Super vivid and bright display -The Galaxy A15's 6.5-inch Super AMOLED display boasts vibrant clarity even in direct sunlight with Vision Booster, smooth-scrolling with improved 90Hz refresh rate, enhanced brightness up to 800 nits, and all-day comfort with reduced blue light thanks to Eye Comfort Shield.
Stay in the zone with a 2-day battery - More time to get productive with a 5,000mAh (typical) battery that lasts for 2 days and recharges rapidly with Super Fast Charging.
Unlock with your fingerprint - Double-checked by the side fingerprint sensor, your security is designed to be accessible only by your fingerprint.
Pick your lens. Find your angle. - Go on and express your world. The Galaxy A15 boasts a 50MP Main camera for your masterpiece, 5MP Ultra Wide and 2MP Macro cameras for landscapes and close-ups, and a 13MP Front camera for profile-worthy selfies.
Get it done with boosted performance - Your day runs smoother with an octa-core processor for powerful performance while spacious memory and storage options keep your data and contents ready at hand.
Keep up with the latest for longer - Offered with up to 4 generations of OS upgrades and 5 years of security maintenance, your Galaxy A15 stays up-to-date for longer.
Grade A Returned Device Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
- Can be used on any network
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
The Galaxy A15's 6.5-inch Super AMOLED display boasts vibrant clarity even in direct sunlight with Vision Booster, smooth-scrolling with improved 90 Hz refresh rate, enhanced brightness up to 800 nits, and all-day comfort with reduced blue light thanks to Eye Comfort Shield. -
Balanced simplicity
Designed to fulfill. The Galaxy A15 showcases its refined aesthetics through an intuitive frame, glossy back cover and tidy camera layout. -
Pick your lens, find your angle
Go on and express your world. The Galaxy A15 boasts a 50MP Main camera for your masterpiece, 5MP Ultra Wide and 2MP Macro cameras for landscapes and close-ups, and a 13MP Front camera for profile-worthy selfies. -
Your day runs smoother with an octa-core processor for powerful performance while spacious memory and storage options keep your data and contents ready at hand. -
More time to get productive with a 5,000 mAh (typical) battery that lasts for 2 days and recharges rapidly with Super Fast Charging. -
Trust in Samsung Knox Vault
Certified EAL5+, Samsung Knox Vault is designed to safeguard your sensitive data, such as PINs, passwords and patterns, in a separate tamper-resistant storage for protection against software and hardware threats involving voltage, glitches, high temperature and laser. -
- Samsung Galaxy A15 - blue black - 4G smartphone - 128 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-A155F/DSN
- Display
- OLED display - 2340 x 1080 pixels - 6.5" - 399 ppi - (90 Hz) - Super AMOLED
- Processor
- MediaTek Helio G99 2.2 GHz (8-core)
- Memory
- RAM 4 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 14 with One UI 6.0
- Main Camera
- 50 Megapixel - f/1.8 - focus: automatic
- Second Camera
- 5 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 2 Megapixel - f/2.4 - macro camera
- Front Camera
- 13 Megapixel f/2.0
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Face recognition, fingerprint reader (side)
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 3060 minutes
- Blue black
- 76.8 mm x 8.4 mm x 160.1 mm
- 200 g
- Repairability Index
- 8.3 (out of 10)
- Specific Absorption Rate (SAR)
- 0.42 W/kg (head) , 1.29 W/kg (body) , 2.34 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-A155F/DSN
- Form Factor
- Touch
- 76.8 mm
- 8.4 mm
- 160.1 mm
- 200 g
- Body Colour
- Blue black
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 14
- User Interface
- One UI 6.0
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 850, 900
- 4G LTE Band
- Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, geomagnetic sensor, light sensor, virtual proximity sensor
- Security Devices
- Additional Features
- 5 years of Security Updates, 4 years of OS updates
Media Player
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Atmos sound technology
- Clock Speed
- 2.2 GHz
- Processor Core Qty
- 8-core
- RAM
- 4 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 109.1 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.0
- Video Resolutions
- 1280 x 720 (720p) at 30 fps
- Light Source
- Display flash
- Palm shutter
Main Camera
- Sensor Resolution
- 50 Megapixel
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Camera Modes
- Panorama, Slow motion mode, Pro mode, night mode, Food, Portrait, AR lens, Macro mode
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 120 fps
- Scene Optimiser
Second Camera
- Sensor Resolution
- 5 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
Third Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.5"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 399 ppi
- Max Brightness
- 800 cd/m²
- Colour Depth
- 16.7 million colours
- Enhancement Technology
- Eye Comfort Shield
- Refresh Rate
- 90 Hz
- Infinity U Display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 5000 mAh
- Fast Charging Technology
- Samsung Super Fast Charging
- Talk Time
- 3060 minutes
- Run Time Details
- Talk (LTE): up to 3060 min , Active online usage (LTE): up to 19 hrs , Playback (video): up to 20 hrs , Active online usage (Wi-Fi): up to 19 hrs , Playback (audio): up to 109 hrs
- SGS Eye Care Display Certification
- Included Accessories
- SIM card removal tool, USB-C to USB-C cable
- 2-year warranty
- Regional Warranty Exceptions
- Spain - 3 years
Sustainability Information
- 8.3 (out of 10)
