Awesome inside and out
A delightful blend of simplicity and enjoyment. The iconic Galaxy A35 5G design features a linear camera layout encased with an elegant glass back and a flat side frame for a sleek look and feel. -
Beauty lies in the details
Capture beautiful photos with the 50MP high-resolution Wide-angle camera. The vivid color and details will give you awe-inspiring photos worth sharing. -
Stunning photos even in the dark
Nightography just got fun. The Galaxy A35 5G comes with an improved NPU and enhanced sensor that makes photos clear with detail even in the dark. From nightscapes to night portraits, you'll get more detail in every shot. -
Shoot clear and steady videos
With Super HDR, you can get rich colors, clear videos, and better visibility in a variety of lighting conditions. Paired with OIS and VDIS, you get smooth videos while filming on the move. -
Edit photos effortlessly
Take your photos to the next level by enhancing your images with Edit Suggestion like Background blur, Remaster, Erase shadows and more. -
Bright and vibrant display
Meet the brilliant 6.6-inch FHD+ Super AMOLED Infinity-O display with a 120 Hz smooth high-refresh rate and 1,000 nits of brightness. Vision Booster can give you crystal-clear outdoor visibility even in direct sunlight. -
The power is in your hands
Unlock the Octa-core processor's power with improved GPU and NPU, making multitasking, gaming, and streaming a breeze. Galaxy A35 5G features a large vapor chamber cooling system that's ready to handle almost any task. -
Battery life for 2 days
Get more mobility with the 5,000 mAh (typical) battery designed to keep you connected for 2 days and recharge with Super Fast Charging. -
Helps resist damage from drops and spills
Your phone is dust and water resistant with an IP67 rating. Plus, the display is made from tough Corning Gorilla Glass Victus + to give you additional peace of mind. -
Support to keep your information safe
The EAL5+ certified Samsung Knox Vault is designed to protect your sensitive information, such as your PIN, password and pattern. Your encrypted data can be safely transferred to Samsung Knox Vault storage, which is completely isolated and separated from the main operating system.
- Samsung Galaxy A35 - Enterprise Edition - awesome navy - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-A356B/DS
- Display
- OLED display - 2340 x 1080 pixels - 6.6" - (120 Hz) - Super AMOLED - Corning Gorilla Glass Victus+ (scratch resistant glass)
- Processor
- 2.4 GHz (8-core)
- Memory
- RAM 6 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 14 with One UI 6.1
- Main Camera
- 50 Megapixel - wide-angle lens - f/1.8 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 5 Megapixel - f/2.4 - macro camera
- Front Camera
- 13 Megapixel f/2.2 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, Bluetooth
- Security Devices
- Fingerprint reader
- Connectors
- USB-C
- Standby Time
- Up to 48 hours
- Protection
- Water-resistant, dust-resistant
- Awesome navy
- 78 mm x 8.2 mm x 161.7 mm
- 209 g
- Repairability Index
- 8.4 (out of 10)
- Specific Absorption Rate (SAR)
- 0.436 W/kg (head) , 0.917 W/kg (body) , 2.15 W/kg (limb)
- 3-year warranty
- Product Type
- Smartphone
- SM-A356B/DS
- Form Factor
- Touch
- Protection
- 78 mm
- 8.2 mm
- 161.7 mm
- 209 g
- Body Colour
- Awesome navy
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 14
- User Interface
- One UI 6.1
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
- Security Devices
- Additional Features
- MIMO technology, Samsung Smart Switch, Virtual Proximity Sensing, Samsung Knox Vault, 5 years of Security Updates, 2 years of product availability from launch date, SmartThings Support, 4 generations of OS upgrades
Media Player
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Clock Speed
- 2.4 GHz
- Processor Core Qty
- 8-core
- RAM
- 6 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 108 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Focus free
Main Camera
- Sensor Resolution
- 50 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- HDR Mode
- Super HDR
- Light Source
- LED flash
- Video Resolutions
- Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
- vDIS technology
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
Third Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.6"
- Display Resolution
- Display Format
- Full HD+
- Max Brightness
- 1000 cd/m²
- Colour Depth
- 16.7 million colours
- Enhancement Technology
- Vision Booster technology
- Refresh Rate
- 120 Hz
- Protection
- Infinity O display, High brightness mode
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 5000 mAh
- Fast Charging Technology
- Samsung Super Fast Charging
- Standby Time
- 48 hours
- Run Time Details
- Active online usage (LTE): up to 23 hrs , Active online usage (Wi-Fi): up to 22 hrs , Playback (wireless video): up to 26 hrs , Playback (wireless audio): up to 83 hrs , Standby: up to 48 hrs
- IP67, Common Criteria EAL5+, SGS Eye Care Display Certification, Android Audio Streaming for Hearing Aid (ASHA)
- Limited warranty - 3 years
Sustainability Information
- 8.4 (out of 10)
- Max Depth of Water Resistance
- 1 m
