Samsung Galaxy A41 64GB Blue
Quicklinx: FXF8WS00 Mfr#: SM-A415FZBDEUA
  • microSDHC
  • Android
Get sleek and stylish with the Galaxy A41. Enjoy an awesome camera for capturing your favorite moments, an amazing display for watching and browsing and a battery that will keep you going - all at an incredibly awesome price.
  • A wide display from edge to edge
    Immerse yourself in the Galaxy A41's incredible 6.1" Infinity-U Display. Indulge in the crisp detail and vivid color of your favorite blockbusters and celebrate the exquisite elements of beautifully bright boxsets in vivid Full HD+. The Galaxy A41 makes no compromises when it comes to screen and picture quality with its wide aspect ratio that fills your screen with content from edge to edge.
  • Light, compact design
    Galaxy A41's slim 7.9 mm body and ergonomically curved back are neat and conveniently shaped. You can hold your phone comfortably in one hand whilst easily navigating on screen.
  • Three advanced cameras to boost your photo skills
    The Galaxy A41 boasts an incredibly advanced triple rear camera. So, whether you're looking to capture perfect portraits or breathtaking scenery, this device has you covered.
  • Capture more view from the same spot
    Capture the wider world, fitting in more of what you see with the 8MP Ultra Wide Camera's wider field of vision. And with a 48MP hi-resolution Main Camera, your memories will stay bright and clear throughout the day.
  • Depth Camera brings your subject into the spotlight
    The 5MP Depth Camera lets you adjust the depth of field before and after you nail the shot. The advanced 5MP Depth Camera knocks out unwanted background noise from your images to make them look more professional.
  • Show off your sensational selfies
    You don't need to be a celebrity to take selfies like one. The Flaw Detection feature spots common glitches like closed eyes, blurred edges and excessive backlighting, so you'll always be captured in the best possible light. Use the Galaxy A41's high-resolution, front-facing Selfie Camera with Live Focus to gently blur the background of your photos so your face becomes the star. You'll want to share your shots with everyone.
  • Get going and keep going with a long-lasting, Fast Charging battery
    The powerful, long-lasting battery you can rely on the Galaxy A41 to keep you going throughout the day. A 3,500mAh battery gives you the power to stream, share and game on. And if you start running low, plug in and power up with up to 15W of Fast Charging.
  • More room to play
    Galaxy A41 has fast processing and spacious storage, so you can focus on now. An advanced Octa-core processor and 4GB of RAM deliver smooth and efficient performance. Download more and delete less with an internal storage. Add even more with a MicroSD card.
  • Game Booster gives you the edge
    Maximize performance with Game Booster. Cut distractions and up your game with a dedicated interface and easy-to-reach menu. Frame Booster gives graphics smooth, lifelike motion. And play at your best as Game Booster learns your usage patterns to optimize battery, temperature and memory.
  • Your fingerprint is the key
    Galaxy A41 comes with high-tech biometric authentication. The On-Screen Fingerprint Scanner recognizes your unique fingerprint, so you are the only one who can press and unlock in one easy move.
  • Defense-grade security available to everyone
    Built into the phone's hardware and software from the start, Samsung Knox protects your phone from the minute it's turned on. Offering multi-layered security, it defends your most sensitive information from malware and malicious threats.
Samsung Galaxy A41 - prism crush blue - 4G smartphone - 64 GB - GSM
4G smartphone
Manufacturer Model Number
SM-A415F/DSN
Display
OLED display - 2400 x 1080 pixels - 6.1" - Super AMOLED
2 GHz (8-core)
RAM 4 GB / Internal Memory 64 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Main Camera
48 Megapixel - wide-angle lens - f/2.0 - focus: automatic
Second Camera
8 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
5 Megapixel - f/2.4 - depth camera
Front Camera
25 Megapixel f/2.2
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader (under display), face recognition
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1500 minutes
Prism crush blue
69.8 mm x 7.9 mm x 149.9 mm
152 g
0.587 W/kg (head) , 1.5 W/kg (body)
Smartphone
SM-A415F/DSN
Touch
69.8 mm
7.9 mm
149.9 mm
152 g
Body Colour
Prism crush blue
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 850, 900
4G LTE Band
Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, gyro sensor, hall sensor, geomagnetic sensor
Security Devices
Additional Features
Virtual Proximity Sensing
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Clock Speed
2 GHz
Processor Core Qty
8-core
RAM
4 GB
Internal Memory Capacity
64 GB
User Memory
46.9 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
25 Megapixel
Lens Aperture
F/2.2
Live Focus
Main Camera
Sensor Resolution
48 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.0
Field of View (FoV)
80 degree(s)
Focus Adjustment
Automatic
Digital Zoom
8x
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps
Live Focus
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Third Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Depth camera
Display
OLED display
Super AMOLED
Diagonal Size
6.1"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Colour Depth
16.7 million colours
Edge-to-Edge screen, Infinity U Display
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
3500 mAh
Talk Time
1500 minutes
Run Time Details
Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 17 hrs , Playback (audio): up to 80 hrs , Talk (LTE): up to 1500 min
Power adapter
