Samsung Galaxy A15 128GB Blue
Quicklinx: HTR4WS00 Mfr#: SM-A155FZBDEUB
  • microSDHC
  • microSD
  • Android
Samsung Galaxy A15 boasts a bevy of impressive features, without the flagship price tag. The best bits include a 50MP main camera, a bright 6.5-inch FHD+ display, and a 5,000mAh battery to take you all the way through the day.
Snapping that sharable shot is easy with Galaxy A15's multi-lens including a 50MP main camera. The Ultra Wide lens is perfect for immortalising those awe-inspiring landscapes, or the Macro lens can highlight tiny details in close-ups. And when the time comes for a shameless selfie, flip over to the 13MP front-facing lens, concealed within the slick Infinity-U display.
Galaxy A15's 6.5-inch FHD+ display is packed with smarts. The Infinity-U design features a subtle dew-drop cut-out at the top of the display, to conceal the selfie camera. While the Eye comfort shield technology will reduce blue light in the evening, to ease eye strain. And if that's not enough, Vision Booster makes sure the screen is bright and clear, even when out and about on a sunny day.
Galaxy A15's 5,000mAh battery is huge. It can hold onto enough power to comfortably take users from their morning alarm all the way to bed time. And if there's a call for a rapid injection of power before heading out the door, the Super Fast Charging technology will step in and get to work.
Samsung Galaxy A15 has space for a microSD card, which allows users to boost the device's storage capacity from the already substantial 128GB, to a whopping 1TB. That's enough room to save over 250,000 photos.
  • Super vivid and bright display
    The Galaxy A15's 6.5-inch Super AMOLED display boasts vibrant clarity even in direct sunlight with Vision Booster, smooth-scrolling with improved 90 Hz refresh rate, enhanced brightness up to 800 nits, and all-day comfort with reduced blue light thanks to Eye Comfort Shield.
  • Balanced simplicity
    Designed to fulfill. The Galaxy A15 showcases its refined aesthetics through an intuitive frame, glossy back cover and tidy camera layout.
  • Pick your lens, find your angle
    Go on and express your world. The Galaxy A15 boasts a 50MP Main camera for your masterpiece, 5MP Ultra Wide and 2MP Macro cameras for landscapes and close-ups, and a 13MP Front camera for profile-worthy selfies.
  • Get it done with boosted performance
    Your day runs smoother with an octa-core processor for powerful performance while spacious memory and storage options keep your data and contents ready at hand.
  • Stay in the zone with a 2-day battery
    More time to get productive with a 5,000 mAh (typical) battery that lasts for 2 days and recharges rapidly with Super Fast Charging.
  • Trust in Samsung Knox Vault
    Certified EAL5+, Samsung Knox Vault is designed to safeguard your sensitive data, such as PINs, passwords and patterns, in a separate tamper-resistant storage for protection against software and hardware threats involving voltage, glitches, high temperature and laser.
  • Unlock with your fingerprint
    Double-checked by the side fingerprint sensor, your security is designed to be accessible only by your fingerprint.
Samsung Galaxy A15 - blue - 4G smartphone - 128 GB - GSM
4G smartphone
Manufacturer Model Number
SM-A155F/DSN
Display
OLED display - 2340 x 1080 pixels - 6.5" - 399 ppi - (90 Hz) - Super AMOLED
MediaTek Helio G99 2.2 GHz (8-core)
RAM 4 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
Android 14 with One UI 6.0
Main Camera
50 Megapixel - f/1.8 - focus: automatic
Second Camera
5 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
2 Megapixel - f/2.4 - macro camera
Front Camera
13 Megapixel f/2.0
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader (side), face recognition
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 3060 minutes
Blue
76.8 mm x 8.4 mm x 160.1 mm
200 g
Repairability Index
8.3 (out of 10)
0.42 W/kg (head) , 1.29 W/kg (body) , 2.34 W/kg (limb)
Smartphone
SM-A155F/DSN
Touch
76.8 mm
8.4 mm
160.1 mm
200 g
Body Colour
Blue
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 14
User Interface
One UI 6.0
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Communications
Data Transmission
LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 5, Band 8
3G UMTS Frequency
2100, 850, 900
4G LTE Band
Band 1, Band 20, Band 28, Band 3, Band 38, Band 41, Band 5, Band 7, Band 8
4G LTE Frequency
FDD 2100, FDD 800 DD, FDD 700 APT, FDD 1800+, TDD 2600, TDD 2500, FDD 850, FDD 2600, FDD 900
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.3
Phone Features
Sensors
Accelerometer, light sensor, virtual proximity sensor, geomagnetic sensor
Security Devices
Additional Features
5 years of Security Updates, 4 years of OS updates
Media Player
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Atmos sound technology
MediaTek Helio G99
Clock Speed
2.2 GHz
Processor Core Qty
8-core
RAM
4 GB
Internal Memory Capacity
128 GB
User Memory
109.1 GB
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
13 Megapixel
Lens Aperture
F/2.0
Video Resolutions
1280 x 720 (720p) at 30 fps
Light Source
Display flash
Palm shutter
Main Camera
Sensor Resolution
50 Megapixel
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Digital Zoom
10x
Camera Modes
Macro mode, night mode, Pro mode, AR lens, Panorama, Food, Portrait, Slow motion mode
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 120 fps
Scene Optimiser
Second Camera
Sensor Resolution
5 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Third Camera
Sensor Resolution
2 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Display
OLED display
Super AMOLED
Diagonal Size
6.5"
Display Resolution
2340 x 1080 pixels
Display Format
Full HD+
Pixel Density
399 ppi
Max Brightness
800 cd/m²
Colour Depth
16.7 million colours
Enhancement Technology
Eye Comfort Shield
Refresh Rate
90 Hz
Infinity U Display
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
5000 mAh
Fast Charging Technology
Samsung Super Fast Charging
Talk Time
3060 minutes
Run Time Details
Talk (LTE): up to 3060 min , Active online usage (LTE): up to 19 hrs , Playback (video): up to 20 hrs , Active online usage (Wi-Fi): up to 19 hrs , Playback (audio): up to 109 hrs
SGS Eye Care Display Certification
SIM card removal tool, USB-C to USB-C cable
Regional Warranty Exceptions
Spain - 3 years
Sustainability Information
Repairability Index
8.3 (out of 10)
