Samsung Galaxy A35 5G 128gb Navy - Grade A
Quicklinx: HYTQWS00 Mfr#: SM-A356BZKBEUB/GRADEA
  • microSDHC
  • microSD
  • Android
Grade A Returned Device
Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
  • Can be used on any network
  • 12 months warranty
  • Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
  • Re-sealed, original packaging.
  • Awesome inside and out
    A delightful blend of simplicity and enjoyment. The iconic Galaxy A35 5G design features a linear camera layout encased with an elegant glass back and a flat side frame for a sleek look and feel.
  • Beauty lies in the details
    Capture beautiful photos with the 50MP high-resolution Wide-angle camera. The vivid color and details will give you awe-inspiring photos worth sharing.
  • Stunning photos even in the dark
    Nightography just got fun. The Galaxy A35 5G comes with an improved NPU and enhanced sensor that makes photos clear with detail even in the dark. From nightscapes to night portraits, you'll get more detail in every shot.
  • Shoot clear and steady videos
    With Super HDR, you can get rich colors, clear videos, and better visibility in a variety of lighting conditions. Paired with OIS and VDIS, you get smooth videos while filming on the move.
  • Edit photos effortlessly
    Take your photos to the next level by enhancing your images with Edit Suggestion like Background blur, Remaster, Erase shadows and more.
  • Bright and vibrant display
    Meet the brilliant 6.6-inch FHD+ Super AMOLED Infinity-O display with a 120 Hz smooth high-refresh rate and 1,000 nits of brightness. Vision Booster can give you crystal-clear outdoor visibility even in direct sunlight.
  • The power is in your hands
    Unlock the Octa-core processor's power with improved GPU and NPU, making multitasking, gaming, and streaming a breeze. Galaxy A35 5G features a large vapor chamber cooling system that's ready to handle almost any task.
  • Battery life for 2 days
    Get more mobility with the 5,000 mAh (typical) battery designed to keep you connected for 2 days and recharge with Super Fast Charging.
  • Helps resist damage from drops and spills
    Your phone is dust and water resistant with an IP67 rating. Plus, the display is made from tough Corning Gorilla Glass Victus + to give you additional peace of mind.
  • Support to keep your information safe
    The EAL5+ certified Samsung Knox Vault is designed to protect your sensitive information, such as your PIN, password and pattern. Your encrypted data can be safely transferred to Samsung Knox Vault storage, which is completely isolated and separated from the main operating system.
Samsung Galaxy A35 - awesome navy - 5G smartphone - 128 GB - GSM
5G smartphone
Manufacturer Model Number
SM-A356B/DS
Display
OLED display - 2340 x 1080 pixels - 6.6" - (120 Hz) - Super AMOLED - Corning Gorilla Glass Victus+ (scratch resistant glass)
2.4 GHz (8-core)
RAM 6 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
Android 14 with One UI 6.1
Main Camera
50 Megapixel - wide-angle lens - f/1.8 - focus: automatic
Second Camera
8 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
5 Megapixel - f/2.4 - macro camera
Front Camera
13 Megapixel f/2.2 - focus free
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Wi-Fi 6, Bluetooth
Security Devices
Fingerprint reader
Connectors
USB-C
Standby Time
Up to 48 hours
Protection
Water-resistant, dust-resistant
Awesome navy
78 mm x 8.2 mm x 161.7 mm
209 g
Repairability Index
8.4 (out of 10)
0.436 W/kg (head) , 0.917 W/kg (body) , 2.15 W/kg (limb)
Smartphone
SM-A356B/DS
Touch
Protection
78 mm
8.2 mm
161.7 mm
209 g
Body Colour
Awesome navy
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 14
User Interface
One UI 6.1
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n40
5G NR Frequency
FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD 2300
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.3
Phone Features
Sensors
Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
Security Devices
Fingerprint reader
Additional Features
MIMO technology, Samsung Smart Switch, Virtual Proximity Sensing, Samsung Knox Vault, 5 years of Security Updates, SmartThings Support, 4 generations of OS upgrades
Media Player
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Clock Speed
2.4 GHz
Processor Core Qty
8-core
RAM
6 GB
Internal Memory Capacity
128 GB
User Memory
108 GB
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
13 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Focus free
Main Camera
Sensor Resolution
50 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Digital Zoom
10x
HDR Mode
Super HDR
Light Source
LED flash
Video Resolutions
Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
vDIS technology
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Third Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Display
OLED display
Super AMOLED
Diagonal Size
6.6"
Display Resolution
2340 x 1080 pixels
Display Format
Full HD+
Max Brightness
1000 cd/m²
Colour Depth
16.7 million colours
Enhancement Technology
Vision Booster technology
Refresh Rate
120 Hz
Protection
Infinity O display, High brightness mode
Connector Type
USB Type-C - 24 pin USB-C
5000 mAh
Fast Charging Technology
Samsung Super Fast Charging
Standby Time
48 hours
Run Time Details
Active online usage (LTE): up to 23 hrs , Active online usage (Wi-Fi): up to 22 hrs , Playback (wireless video): up to 26 hrs , Playback (wireless audio): up to 83 hrs , Standby: up to 48 hrs
IP67, Common Criteria EAL5+, SGS Eye Care Display Certification, Android Audio Streaming for Hearing Aid (ASHA)
Regional Warranty Exceptions
Spain - 3 years
Sustainability Information
Repairability Index
8.4 (out of 10)
Max Depth of Water Resistance
1 m
