The Flaw Detection feature spots common glitches like closed eyes, blurred edges and excessive backlighting, so you'll always be captured in the best possible light. Use the Galaxy A41's high-resolution, front-facing Selfie Camera with Live Focus to gently blur the background of your photos so your face becomes the star. You'll want to share your shots with everyone. -
Get going and keep going with a long-lasting, Fast Charging battery
The powerful, long-lasting battery you can rely on the Galaxy A41 to keep you going throughout the day. A 3,500mAh battery gives you the power to stream, share and game on. And if you start running low, plug in and power up with up to 15W of Fast Charging. -
More room to play
Galaxy A41 has fast processing and spacious storage, so you can focus on now. An advanced Octa-core processor and 4GB of RAM deliver smooth and efficient performance. Download more and delete less with an internal storage. Add even more with a MicroSD card. -
Game Booster gives you the edge
Maximize performance with Game Booster. Cut distractions and up your game with a dedicated interface and easy-to-reach menu. Frame Booster gives graphics smooth, lifelike motion. And play at your best as Game Booster learns your usage patterns to optimize battery, temperature and memory. -
Your fingerprint is the key
Galaxy A41 comes with high-tech biometric authentication. The On-Screen Fingerprint Scanner recognizes your unique fingerprint, so you are the only one who can press and unlock in one easy move. -
Defense-grade security available to everyone
Built into the phone's hardware and software from the start, Samsung Knox protects your phone from the minute it's turned on. Offering multi-layered security, it defends your most sensitive information from malware and malicious threats.
- Samsung Galaxy A41 - Prism crush white - 4G smartphone - 64 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-A415F/DSN
- Display
- OLED display - 2400 x 1080 pixels - 6.1" - Super AMOLED
- Processor
- 2 GHz (8-core)
- Memory
- RAM 4 GB / 64 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Main Camera
- 48 Megapixel - wide-angle lens - f/2.0 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 5 Megapixel - f/2.4 - depth camera
- Front Camera
- 25 Megapixel f/2.2
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader (under display), face recognition
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1500 minutes
- Prism crush white
- 69.8 mm x 7.9 mm x 149.9 mm
- 152 g
- Specific Absorption Rate (SAR)
- 0.587 W/kg (head) , 1.5 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-A415F/DSN
- Form Factor
- Touch
- 69.8 mm
- 7.9 mm
- 149.9 mm
- 152 g
- Body Colour
- Prism crush white
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 850, 900
- 4G LTE Band
- Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, gyro sensor, hall sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Virtual Proximity Sensing
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Clock Speed
- 2 GHz
- Processor Core Qty
- 8-core
- RAM
- 4 GB
- Internal Memory Capacity
- 64 GB
- User Memory
- 46.9 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 25 Megapixel
- Lens Aperture
- F/2.2
- Live Focus
Main Camera
- Sensor Resolution
- 48 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.0
- Field of View (FoV)
- 80 degree(s)
- Focus Adjustment
- Automatic
- Digital Zoom
- 8x
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
- Live Focus
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
Third Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Depth camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.1"
- Display Resolution
- Display Format
- Full HD+
- Colour Depth
- 16.7 million colours
- Edge-to-Edge screen, Infinity U Display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3500 mAh
- Talk Time
- 1500 minutes
- Run Time Details
- Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 17 hrs , Playback (audio): up to 80 hrs , Talk (LTE): up to 1500 min
- Included Accessories
- Power adapter
- Limited warranty - 2 years
