Be ready for anything that life throws at you with a fusion of solid, premium-feel metal and robust Gorilla Glass. At 4.7 inches, the A3 is compact enough to fit perfectly into your life.
Front and rear cameras feature f/1.9 aperture for exceptionally clear images, even in low-light conditions. Capture precious moment in an instant, simply by pressing the home button twice, and launch the camera in under a second. Capture more of your surroundings with the 'wide selfie' function.
Beautifully crafted
Be ready for anything that life throws at you with a fusion of solid, premium-feel metal and robust Gorilla Glass. At 4.7 inches, the A3 is compact enough to fit perfectly into your life. -
Brighter, crisper images
Front and rear cameras feature f/1.9 aperture for exceptionally clear images, even in low-light conditions. Capture precious moment in an instant, simply by pressing the home button twice, and launch the camera in under a second. Capture more of your surroundings with the 'wide selfie' function. -
Extended power
A larger battery capacity lets you get more out of a host of exciting features. Watch HD videos, play games, stream high-quality audio and work on a range of productivity-enhancing apps for longer than ever.
- Samsung Galaxy A3 (2017) - blue-mist - 4G smartphone - 16 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-A320FL
- Display
- OLED display - 1280 x 720 pixels - 4.7" - HD Super AMOLED
- Processor
- 1.6 GHz (8-core)
- Memory
- RAM 2 GB / 16 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Google Android
- Main Camera
- 13 Megapixel - CMOS - f/1.9 - focus: automatic
- Front Camera
- 8 Megapixel - CMOS f/1.9
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1020 minutes
- Protection
- Dustproof, waterproof
- Blue-mist
- 66.2 mm x 7.9 mm x 135.4 mm
- 138 g
- Specific Absorption Rate (SAR)
- 0.349 W/kg (head) , 1.38 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-A320FL
- Form Factor
- Touch
- Protection
- 66.2 mm
- 7.9 mm
- 135.4 mm
- 138 g
- Body Colour
- Blue-mist
- Body Material
- Metal, glass
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Google Android
- Navigation
- GPS, GLONASS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 5, Band 7, Band 8, Band 20, Band 40
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, PBAP, MAP, HOGP
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, flight mode, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Clock Speed
- 1.6 GHz
- Processor Core Qty
- 8-core
- RAM
- 2 GB
- Internal Memory Capacity
- 16 GB
- User Memory
- 9.7 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Sensor Type
- CMOS
- Lens Aperture
- F/1.9
Main Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Type
- CMOS
- Lens Aperture
- F/1.9
- Focus Adjustment
- Automatic
- Camera Modes
- Food mode
- Light Source
- LED light
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
Display
- OLED display
- Technology
- HD Super AMOLED
- Diagonal Size
- 4.7"
- Display Resolution
- 1280 x 720 pixels
- Display Format
- HD
- Colour Depth
- 16.7 million colours
- Connector Type
- Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
- Capacity
- 2350 mAh
- Talk Time
- 1020 minutes
- Run Time Details
- Talk (3G): up to 1020 min , Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (video): up to 17 hrs , Playback (Music): up to 41 hrs , Playback (audio (Always On Display Off)): up to 55 hrs
- IP68
- Included Accessories
- Power adapter
- Limited warranty - 2 years
