Samsung Flip 2 65" Interactive Display - WM65R
Quicklinx: FQ0HWS00 Mfr#: LH65WMRWBGCXEN
  • Draw, write & inspire ideas
    Samsung Flip provides users with a smooth and familiar pen to paper writing experience in a variety of available colors, styles and widths. Up to 4 people can write simultaneously, using any object as a writing tool. In addition, users can quickly erase the drawings with finger or palm swipe
  • Creating a masterpiece
    On brush mode, Samsung Flip recognizes a wide range of thicknesses, ensuring users can create art at the stroke of a brush. Water and oil painting modes allow different styles and textures, while the Flip also gives users a full, vibrant color palette, even allowing flexible color mixing
  • Write on any background
    Samsung Flip allows users to write on any background source. By simply clicking the note layer button, users can enjoy smooth writing anytime, anywhere on any content displayed, without affecting any work behind the original layer
  • Flexible image editing
    Bringing versatility to the board. With Samsung Flip, users can quickly and easily select, move, crop, capture, and edit any images. Each Image can also be merged to the roll with just one click of a button, allowing it to be edited or erased
  • Suitable for all business needs
    Samsung Flip can be used for a wide range of business applications, providing embedded versatile templates. You can use the Flip as a calendar, scheduler, note or checklist board. Samsung Flip perfectly matches any business need, enabling users to utilize the display in various customized ways
  • Easy content navigation & protection
    Samsung Flip has up to 20 pages of writing space per roll, allowing users to seamlessly scroll through pages. In addition, the Flip ensures that confidential meeting information remains in the right hands. Its reinforced lock system allows users to safeguard sensitive content from view
  • Multiple connection options
    Users are empowered by the Flip's versatile connection options. USB, HDMI, NFC and screen sharing capabilities enable optimum collaboration and provide interactive content visibility, notation and sharing. The Flip also offers an optional tray as a more powerful connectivity extension
  • Synchronized screen viewing
    The touch out functionality allows users to sync their personal devices with the Samsung Flip, allowing real-time content sharing and control. Any changes made on the Flip display will be mirrored on the connected device, and vice versa, for efficient collaboration
  • Connect from anywhere
    The Samsung Flip allows users to connect their PC to the board remotely, meaning any meeting can be started without a PC to avoid delays and ensure efficiency. A Bluetooth keyboard, mouse and speaker can also be connected to the Flip, creating a convenient meeting environment
  • Large audience sharing
    Users can project content on Samsung Flip to another large digital display in real time, using Wi-Fi network or HDMI out connection. Even connected to a personal device, the Flip display can be shared. This feature is ideal for large meeting environments, delivering information to bigger audiences
  • Effortless meeting recap distribution
    Following any meeting, users can distribute recaps to all attendees and colleagues, removing the frustration traditionally associated with handwritten meeting notes. Important conversations and content are stored within the Flip in real-time, easily shareable across mobile and digital channels
  • Precise visuals with powerful operation
    Samsung Flip displays all content in clear UHD picture quality, regardless of the room, creating a compelling meeting environment. Backed by the powerful Tizen 5.0 operating system for a seamless user experience, embedded sensors automatically activate the display when the screen is knocked
Samsung Flip 2 WM65R WMR Series - 65" LED-backlit LCD display - 4K - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN, NFC
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
USB
2 ports
2 passive pens
Voltage
Energy Class
Class A+
181.5 Watt
Power Consumption (On mode)
100 W
Energy Consumption per Year
146 kWh
152.22 cm x 6.29 cm x 89.76 cm
40 kg
Energy Class
Class A+
181.5 Watt
100 W
146 kWh
Diagonal Class
65"
Commercial Use
Yes - interactive
Combined With
Touchscreen
Series
WMR Series
Operating System
Linux
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
Dimensions
Without stand
152.22 cm
6.29 cm
89.76 cm
40 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
2
Configuration
ARM Cortex-A72 Quad-Core ( 1.7 GHz ) - 2.5 GB LPDDR4 - 8 GB
8 GB
Network & Internet Multimedia
Wi-Fi, LAN, NFC
Connector Type
2 x HDMI input , 2 x USB - side , Serial input , LAN
2 passive pens
USB cable
CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST 22505-97, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, BIS, INMETRO, GB 4943.1-2011, AS/NZS CISPR 22:2009, KCC/EK, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power supply
Input Voltage
Power Consumption Sleep
0.5 Watt
Width (Shipping)
169.1 cm
Depth (Shipping)
19.8 cm
Height (Shipping)
105.5 cm
Weight (Shipping)
50.6 kg
10 - 80%
Brand: Samsung
Price Range Ex VAT: £1500+
