Smooth and bright, even in sunlight
Galaxy A34 5G's 1,000nits, Super AMOLED display ensures a clear view even when outside. Enjoy silky smooth viewing on the 6.6-inch awesome screen and refresh rates of up to 120Hz that breathe life into your content
Get it done in a flash
Powered by an octa-core processor and connected in 5G, Galaxy A34 5G inspires your peak performance whether at work or play.
Plenty of juice
With a 5,000mAh (typical) battery, Galaxy A34 5G keeps going for all the snapping, scrolling and streaming you can handle.
Awesome viewing experience
Get immersed! The 1000 nits, and Super AMOLED display on Galaxy A34 5G ensures clear visibility even in outdoor locations. For silky smooth viewing on the 16.65 cm (6.6") awesome screen, switch to a refresh rate of up to 120 Hz and binge-watch like never before. -
Simple and sleek
Framed in simple lines and a glastic finish, Galaxy A34 5G is available in fashionable yet timeless colors including Awesome Lime, Awesome Silver and Awesome Graphite. -
Your moments come to life
Galaxy A34 5G records your finest moments in bright, vivid colors even in the shakiest moments with its VDIS feature. The camera automatically adjusts the light and the frame to fit the subjects perfectly with Auto Framing. -
Powered by an octa-core processor and connected in 5G, Galaxy A34 5G inspires your peak performance whether at work or play. -
Go for days
With a 5,000 mAh (typical) battery, Galaxy A34 5G is fueled for longer hours while optimizing the battery life based on your phone usage through Adaptive Battery. -
Sense the palpable difference
Boosted in precision and feedback, the enhanced haptic experience of Galaxy A34 5G, offers a new range of emotions that interact with your hands.
- Samsung Galaxy A34 5G - awesome graphite - 5G smartphone - 256 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-A346B/DSN
- Display
- OLED display - 2340 x 1080 pixels - 6.6" - (120 Hz) - Super AMOLED
- Processor
- 2.6 GHz (8-core)
- Memory
- RAM 8 GB / 256 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- With One UI
- Main Camera
- 48 Megapixel - f/1.8 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 5 Megapixel - f/2.4 - macro camera
- Front Camera
- 13 Megapixel f/2.2
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Connectors
- USB-C
- Talk Time
- Up to 2160 minutes
- Protection
- Water-resistant, dust-resistant
- Awesome graphite
- 78.1 mm x 8.2 mm x 161.3 mm
- 199 g
- Repairability Index
- 8.3 (out of 10)
- Specific Absorption Rate (SAR)
- 0.546 W/kg (head) , 1.488 W/kg (body) , 2.68 W/kg (limb)
- Product Type
- Smartphone
- SM-A346B/DSN
- Form Factor
- Touch
- Protection
- 78.1 mm
- 8.2 mm
- 161.3 mm
- 199 g
- Body Colour
- Awesome graphite
- SAR Value
- 2.68 W/kg (limb), 0.546 W/kg (head), 1.488 W/kg (body)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- User Interface
- One UI
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 26, Band 28, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n7, n8, n20, n28, n38, n41, n77, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, TDD TD 3700, TDD TD 3500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
- Security Devices
- Additional Features
- MIMO technology, Samsung KNOX, Samsung Smart Switch, Virtual Proximity Sensing, 5 years of Security Updates, 4 years of OS updates
Media Player
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Atmos sound technology
- Clock Speed
- 2.6 GHz
- Processor Core Qty
- 8-core
- RAM
- 8 GB
- Internal Memory Capacity
- 256 GB
- User Memory
- 218 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.2
Main Camera
- Sensor Resolution
- 48 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Light Source
- LED flash
- Video Resolutions
- Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, Slo-mo video 1280 x 720 (720p) at 480 fps
- Auto framing, object eraser, AI image enhancer, Photo Remaster
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
Third Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.6"
- Display Resolution
- Display Format
- Full HD+
- Max Brightness
- 1000 cd/m²
- Colour Depth
- 16.7 million colours
- Refresh Rate
- 120 Hz
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 5000 mAh
- Talk Time
- 2160 minutes
- Run Time Details
- Active online usage (LTE): up to 22 hrs , Active online usage (Wi-Fi): up to 22 hrs , Playback (wireless video): up to 21 hrs , Playback (wireless audio): up to 84 hrs , Talk (4G): up to 2160 min
- IP67
Sustainability Information
- 8.3 (out of 10)
- Max Depth of Water Resistance
- 1 m
